    PID Tuning help needed
    2.2k
    • Reefwarriorundefined
      Reefwarrior
      Hi
      I have started to PID tune my hotend heater, but it has been going for 20 minutes now, without finishing up - also I am at a P parameter of 0.1; am using an external mosfet driving my 24V heater (I want as little as possible current through my control board).
      I am using a Duet2 board, with firware V 3.2.2; and Duet wifi server verion 1.25. I have included the text from the configuration at the end of this post.
      Other strange thing is, there are quite a lot of oscillations with regards to the temperature being sensed. (Up to 3 to 4 degrees up and down)
      Any/all help appreciated!
      Tinus
      CONTENTS OF CONFIG.G
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Nov 03 2020 07:37:18 GMT-0800 (Pacific Standard Time)
      M550 P"Ender3" ; set printer name
      M918 P1 E4 F2000000 ; configure direct-connect display
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; X Stepper
      M569 P1 S0 ; Y Stepper
      M569 P2 S0 ; Z Stepper
      M569 P3 S1 ; E Stepper
      M569 P4 S0
      M584 X0 Y1 Z2:4 E3 ; set drive mapping
      M92 X80.00 Y80.00 Z1200.00 E401 ; set steps per mm
      M566 X800.00 Y800.00 Z800.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y15000.00 Z1500.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z250.00 E5000.00 ; set accelerations (mm/s^2)
      M906 X800 Y1000 Z850 E1500 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M671 X-24.2:250.8 Y0:0 S1.0
      M208 X-77.2 Y-13 Z0 S1 ; set axis minima
      M208 X270 Y258 Z360 S0 ; set axis maxima
      M574 X1 S1 P"!xstop" ; x-end stop with inverse operation
      M574 Y1 S1 P"!ystop" ; y-end stop with inverse operation
      M574 Z1 S2 ; z-end stop with inverse operation
      M950 S0 C"exp.heater3" ; define servo
      M558 C"zprobe.in" P9 H10 F120 T3000 S1 I1 ; set Z probe type to switch and the dive height + speeds
      G31 X40.0 Y-4.5 Z2.35 ; set Z probe trigger value, offset and trigger height // Z2.35
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 B1 S0.6 ; enable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S150 ; set temperature limit for heater 0 to 150C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
      M307 H1 B0 S0.6 ; disable bang-bang mode for heater and set PWM limit
      M302 S180 R180 ; Set retraction/extruding temperature limits. Extruding 180, Retraction 180.
      M143 H1 S320 ; Set maximum heater temperature to 320C
      ;M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S0.85 ; disable bang-bang mode for heater and set PWM limit
      M950 F0 C"e1heat" ; create fan 0ler Fan" H-1 ; set fan 2 value. Thermostatic control is turned on @ 0.8Factor and 180C
      M106 P0 C"Part Cooler Fan" H-1
      M950 F1 C"fan0"
      M106 P1 C"Fan unknown 0" H-1
      M950 F2 C"fan1"
      M106 P2 C"Hot End Fan" H1 T40
      M950 F3 C"fan2"
      M106 P3 C"Extruder Stepper Fan" H1 T60
      T0 ; select first tool
      ; Signal to user that probe and loading is complete
      M501 ; Load EEPROM details
      M575 P1 S1 B115200
        jay_s_uk
        the oscillations are normal and it can take up to an hour or more to PID tune something. just let it run its course
        Reefwarriorundefined 1 Reply Last reply Reply Quote 0
          Reefwarrior @jay_s_uk
          @jay_s_uk said in PID Tuning help needed:
          Thanx, but is it normal to shoot 30+ degrees Pas target, and the oscillations do not get smaller!?
            jay_s_uk @Reefwarrior
            @Reefwarrior yes. its measuring cooling and heating times
              Reefwarrior
              @jay_s_uk Thank you - I will try again and let you know. Weird is that I started the PID process with a temperature of 240C, but on initial heating now it went past 320C. I suspect that the glass thingy (I forgot the name now!) that measures the temperature may not be calibrated/defined correctly.
              I know in Marlin you can choose the different options, but I haven't come across it in the duet firmware yet. Or am I missing something?
              Tinus 🙂
              jay_s_ukundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                @Reefwarrior yea, it shouldn't go as high as 320 on a 240 degree tune.
                The M308 line in config sets the thermistor. best finding out what you had in marlin so you can replicate it here
                • deckingmanundefined
                  deckingman @Reefwarrior
                  @Reefwarrior It sounds to me like you have a very over powered heater. Might it be 12V heater running in a 24V system? Are you able to measure the resistance of the heater cartridge? If so, post the value here and one of us will work out the wattage.
                  Reefwarriorundefined 1 Reply Last reply Reply Quote 1
                    Reefwarrior @deckingman
                    @deckingman Hi, I get 4.1ohm. I don't know if this can be correct, as it 'feels' too little?
                      @Reefwarrior typical resistances
                      P\V --------------------- 12V---- 24V
                      40w (Red Leads) 3.6Ω 14.4Ω
                      25w (Blue Leads) 5.76Ω 23.04Ω
                        @Reefwarrior said in PID Tuning help needed:
                        So, if my maths serves me correctly, V=IR, so I=V/R = 24/4.1 = 5.8536Amps. Wattage = VI = 24 x 5.853 = 140.48 Watts !!
                        If the voltage was 12, then the current becomes 2.9 Amps so the wattage would then be 12 x 2.9 = 35 Watts.
                        So it looks you have a nominal 40 watt \ 12V cartridge so when you put 24V through it, you get roughly 4 x the heating power.
                        Note. A 40 Watt/24V cartridge would have a resistance of about 14.5 Ohms.
                        Edit. A 40W/ 24v heater cartridge would draw about 1.65 Amps which is perfectly safe to use with the onboard MOSFETs - no need to use an external one.
                          Reefwarrior
                          Thank you all for the feedback. Yes seems I am running a 12V then at 24V. I take it I can't just put in a power factor of P0.25 to fix this? Or will it be better to rather just swap it out for a 24V cartridge?
                          deckingmanundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                            Running 25% PWM is bad idea IMO. The problem is that, if a MOSFET fails, then you could end up with the full ("permanent" as in non PWM switched) 24V which could be a fire risk.
                              @Reefwarrior swap it. it will be unsafe until you do so
                                Reefwarrior
                                Cool thank you. I will swap it out this afternoon then, and see if it is better.
                                With regards to the temperature measurement. Is it normal for it to jump up and down a few degrees? The graphs show spikes, instead of a normal flat line....
                                deckingmanundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                  I think you'll find it's a lot more stable with a cartridge that is a better match to the hot end. The PID control can only do so much and when you have a heater that is over powered by a factor of 4 then you are likely to get overshoots when it turns on.
                                    droftarts administrators @Reefwarrior
                                    No, check your wiring. Either it's picking up interference (usually from stepper motor or endstop wiring), or there's a poor joint. It will also cause the PID tuning to fail, as it can't get a consistent reading, and it's probably why it's taking so long to tune.
                                    Are you using a thermistor PT1000, PT100 or thermocouple? There are ways to make the last two more reliable, by using four wires rather than just two.
                                      Reefwarrior @droftarts
                                      @droftarts Hi Ian,
                                      It looks like one of those little glass bead thingies that measures the temperature....
                                        @Reefwarrior Sounds like a thermistor. Check your wiring, and make sure the leads of the thermistor aren't grounding on the heater block, and that the thermistor bead is making good contact with the heater block (ie not flapping about in a big hole!). Cartridge thermistors, or PT1000, are generally easier to use and get good contact with. What kind of hot end is this?
                                        Reefwarriorundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                                          @droftarts E3d v6 clone. I will take a look at the hotend too....
                                            deckingman @droftarts
                                            @droftarts Did you check the earlier posts? It transpires the OP has a 12V cartridge and a 24V system. So around 140 Watt instead of 35. Methinks, that's more likely to cause the oscillations.
