Duet 2 wifi failures
@Phaedrux Oh those are just from the print (duet holder). It looks like its on the card but they are mid air
And i blew the duet clean, still the same issue.
When and where did you purchase the Duet?
@Phaedrux From reprappro.me 7th July 2020
Please contact your vendor and initiate the warranty exchange process. Include a link to this thread as authorization.
@tia79
Hello, I don’t know if you finally found a solution but I have the same issue: “Duet reject http request...”. I have understood the system didn’t find the config.g file and also nothing else (after trying to install a new firmware).
I finally found the solution by reformatting the SD CARD. It has to be Fat 32 formatted. But this information isn’t sufficient. If you use a Mac, you can also choose the partition map type to format your card. It has to be the master boot record partition map and nothing else. If you use the guid partition map, the duet doesn’t recognise your config.
I hope this information could be helpful. -
@redax27 It's recommended to use the SD card formatting tool to ensure the card is properly formatted.
