help with config.g
1.4k
  • undefined
    patterson6
    So upgraded from duet 2 to duet 3. Made a new config and have been playing around with it.
    Right now my problems are.
    1. Bed heater faults out when activated. Ssr relay don't even light up. seems more like a software issue because hardware is basically the same. I do have the current temp working.
    2. Hotend don't work. I am using a pt100 on a smart effector through temp daughterboard.
    3. Added an expansion board for the RGB leds. I kinda started it but am lost on expansion pins.
    4. My stepper motors for xyz. If you want to double check and see what microstepping is best. I never know if i should use 64 or what. Link for motors in config. Looking for quite.
    Thanks...
    ;NETWORKNETWORKNETWORKNETWORKNETWORKNETWORKNETWORKNETWORKNETWORKNETWORKNETWORKNETWORK***NETWORK
    M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    ;GENERAL PREFERENCESGENERAL PREFERENCESGENERAL PREFERENCESGENERAL PREFERENCESGENERAL PREFERENCESGENERAL PREFERENCES
    M550 P"Duet 3" ; set printer name
    M665 R316 L616.42 B215 H989.4 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
    ;DRIVESDRIVESDRIVESDRIVESDRIVESDRIVESDRIVESDRIVESDRIVESDRIVESDRIVESDRIVESDRIVES
    ;X,Y,Z stepper motors 23HM22-2804S https://www.omc-stepperonline.com/nema-23-bipolar-0-9deg-1-26nm-178-4oz-in-2-8a-2-5v-57x57x56mm-4-wires.html
    ;E steper motor 42BYGHW811 on Nimble 2
    M569 P0.1 S1 ; physical drive 0.1 goes forwards
    M569 P0.2 S1 ; physical drive 0.2 goes forwards
    M569 P0.3 S0 ; physical drive 0.3 goes backwards
    M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
    M350 X64 Y64 Z64 E16 I1 ; configure microstepping with interpolation
    M92 X640.00 Y640.00 Z640.00 E1775.00 ; set steps per mm
    M566 X72000.00 Y72000.00 Z72000.00 E2400.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X330000.00 Y330000.00 Z330000.00 E216000.00 ; set maximum speeds (mm/min)
    M201 X5400.00 Y5400.00 Z5400.00 E120.00 ; set accelerations (mm/s^2)
    M906 X2800 Y2800 Z2800 E1800 I40 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    ;AXIS LIMITSAXIS LIMITSAXIS LIMITSAXIS LIMITSAXIS LIMITSAXIS LIMITSAXIS LIMITSAXIS LIMITS***AXIS LIMITS
    M208 Z0 S1 ; set minimum Z
    ;ENDSTOPSENDSTOPSENDSTOPSENDSTOPSENDSTOPSENDSTOPSENDSTOPSENDSTOPSENDSTOPSENDSTOPS***ENDSTOPS
    M574 X2 S1 P"io0.in" ; configure active-high endstop for high end on X via pin io0.in
    M574 Y2 S1 P"io1.in" ; configure active-high endstop for high end on Y via pin io1.in
    M574 Z2 S1 P"io2.in" ; configure active-high endstop for high end on Z via pin io2.in
    ;Z-PROBEZ-PROBEZ-PROBEZ-PROBEZ-PROBEZ-PROBEZ-PROBEZ-PROBEZ-PROBEZ-PROBEZ-PROBEZ-PROBE
    M558 P5 R0.4 C"io3.in+io3.out" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
    G31 P100 X0 Y0 Z4 ; set Z probe trigger value, offset and trigger height
    M557 R85 S20 ; define mesh grid
    ;HEATERSHEATERSHEATERSHEATERSHEATERSHEATERSHEATERSHEATERSHEATERSHEATERSHEATERSHEATERS
    ;****************************************** Hotend ********************************************************************
    M308 S0 P"temp1" Y"thermistor" T10000 B3950 ; configure sensor 0 as thermistor on pin temp1 // Smart effector // pt 100 // on daugherboard
    M950 H0 C"out1" T0 ; create nozzle heater output on out1 and map it to sensor 0
    M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
    M143 H0 S380 ; set temperature limit for heater 0 to 380C
    ;****************************************** Chamber/Radiator heater ****************************************************
    M308 S1 P"temp2" Y"thermistor" T50000 B3950 ; configure sensor 1 as thermistor on pin temp2
    M950 H1 C"out3" T1 ; create chamber heater output on out3 and map it to sensor 1
    M307 H1 B1 S1.00 ; enable bang-bang mode for the chamber heater and set PWM limit
    M141 H1 ; map chamber to heater 1
    M143 H1 S90 ; set temperature limit for heater 1 to 90C
    ;****************************************** Bed Heater ****************************************************************
    M308 S2 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin temp0
    M950 H2 C"out0" T2 ; create bed heater output on out0 and map it to sensor 2
    M307 H2 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
    M140 H2 ; map heated bed to heater 2
    M143 H2 S120 ; set temperature limit for heater 2 to 120C
    ;COOLINGCOOLINGCOOLINGCOOLINGCOOLINGCOOLINGCOOLINGCOOLINGCOOLINGCOOLINGCOOLINGCOOLING
    ;****************************************** Water pump for hotend ****************************************************
    M950 F0 C"out5" Q500 ; create fan 0 on pin out5 and set its frequency
    M106 P0 C"water pump " S1 H1:1 T35 ; set fan 0 name and value. Thermostatic control is turned on
    ;****************************************** Chamber fan blowing on radiator*******************************************
    M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
    M106 P1 C"radiator fan" S1 H1:1 T35 ; set fan 1 name and value. Thermostatic control is turned on
    ;****************************************** Recirc/hepa filter fan ****************************************************
    M950 F2 C"out7" Q500 ; create fan 2 on pin out7 and set its frequency
    M106 P2 C"recirc/hepa fan" S1 H1:1 T35 ; set fan 2 value. Thermostatic control is turned on
    ;****************************************** Berd air ******************************************************************
    M950 F3 C"out4" Q500 ; create fan 3 on pin out4 and set its frequency
    ;M106 P3 C"berd air" S1 H3 T35 ; set fan 3 value. Thermostatic control is turned on // Not needed at this time
    ;LEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLED
    ;***************************************** RGBW led strip on build area **********************************************
    M950 F4 C"out9" ; create white led on mainboard pin out9
    ;M950 F4 C"out6" ; create red led on expansion pin out 6
    ;M950 F4 C"out7" ; create green led on expansion pin out 7
    ;M950 F4 C"out8" ; create blue led on expansion pin out 8
    ;TOOLSTOOLSTOOLSTOOLSTOOLSTOOLSTOOLSTOOLSTOOLSTOOLSTOOLSTOOLSTOOLSTOOLS***TOOLS
    M563 P0 D0 F0 ; define tool 0
    undefined undefined 2 Replies Last reply 10 Mar 2021, 11:23 Reply Quote 0
    • undefined
      fcwilt
      Please do the following from the DWC console:
      Execute M122 and post the results
      Execute M98 P"config.g" and post the results
      Thanks.
      undefined 1 Reply Last reply 12 Mar 2021, 13:22 Reply Quote 0
      • undefined
        jay_s_uk @patterson6
        @patterson6
        have you included power to the out 0 power in? out0 won't work without that.
        These are the correct settings for a daughter board with PT100 assuming you are using input number 1
        M308 S1 P"spi.cs1" Y"rtd-max31865" ; PT100 Temperature Sensor
        you can interpolate the motors at any steps on the duet 3 but going higher than x16 probably won't make much difference.
        undefined 1 Reply Last reply 10 Mar 2021, 16:50 Reply Quote 0
        • undefined
          patterson6 @jay_s_uk
          @jay_s_uk
          1. You were right with the out0 in. So i just bridged from the 24v. The bed works now. Thanks
          2. The M308 didnt work. Its not really on input number 1. Nothing is. I just put that in the config when i was in editor. Its just plugged into temp daughterboard then the z-prob is on IO3.
          3. Any idea for pin assignment on how to gcode it? My White led turns on fine when i do a M106. I just have to get the expansion board installed when it comes for the r,g,b. It will be plugged into those pinouts on the expansion board.
            ;******************** RGBW led strip on build area **********************
            ;M950 F5 C"out6" ; create red led on expansion pin out 6
            ;M950 F6 C"out7" ; create green led on expansion pin out 7
            ;M950 F7 C"out8" ; create blue led on expansion pin out 8
          4. Thanks
          undefined 1 Reply Last reply 10 Mar 2021, 18:19 Reply Quote 0
          • undefined
            Veti
            @patterson6 said in help with config.g:
            this is not the result of a delta calibration.
            also your config does not have a M501.
            So you have not run a pid tune. this will cause the observed errors on the bed.
            undefined 1 Reply Last reply 12 Mar 2021, 13:34 Reply Quote 0
            • undefined
              P"spi.cs1"
              that specifies the temp daughterboard. they have 2 inputs, CS0 and CS1 so you will have to modify that line accordingly
              undefined 1 Reply Last reply 12 Mar 2021, 13:23 Reply Quote 0
              • undefined
                patterson6 @fcwilt
                @fcwilt m122
                still having trouble with hotend
                RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (standalone mode)
                Board ID: 08DJM-956L2-G43S8-6J9FD-3SJ6R-TB0AG
                Used output buffers: 1 of 40 (12 max)
                Static ram: 149788
                Dynamic ram: 92524 of which 160 recycled
                Never used RAM 116360, free system stack 200 words
                Tasks: NETWORK(ready,199) ETHERNET(blocked,109) HEAT(blocked,297) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,354) TMC(blocked,53) MAIN(running,1123) IDLE(ready,19)
                Owned mutexes:
                Last reset 00:01:10 ago, cause: software
                Last software reset at 2021-03-12 07:19, reason: User, GCodes spinning, available RAM 116360, slot 2
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                Error status: 0x00
                Aux0 errors 0,0,0
                Aux1 errors 0,0,0
                MCU temperature: min 28.8, current 29.5, max 29.7
                Supply voltage: min 21.4, current 22.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
                Driver 0: position 971943, standstill, reads 1384, writes 14 timeouts 0, SG min/max 0/0
                Driver 1: position 971943, standstill, reads 1384, writes 14 timeouts 0, SG min/max 0/0
                Driver 2: position 971943, standstill, reads 1385, writes 14 timeouts 0, SG min/max 0/0
                Driver 3: position 0, standstill, reads 1385, writes 14 timeouts 0, SG min/max 0/0
                Driver 4: position 0, standstill, reads 1388, writes 11 timeouts 0, SG min/max 0/0
                Driver 5: position 0, standstill, reads 1388, writes 11 timeouts 0, SG min/max 0/0
                Date/time: 2021-03-12 07:20:19
                Slowest loop: 4.14ms; fastest: 0.05ms
                === Storage ===
                Free file entries: 10
                SD card 0 detected, interface speed: 25.0MBytes/sec
                SD card longest read time 2.3ms, write time 0.0ms, max retries 0
                === MainDDARing ===
                === AuxDDARing ===
                Bed heaters = 2 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 1 -1 -1 -1
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                SBC is idle in state(s) 0
                Daemon is idle in state(s) 0
                Aux2 is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 6.76ms; fastest: 0.02ms
                Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
                HTTP sessions: 1 of 8
                • Ethernet -
                  State: active
                  Error counts: 0 0 1 0 0
                  Socket states: 5 2 2 2 2 0 0 0
                  === CAN ===
                  Messages queued 281, send timeouts 631, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
                  M98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is disabled
                  TELNET is disabled
                  Warning: Sensor number 0 has not been defined
                  Tool 0 offsets: X0.00 Y0.00 Z0.00
                • undefined
                  @jay_s_uk
                  tried both 0 and 1 no go...
                  M308 S1 P"spi.cs0" Y"rtd-max31865" ; configure sensor 0 as thermistor // Smart effector // pt 100 // on daugherboard
                  undefined 1 Reply Last reply 12 Mar 2021, 13:27 Reply Quote 0
                  • undefined
                    @jay_s_uk
                    you should be using H1 rather H0 otherwise the heater won't be created correctly for the tool
                    undefined 1 Reply Last reply 12 Mar 2021, 16:33 Reply Quote 0
                    • undefined
                      patterson6 @Veti
                      @Veti what do you mean its not a result of a delta calibration? what am i missing? Where would the M501 go? Yeah i didnt pid tune anything yet. Just trying to get it all working first. I am not great with Gcode.
                      undefined 1 Reply Last reply 12 Mar 2021, 14:00 Reply Quote 0
                      • undefined
                        Veti @patterson6
                        @patterson6
                        please read https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Auto_calibration
                        • undefined
                          @jay_s_uk what does the S do in M308? reprap says sensor number but idk whats what. i was just matching the heater number. also still dont work. i tried both spi.cs1 and spi.cs0
                          M308 S3 P"spi.cs1" Y" rtd-max31865" ; define temperature sensor number 3 as a PT100 on the first port of a temperature daughter board plugged into mainboard
                          M950 H1 C"out1" T0 ; create nozzle heater output on out1 and map it to sensor 0
                          M307 H1 A498.0 C324.4 D4.2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                          M143 H1 S350 ; set temperature limit for heater 0 to 350C
                          M308 S1 P"temp2" Y"thermistor" T50000 B3950 ; configure sensor 1 as thermistor on pin temp2 two sensors wired together
                          M570 H0 P10000 T15 ; Set heater fault detection for out 3, 1,000 second anomaly, 10c excursion
                          M950 H0 C"out3" T1 ; create chamber heater output on out3 and map it to sensor 1
                          M307 H0 A72.0 C71.5 D1.4 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit
                          M141 H0 ; map chamber to heater 1
                          M143 H0 S90 ; set temperature limit for heater 1 to 90C
                          M307 H2 A183.1 C1561.5 D.7 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                          • undefined
                            Here's what a sane setup for heaters looks like right out of the config tool.
                            M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
                            M308 S1 P"spi.cs0" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs0
                            M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
                            M308 S2 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 2 as thermistor on pin temp1
                            M950 H2 C"out2" T2 ; create chamber heater output on out2 and map it to sensor 2
                            M307 H2 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit
                            M141 H2 ; map chamber to heater 2
                            M143 H2 S280 ; set temperature limit for heater 2 to 280C
                            I didn't duplicate your fans or tools though.
                            undefined 1 Reply Last reply 13 Mar 2021, 22:56 Reply Quote 1
                            • undefined
                              patterson6 @Phaedrux
                              @Phaedrux I found that at the bottom H1 was not declared under tools. So now my hotend pops up on dwc but under current for temp i am reading 2000.0c before it was just n/a. so then i changed the spi.cs0 to spi.cs1 even spi.cs2 even spi.cs3. nothing worked and all said 2000c. I checked all my connections and everything seems right.
                              The bright side my expansion board came today and i wired up the rgb led and found the extension on the out.6 pin just need an 1.out.6. So those work and i also added some more thermistors in extra. Pretty cool. I wish the trend chart was bigger.
                              M558 P5 R0.4 C"io3.in+io3.out" H5 F500 T1500 ; set Z probe type to effector and the dive height + speeds
                              M557 R215 S25 ; define mesh grid
                              M308 S1 P"spi.cs0" Y"rtd-max31865" A"Hotend" ; define temperature sensor number 1 as a PT100 on the first port of a temperature daughter board plugged into mainboard
                              M143 H1 S280 ; set temperature limit for heater 0 to 280C
                              M308 S2 P"temp2" Y"thermistor" A"Radiator" T50000 B3950 R2300 ; configure sensor 2 as thermistor on pin temp2 two sensors wired parallel
                              M570 H2 P10000 T15 ; Set heater fault detection for out 3, 1,000 second anomaly, 10c excursion
                              M950 H2 C"out3" T2 ; create chamber heater output on out3 and map it to sensor 2
                              M307 H2 A72.0 C71.5 D1.4 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit
                              M143 H2 S90 ; set temperature limit for heater 2 to 90C
                              M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
                              M307 H0 A183.1 C1561.5 D.7 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                              M143 H0 S120 ; set temperature limit for heater 2 to 120C
                              ;EXTRASEXTRASEXTRASEXTRASEXTRASEXTRASEXTRASEXTRASEXTRASEXTRASEXTRASEXTRASEXTRASEXTRAS
                              ;****************************************** Recirc air temp from hepa ****************************************************
                              M308 S5 P"temp3" Y"thermistor" A"Filter air temp" T100000 B3950 R2500 ; configure sensor 5 as thermistor on pin temp3
                              ;****************************************** MCU Temp *****************************************************************
                              M308 S6 Y"mcu-temp" A"MCU" ; configure sensor 6 as mcu temp on motherboard
                              ;****************************************** Air temp above effector ****************************************************
                              M308 S7 P"temp1" Y"thermistor" A"Effector air temp" T100000 B3950 ; configure sensor 6 as thermistor on pin temp3
                              M950 F5 C"1.out6" ; create red led on expansion pin out 6
                              M950 F6 C"1.out7" ; create green led on expansion pin out 7
                              M950 F7 C"1.out8" ; create blue led on expansion pin out 8
                              ;MiscellaneousMiscellaneousMiscellaneousMiscellaneousMiscellaneousMiscellaneousMiscellaneousMiscellaneous
                              undefined 1 Reply Last reply 13 Mar 2021, 23:48 Reply Quote 0
                              • undefined
                                Phaedrux Moderator @patterson6
                                Photo of your wiring at the daughterboard?
                                undefined 1 Reply Last reply 14 Mar 2021, 00:18 Reply Quote 0
                                • undefined
                                  from the duet 2 to duet 3 the rest of the hardware has been untouched. Its been a year but i think the pt100 was working at that time.
                                  • undefined
                                    Can you get a closer show of the daughterboard itself? Can you remove it and reseat it?
                                    undefined 1 Reply Last reply 14 Mar 2021, 00:24 Reply Quote 0
                                    • undefined
                                      @Phaedrux i removed it and checked the pins. seems to be seated properly. i have an extra smart effector i can try that i guess. if not i can buy another pt100. seems more like software.
                                      • undefined
                                        Can you do this test on the daughterboard?
                                        https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors#Section_To_test_the_functionality_of_one_of_the_PT100_channels
                                        undefined 2 Replies Last reply 14 Mar 2021, 00:28 Reply Quote 0
                                        • undefined
                                          @Phaedrux pretty sure i can. give me a little bit
                                          7 out of 29
