    Duet2 ethernet and 12864 display using ST7567
    42
    3.8k
    • CNCModellerundefined
      CNCModeller
      Hi All,
      Is there a guide to using a 12864 display using ST7567 with the Duet2 ethernet anywhere?
      I've been reading up on the duet3 mini and there is a suggestion that one can also be used with the Duet2 as long as you're running RRF 3.2?
      I was shopping for a panel due but I'd rather put the money towards a mini for my other printer if I can use a couple of cheep 12864 displays for stand alone printer management.
      Any constructive thoughts would be much appreciated.
      All the best
      Barry M
      Polar Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      K40 Laser, Duet2
      https://forum.duet3d.com/post/312082
      Wanhao D5S
      https://www.youtube.com/CNCModellerUK
        droftarts administrators @CNCModeller
        @CNCModeller In general, see https://duet3d.dozuki.com/Wiki/Connecting_an_LCD_control_panel#Section_Connecting_a_12864_mono_graphics_LCD_display_with_rotary_encoder
        Compatible displays are https://wiki.fysetc.com/Mini12864_Panel/ and (I think) https://wiki.fysetc.com/Generic_12864_Panel/. For other displays, YMMV, but see the pinout below (some people have got the Ender 12864 panels working).
        You can connect one of the Fystec 12864 displays (with a ST7567 controller) to a Duet 3 Mini 5+ directly; see https://duet3d.dozuki.com/Wiki/Connecting_an_LCD_control_panel#Section_Duet_3_Mini_5_support_for_12864_displays
        For the Duet 2 WiFi/Ethernet, it's supported in RRF 3.2 firmware and later but you will need to make up your own wiring loom between the CONN_SD and CONN_LCD headers to the 12864 display ; see https://duet3d.dozuki.com/Wiki/Connecting_an_LCD_control_panel#Section_Connecting_a_12864_mono_graphics_LCD_display_with_rotary_encoder
        Though the information on connecting a 12864 with a ST7567 controller to the Duet 2 is not quite complete. I'll update it with the information below when I hear from @dc42 that it's correct!
        The pinout table used when ST7567 is selected with M918 is here: https://github.com/Duet3D/RepRapFirmware/blob/c565f35304b0d872d8671584dd6341ce13a82bbf/src/DuetNG/Pins_DuetNG.h#L231
        I've slightly reformatted this to show pin connections from CONN_LCD and CONN_SD (see Duet 2 WiFi/Ethernet wiring diagram HERE) and 12864 EXP1 and EXP2 connectors (see pin out diagram on the page HERE).
        connlcd.2 -> exp1.2 (gnd)
        connlcd.3 -> exp2.6 (EncoderPinB)
        connlcd.4 -> exp2.8 (EncoderPinA)
        connlcd.5 -> exp1.5 (LcdNeopixelPin)
        connlcd.6 -> exp1.6 (LcdResetPin)
        connlcd.7 -> exp1.7 (LcdA0Pin)
        connlcd.8 -> exp1.8 (LcdCSPin)
        connlcd.9 -> exp1.9 (EncoderPinSw)
        connlcd.10 -> exp1.10 (LcdBeepPin)
        connsd.1 -> exp1.1 (+5V)
        connsd.2 -> exp2.2 (gnd)
        connsd.3 -> exp2.7 (SD CS)
        connsd.4 -> exp2.9 (sck)
        connsd.5 -> exp2.5 (mosi)
        connsd.6 -> exp2.10 (miso)
        There's also a very long thread which charts the development of connecting 12864 displays here: https://forum.duet3d.com/topic/15611/logic-level-shifter-for-12864-display-on-duet-2-wifi/198
        CNCModellerundefined 1 Reply Last reply Reply Quote 1
          jay_s_uk
          The support for RRF using BTT TFT screens has recently improved to the point where its actually usable
            droftarts administrators @jay_s_uk
            @jay_s_uk said in Duet2 ethernet and 12864 display using ST7567:
            Can you post a link to the "useable" ones?!
              jay_s_uk @droftarts
              @droftarts
              Use the images from this link https://github.com/bigtreetech/BIGTREETECH-TouchScreenFirmware/tree/master/Copy to SD Card root directory to update or build your own from the latest sources if your screen isn't listed.
              Make the following adjustments
              • add M409 K"job.file.fileName" in start.g
              • add M118 P2 S"//action:cancel" in stop.g
              • add M118 P2 S"//action::paused" in pause.g
              • add M118 P2 S"//action::prompt_begin Resuming" in resume.g
              • add M575 P1 S2 B57600 in config.g of RRF to set baudrate to 57600(The baudrate of the TFT and motherboard must be the same)
              There is an RRF specific config.ini to use as a base with all the RRF requirements preset and thats in the same folder as the image above. Just rename it from config_rrf.ini to config.ini and flash as normal
              droftartsundefined 1 Reply Last reply Reply Quote 1
                @jay_s_uk Thanks, interesting. I'll have to get hold of one, and write up how to connect them in the wiki.
                  jay_s_uk @droftarts
                  @droftarts i'll be adding it to our wiki for the LPC/STM port shortly.
                  The functionality has only been added in the last few days so I'm just waiting for it to settle down a bit.
                  I'll drop you a link when I've added it
                    CNCModeller @droftarts
                    Thanks for the information @droftarts. I've just ordered one of the mini displays for my Duet ethernet.
                    I'll probably get a second and a duet mini if I like the interface. Sounds like it's configurable so I can get it set up with just the menu options I need.
                    I found out about this via the post you linked me to about using the display and now I have the pinout I'm really looking forward to seeing it work.
                    Thanks again
                    Barry M
                    Wanhao D4S: Duet2
                    K40 Laser, Duet2
                    Wanhao D5S
                      @CNCModeller and @dc42 confirmed that I've got the pinout correct! I'll update the wiki when I get a moment.
                      CNCModellerundefined 1 Reply Last reply Reply Quote 0
                        @droftarts said in Duet2 ethernet and 12864 display using ST7567:
                        That's great, thanks Ian.
                        All the best
                        Barry M
                        Wanhao D4S: Duet2
                        K40 Laser, Duet2
                        Wanhao D5S
                        • rilotundefined
                          rilot
                          I’m going to be setting up one of the Fysetc displays with a Duet WiFi tomorrow. Thanks for the wiring layout.
                          If I only want display but don’t care about the SD cars I’m assuming I can do without some of the connections. Or are the all required?
                            CNCModeller @rilot
                            Hi @rilot I'd appreciate it if you'd kindly update us on how it went.
                            I assume you're going to need the SD +5v connection as a minimum... But I'm only guessing.
                            Mine won't arrive until the weekend 🙂
                            Many thanks
                            Barry M
                            Wanhao D4S: Duet2
                            K40 Laser, Duet2
                            Wanhao D5S
                            • rilotundefined
                              rilot
                              OK, I got it working apart from the backlight. I'm guessing that the DuetWifi doesn't support the NEOPixel RGB. We have a connection for it though in the pinout for connecting the Mini 12864.
                                droftarts administrators @rilot
                                @rilot can you control it using M150? This from the Duet 3 Mini 5+ section:
                                When using a version 2.1 controller, the colours of the three Neopixel LEDs built into the display can be set using the M150 command with LED type parameter X2.
                                rilotundefined CNCModellerundefined 2 Replies Last reply Reply Quote 0
                                • rilotundefined
                                  rilot @droftarts
                                  @droftarts I'm using a Duet2Wifi and M150 results in a Command not supported error. This is with 3.2.2
                                    CNCModeller @rilot
                                    @rilot said in Duet2 ethernet and 12864 display using ST7567:
                                    Same here on Duet Ethernet... no baclight and M150 "Command Not Supported"
                                    At least its working, I can now look at a custom menu set.
                                    I built a little connector conversion board to address custom the loom requirements, see below.
                                    Thanks for the help folks 🙂
                                    Cheers
                                    BPM
                                    Wanhao D4S: Duet2
                                    K40 Laser, Duet2
                                    Wanhao D5S
                                      @droftarts @dc42
                                      Hi guys, it there any information on @rilot and my issue re Duet Ethernet / WiFi and the 12864 display doesn't have a working backlight and M150 "Command Not Supported".
                                      Any thoughts would be much appreciated.
                                      All the best
                                      Barry M
                                      Wanhao D4S: Duet2
                                      K40 Laser, Duet2
                                      Wanhao D5S
                                      • fulgundefined
                                        fulg
                                        @cncmodeller M150 is not supported on Duet2 due to lack of memory. There are some details in this thread but it is hard to follow. That thread specifically says V2.1 of the display (the one with a NeoPixel) does not work on Duet2.
                                        I can confirm a Fysetc V1.2 12864 display works on Duet2 with RRF 3.2.2, you just need a custom wiring loom. I have since moved on to a Mini5+ where the V2.1 is natively supported.
                                        VORON V2 CoreXY + Duet3 Mini5+ Ethernet v1.0 with Mini2+ expansion, VORON V0 CoreXY + Duet2 Maestro
                                        CNCModellerundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                                          CNCModeller @fulg
                                          @fulg said in Duet2 ethernet and 12864 display using ST7567:
                                          Thanks for the heads up.
                                          As I've got one of the 2.1 displays now, perhaps I can drive the neopixel from a separate Arduino using the neopixel library? I just want a backlight running.
                                          If so do we know which pin is the neopixel data pin? It's not obvious to me from the fysetc page.
                                          http://wiki.fysetc.com/Mini12864_Panel/
                                          Many thanks
                                          Wanhao D4S: Duet2
                                          K40 Laser, Duet2
                                          Wanhao D5S
                                          • gloomyandyundefined
                                            gloomyandy @CNCModeller
                                            @cncmodeller The schematic for the display is here: https://github.com/FYSETC/FYSETC-Mini-12864-Panel/blob/master/hardware/V2.1/Mini12864(RGB)V2.1_sch.pdf
                                            Looks like the Neopixel control signal is the "Red" pin 5 on EXP1
