    Duet 2 wifi failures
    2.1k
    • tia79undefined
      tia79
      @droftarts I tried to reformat the sd card but no luck. its still the "Your duet rejected the HTTP request".
      I give up trying to fix this.
      SD card socket pic: https://cdn.discordapp.com/attachments/549857567342592002/821769534707990558/20210317_154424.jpg
        Do you have some compressed air to blow off the board and the slot? It's possible there is some dirt and debris in there blocking the SD card contacts.
        • tia79undefined
          tia79
          @Phaedrux Dirt and debris? You sound like i used the card while i was making mudcakes 🙄
            Instant mudcakes. Just add water. 😜
            • tia79undefined
              tia79
              @Phaedrux Oh those are just from the print (duet holder). It looks like its on the card but they are mid air 🙂 And i blew the duet clean, still the same issue.
                When and where did you purchase the Duet?
                • tia79undefined
                  tia79
                  @Phaedrux From reprappro.me 7th July 2020
                  redax27undefined 1 Reply Last reply Reply Quote 0
                    Please contact your vendor and initiate the warranty exchange process. Include a link to this thread as authorization.
                    • redax27undefined
                      redax27 @tia79
                      @tia79
                      Hello, I don’t know if you finally found a solution but I have the same issue: “Duet reject http request...”. I have understood the system didn’t find the config.g file and also nothing else (after trying to install a new firmware).
                      I finally found the solution by reformatting the SD CARD. It has to be Fat 32 formatted. But this information isn’t sufficient. If you use a Mac, you can also choose the partition map type to format your card. It has to be the master boot record partition map and nothing else. If you use the guid partition map, the duet doesn’t recognise your config.
                      I hope this information could be helpful.
                        Phaedrux Moderator @redax27
                        @redax27 It's recommended to use the SD card formatting tool to ensure the card is properly formatted.
                        https://www.sdcard.org/downloads/formatter/
