    Source of Preconfigured Files?
    help setup duet2wifi duex5 bltouch
    814
    • JDigglyWigglyundefined
      JDigglyWiggly
      Hello, I've recently purchased:
      Duet2Wifi
      Deux5
      PanelDue 7i
      Firmware:
      • 3.2.2 (2021-01-05)
      • Server Version 1.23
      • Web Control 3.2.2
      The Printers Setup is currently:
      • Cartesian
      • Printable Area 235x235x240
      • Dual Z Axis Using Z1 and E1
      • BLTouch 3.1 (PWM7 on Duex5)
      • Extruder is set to E2 (E2 on Duex5)
      I use the Ender 3 settings in RRF Config tool for bed heat and steppers, they seem just fine.
      Now, I promise I am not lazy, I'm just a stay at home father of three children all under 10 and all HIGH energy.
      Now I've tried for three weeks to set this up, I'm having a difficult time of it. I'm not complaining, it's a great system and somewhat easy to use, I just can't seem to focus.
      Would it be possible to get a working config/bed/retract/deploy.
      I thank anyone reading this in advance. I appreciate the help.
        jay_s_uk
        we have an example set of ender 3 files here https://github.com/TeamGloomy/ender-3-fly-E3
          JDigglyWiggly
          I appreciate your help, unfortunately I'm not looking for a menu system for an Ender 3. Thank you though, for being helpful and prompt!
            jay_s_uk @JDigglyWiggly
            @JDigglyWiggly look in the sys folder.
            It has everything you need.
            There is also a branch for the bltouch too
              There's also the config tool itself to generate a set.
              https://configtool.reprapfirmware.org/Start
                JDigglyWiggly
                Absolutely, the problem is, I can't make heads or tails how to set up the dual Z and BLTouch. Using the config tool, when assigning steppers, it lists as
                X
                Y
                Z
                E0
                E1
                X
                Y
                Z
                E0
                E1
                Doesn't seem to take the Duex5 in to account.
                Bltouch should be pwm5, which shows up, but isn't powering up
                  The Dual Z would need to be manually added to the M584 command in config.g. And if you wanted to do auto leveling between them you'd have to manually add a M671 command to tell it where your lead screws are and then setup bed.g to probe points close to the lead screws. All described here: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                  @JDigglyWiggly said in Source of Preconfigured Files?:
                  X
                  Y
                  Z
                  E0
                  E1
                  X
                  Y
                  Z
                  E0
                  E1
                  This does seem to be a problem. I'll ask @chrishamm to take a look next chance he gets. It seems to only be a display problem though. If you choose the second X it will use driver 5 in the generated config.
                  Here's what the config tool generated for me based on what info you've provided, You can load this config.json file into the config tool and use it to export a full set of config files.
                  config.json
                  Then you can compare to this config.g which I've corrected for the drive mappings for dual Z and extruder on duex.
                  ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Mar 12 2021 18:30:41 GMT-0600 (Central Standard Time)
                  G90                                                     ; send absolute coordinates...
                  M83                                                     ; ...but relative extruder moves
                  M550 P"Ender 3 Pro"                                     ; set printer name
                  M918 P1 E4 F2000000                                     ; configure direct-connect display
                  M552 S1                                                 ; enable network
                  M586 P0 S1                                              ; enable HTTP
                  M586 P1 S0                                              ; disable FTP
                  M586 P2 S0                                              ; disable Telnet
                  M569 P0 S0                                              ; physical drive 0 goes backwards
                  M569 P1 S0                                              ; physical drive 1 goes backwards
                  M569 P2 S1                                              ; physical drive 2 goes forwards
                  M569 P3 S1                                              ; physical drive 3 goes forwards
                  M569 P4 S0                                              ; physical drive 4 goes backwards
                  M569 P5 S0                                              ; physical drive 5 goes backwards
                  M584 X0 Y1 Z2:3 E5                                    ; set drive mapping
                  M350 X16 Y16 Z16 E16:16:16 I1                           ; configure microstepping with interpolation
                  M92 X80.00 Y80.00 Z400.00 E93.00:93.00:93.00            ; set steps per mm
                  M566 X1200.00 Y1200.00 Z24.00 E300.00:300.00:300.00     ; set maximum instantaneous speed changes (mm/min)
                  M203 X9000.00 Y9000.00 Z180.00 E6000.00:6000.00:6000.00 ; set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z100.00 E5000.00:5000.00:5000.00   ; set accelerations (mm/s^2)
                  M906 X800 Y800 Z800 E1000:1000:1000 I50                 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                                 ; Set idle timeout
                  M208 X0 Y0 Z0 S1                                        ; set axis minima
                  M208 X235 Y235 Z240 S0                                  ; set axis maxima
                  M574 X1 S1 P"xstop"                                     ; configure active-high endstop for low end on X via pin xstop
                  M574 Y1 S1 P"ystop"                                     ; configure active-high endstop for low end on Y via pin ystop
                  M574 Z1 S2                                              ; configure Z-probe endstop for low end on Z
                  M950 S0 C"duex.pwm7"                                    ; create servo pin 0 for BLTouch
                  M558 P9 C"^zprobe.in" H5 F120 T6000                     ; set Z probe type to bltouch and the dive height + speeds
                  G31 P500 X0 Y0 Z2.5                                     ; set Z probe trigger value, offset and trigger height
                  M557 X15:215 Y15:195 S20                                ; define mesh grid
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B3950          ; configure sensor 0 as thermistor on pin bedtemp
                  M950 H0 C"bedheat" T0                                   ; create bed heater output on bedheat and map it to sensor 0
                  M307 H0 B0 S1.00                                        ; disable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                                 ; map heated bed to heater 0
                  M143 H0 S150                                            ; set temperature limit for heater 0 to 150C
                  M308 S1 P"e0temp" Y"thermistor" T100000 B3950           ; configure sensor 1 as thermistor on pin e0temp
                  M950 H1 C"e0heat" T1                                    ; create nozzle heater output on e0heat and map it to sensor 1
                  M307 H1 B0 S1.00                                        ; disable bang-bang mode for heater  and set PWM limit
                  M143 H1 S275                                            ; set temperature limit for heater 1 to 275C
                  M950 F0 C"fan0" Q500                                    ; create fan 0 on pin fan0 and set its frequency
                  M106 P0 S0 H-1                                          ; set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"fan1" Q500                                    ; create fan 1 on pin fan1 and set its frequency
                  M106 P1 S1 H1 T45                                       ; set fan 1 value. Thermostatic control is turned on
                  M950 F2 C"fan2" Q500                                    ; create fan 2 on pin fan2 and set its frequency
                  M106 P2 S1 H1:0 T45                                     ; set fan 2 value. Thermostatic control is turned on
                  M563 P0 D0 H1 F0                                        ; define tool 0
                  G10 P0 X0 Y0 Z0                                         ; set tool 0 axis offsets
                  G10 P0 R0 S0                                            ; set initial tool 0 active and standby temperatures to 0C
                  M501                                                    ; load saved parameters from non-volatile memory
                  M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"      ; set voltage thresholds and actions to run on power loss
                  T0                                                      ; select first tool
                  JDigglyWigglyundefined 1 Reply Last reply Reply Quote 1
                    JDigglyWiggly @Phaedrux
                    @Phaedrux Thank you so much! I'll be giving this a shot once my kiddos are asleep. I seriously can't thank you enough.
                      No problem, thanks for reporting the bug in the config driver selection display.
                      JDigglyWigglyundefined 1 Reply Last reply Reply Quote 0
                        @Phaedrux Mark this one solved. The config you provided worked as a great baseline. That was nice of you to help out. Thanks again.
                        Phaedruxundefined 1 Reply Last reply Reply Quote 1
                          Phaedrux Moderator @JDigglyWiggly
                          @JDigglyWiggly I did it out of sympathy for a dad with 3 kids under 10.
