    Duet 2 wifi failures
    2.1k
    • tia79undefined
      tia79
      @Veti https://cdn.discordapp.com/attachments/549857567342592002/821709016430018610/Screenshot_3.png
        droftarts administrators @tia79
        @tia79 did you format the SD card with the formatting tool from https://www.sdcard.org/downloads/formatter/index.html ? If it’s not the one supplied with Duet, what make, model and speed is it? Or post picture.
        • tia79undefined
          tia79
          @droftarts It is the original Duet sd card. I got the page up again but its giving me "Your Duet rejected the HTTP request: page not found
          Check that the SD card is mounted and has the correct files in its /www folder" even tho the content on the card is correct.
            @tia79 how did you enable networking? By sending M552 S1 via USB? If so, the network is not being enabled because the config.g file is not being read. This will be because either the SD card isn’t working in the Duet, or the Duet SD card socket is faulty. With the information you have supplied, I don’t know which it is. So:
            1. Format the SD card with the SD card formatting tool, copy configuration and www files on to the SD card and try again.
            2. If that doesn’t work, inspect the SD card socket as described here: https://duet3d.dozuki.com/Wiki/SD_Card#Section_SD_Card_Socket
              If the socket looks like the one in the picture, take a picture of yours and post it here, and we’ll work out if you need a warranty replacement.
            • tia79undefined
              tia79
              @droftarts I tried to reformat the sd card but no luck. its still the "Your duet rejected the HTTP request".
              I give up trying to fix this.
              SD card socket pic: https://cdn.discordapp.com/attachments/549857567342592002/821769534707990558/20210317_154424.jpg
                Do you have some compressed air to blow off the board and the slot? It's possible there is some dirt and debris in there blocking the SD card contacts.
                • tia79undefined
                  tia79
                  @Phaedrux Dirt and debris? You sound like i used the card while i was making mudcakes 🙄
                    Instant mudcakes. Just add water. 😜
                    • tia79undefined
                      tia79
                      @Phaedrux Oh those are just from the print (duet holder). It looks like its on the card but they are mid air 🙂 And i blew the duet clean, still the same issue.
                        When and where did you purchase the Duet?
                        • tia79undefined
                          tia79
                          @Phaedrux From reprappro.me 7th July 2020
                          redax27undefined 1 Reply Last reply Reply Quote 0
                            Please contact your vendor and initiate the warranty exchange process. Include a link to this thread as authorization.
                            • redax27undefined
                              redax27 @tia79
                              @tia79
                              Hello, I don’t know if you finally found a solution but I have the same issue: “Duet reject http request...”. I have understood the system didn’t find the config.g file and also nothing else (after trying to install a new firmware).
                              I finally found the solution by reformatting the SD CARD. It has to be Fat 32 formatted. But this information isn’t sufficient. If you use a Mac, you can also choose the partition map type to format your card. It has to be the master boot record partition map and nothing else. If you use the guid partition map, the duet doesn’t recognise your config.
                              I hope this information could be helpful.
                                Phaedrux Moderator @redax27
                                @redax27 It's recommended to use the SD card formatting tool to ensure the card is properly formatted.
