    Very confused with Duet mesh level correction
    1.1k
    • singhm29undefined
      singhm29
      I feel like something is very off or maybe I am just silly and haven't been understanding this correctly. After getting my printer setup with a Duet 3 6HC and BLtouch I had some success. However after laying dormant for a month I went to start a print only to find my bed level compensation wasnt quite correct when I started a full bed print 600x600mm. This led me down a rabbit hole which I now have many questions about.
      1.My original thought was to just bring the nozzle closer to the print bed through Prusaslicer Z offset but after increasing by -0.4 I realized something else was wrong. I homed my Z axis and checked if Z=0 left only a gap large enough for a piece of paper to slide under. It did not, the gap was much larger. I reset my Z trigger distance by following Betrue3Ds guide probing a single point a number of times and averaging them out. I previously had this as 2.09 and it was now 2.50. Oddly 2.5 is what I had at some other point during my tuning the previous month, I am confused why this keeps changing. I understand why a more negative Z offset in prusaslicer wasnt making any difference as I was already at my Z=0 point but I dont get why this value is changing.
      2.If I probe different points of my bed I get a different trigger height, its repeatable at that point but its not the same between points. I feel like I read somewhere that this should be the same everywhere on the bed.
      3.From this height map the red circled point had a Z height of 0.47mm. I would think that this meant that it was 0.47mm too high and printing in this area would cause the nozzle to print too close to the bed. Instead when I manually set Z=0 at the center of my bed, turned off the motors and manually moved the print bed to this spot it was 0.47mm lower... am I just reading the height map wrong?
      4.I lifted up the red point so that it just caught a piece of paper to be better in line with the center of the printer and to minimize the red point however instead of improving it now told me that red point was 0.68mm... to make things odder it prints better now.
      Thank you for any insights!
      Phaedruxundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @singhm29
        @singhm29 said in Very confused with Duet mesh level correction:
        This sounds like you may have some skew in your frame and/or tilt on the print head.
        Please post some additional information so we can get a better picture of what your printer is doing.
        Post the results of sending M122 and M98 P"config.g" in the gcode console.
        Post your config.g, homing files, bed.g, and slicer start gcode.
        singhm29undefined 1 Reply Last reply Reply Quote 0
        • o_lampeundefined
          o_lampe @singhm29
          @singhm29
          In the early days of 3D printing, we often had people complaining their prints were mirrored. Because in Marlin FW it was easy to confuse the endstop setup and have a X or Y axis setting wrong.
          In your case it seems, like your Z-axis is flipped over, but I have no idea how to achieve that?
          Did you use the Reprap configurator tool to create your config.g and other /sys files?
          • singhm29undefined
            singhm29 @Phaedrux
            @Phaedrux
            Not a problem
            M122
            M122
            RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
            Board ID: 08DJM-956L2-G43S4-6JKDD-3SJ6T-TB6GH
            Used output buffers: 1 of 40 (36 max)
            Static ram: 149788
            Dynamic ram: 93192 of which 132 recycled
            Never used RAM 115720, free system stack 122 words
            Tasks: NETWORK(ready,171) ETHERNET(blocked,109) HEAT(blocked,271) CanReceiv(blocked,927) CanSender(blocked,350) CanClock(blocked,349) TMC(blocked,19) MAIN(running,671) IDLE(ready,19)
            Owned mutexes:
            Last reset 84:30:27 ago, cause: software
            Last software reset at 2021-03-19 23:20, reason: User, GCodes spinning, available RAM 115720, slot 0
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
            Error status: 0x00
            Aux0 errors 0,0,0
            Aux1 errors 0,0,0
            MCU temperature: min 39.6, current 40.5, max 44.5
            Supply voltage: min 22.9, current 23.9, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
            12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0
            Driver 0: position 30073, standstill, reads 53715, writes 130 timeouts 0, SG min/max 0/915
            Driver 1: position 35556, standstill, reads 53715, writes 130 timeouts 0, SG min/max 0/125
            Driver 2: position 365607, standstill, reads 53705, writes 140 timeouts 0, SG min/max 0/1023
            Driver 3: position 0, standstill, reads 53796, writes 50 timeouts 0, SG min/max 0/198
            Driver 4: position 0, standstill, reads 53706, writes 140 timeouts 0, SG min/max 0/1023
            Driver 5: position 0, standstill, reads 53835, writes 11 timeouts 0, SG min/max 0/0
            Date/time: 2021-03-23 11:50:47
            Slowest loop: 69.48ms; fastest: 0.03ms
            === Storage ===
            Free file entries: 10
            SD card 0 detected, interface speed: 25.0MBytes/sec
            SD card longest read time 3.3ms, write time 22.6ms, max retries 0
            DMs created 125, maxWait 416792ms, bed compensation in use: mesh, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 3200, completed moves 3200, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 33], CDDA state -1
            === AuxDDARing ===
            Heater 0 is on, I-accum = 0.0
            Heater 1 is on, I-accum = 0.6
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0
            Aux2 is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 67.65ms; fastest: 0.02ms
            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
            HTTP sessions: 1 of 8
            - Ethernet -
            State: active
            Error counts: 0 0 1 0 0
            Socket states: 5 2 2 2 2 0 0 0
            === CAN ===
            Messages queued 1217061, send timeouts 2738195, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
            M98 P"config.g"
            M98 P"config.g"
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled```
            Config
            ; generated by RepRapFirmware Configuration Tool v3.2.0 on Wed Jan 06 2021 20:53:06 GMT-0500 (Eastern Standard Time)
            G90                                          ; send absolute coordinates...
            M83                                          ; ...but relative extruder moves
            M550 P"Gigabot"                           ; set printer name
            M552 P0.0.0.0 S1                             ; enable network and acquire dynamic address via DHCP
            M586 P0 S1                                   ; enable HTTP
            M586 P1 S0                                   ; disable FTP
            M586 P2 S0                                   ; disable Telnet
            M569 P0.0 S1                                 ; physical drive 0.0 goes forwards
            M569 P0.1 S0                                 ; physical drive 0.1 goes backwards
            M569 P0.2 S1                                 ; physical drive 0.2 goes forwards
            M569 P0.3 S1                                 ; physical drive 0.3 goes forwards
            M569 P0.4 S1                                 ; physical drive 0.4 goes forwards
            M584 X0.0 Y0.1 Z0.2:0.4 E0.3                 ; set drive mapping
            M671 X-109:707 Y300:300 S2.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X CHANGE AFTER FIGURE OUT POSITION OF BL ON MOUNT/limits
            M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
            M92 X59.26 Y59.26 Z2015.50 E393.46        ; set steps per mm
            ;M566 X900.00 Y900.00 Z60.00 E120           ; set maximum instantaneous speed changes (mm/min) WAS 120
            ;M203 X6000.00 Y6000.00 Z180.00 E7000.00      ; set maximum speeds (mm/min)
            ;M201 X500.00 Y500.00 Z20.00 E3500         ; set accelerations (mm/s^2)
            M566 X600.00 Y600.00 Z12.00 E120.00                ; Set maximum instantaneous speed changes (mm/min)
            M203 X18000.00 Y18000.00 Z180.00 E15000.00          ; Set maximum speeds (mm/min) this allows 585 mm3 max flow rate
            M201 X3000.00 Y3000.00 Z20.00 E10000.00            ; Set accelerations (mm/s^2)
            M906 X950 Y1900 Z950:950 E950 I30                ; set motor currents (mA) and motor idle factor in per cent
            M84 S30                                      ; Set idle timeout
            M208 X0 Y0 Z0 S1                             ; set axis minima
            M208 X607 Y603 Z578.5 S0                       ; set axis maxima
            M208 X0:607 Y0:603 ; max movement allowed
            M574 X1 S1 P"!io0.in"                        ; configure active-high endstop for low end on X via pin !io0.in
            M574 Y2 S1 P"!io1.in"                        ; configure active-high endstop for high end on Y via pin !io1.in
            M950 S0 C"io7.out"                           ; create servo pin 0 for BLTouch
            M558 P9 C"^io7.in" H5 F120 T6000             ; set Z probe type to bltouch and the dive height + speeds ORIGINAL
            ;M558 P9 C"^io7.in" H3 F60 T6000 A3 R0.75 S-1 ; will probe each spot 3x then average it out
            G31 P25 X-5 Y48 Z2.5                      ; G31 P25 X-5 Y48 Z2.09 PRIOR TO MARCH 19set Z probe trigger value, offset and trigger height
            ;M557 X5:600 Y47:603 S40                     ; define mesh grid
            M557 X5:598 Y0:603 P5:7
            ;Bed heater config
            M308 S0 P"temp0" Y"thermistor" T100000 B4138 A"Heated bed"; configure sensor 0 as thermistor on pin temp0
            M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
            M307 H0 R0.418 C453.0 D4.22 S1.00 V23.9
            M307 H0 B1 S1.00                             ; enable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                      ; map heated bed to heater 0
            M143 H0 S120                                 ; set temperature limit for heater 0 to 120C
            ;Hotend heater config
            ;M308 S1 P"temp1" Y"pt1000" A"PT1000"      ; configure sensor 1 as thermocouple via CS pin spi.cs1 PT1000 code
            ;M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1 PT1000 code
            M308 S1 P"spi.cs0" Y"rtd-max31865" A"PT100"      ; configure sensor 1 as thermocouple via CS pin spi.cs1 CODE FOR PT100
            M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1 CODE FOR PT100
            ;M307 H1 R1.424 C485.5 D8.34 S1.00            ; PID SETTINGS FOR HOTEND previous one
            M307 H1 R1.558 C264.3 D6.50 S1.00
            ;M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
            M143 H1 S450                                 ; set temperature limit for heater 1 to 450C
            M950 F0 C"out7" Q500                       ; create fan 0 on pin out4 and set its frequency
            M106 P0 S0 H-1                               ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"out8" Q500                   ; create fan 1 on pin out5 and set its frequency
            M106 P1 S1 H1 T45                            ; set fan 1 value. Thermostatic control is turned on
            M563 P0 D0 H1 F0                             ; define tool 0
            G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
            G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
            T0                                           ; select first tool
            M555 P2
            homeall.g
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v3.2.0 on Wed Jan 06 2021 20:53:07 GMT-0500 (Eastern Standard Time)
            G91                    ; relative positioning
            G1 H2 Z5 F6000         ; lift Z relative to current position
            G1 H1 X-598 Y617 F4000 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 H2 X5 Y-5 F6000     ; go back a few mm
            G1 H1 X-598 Y617 F360  ; move slowly to X and Y axis endstops once more (second pass)
            G90                    ; absolute positioning
            G1 X300 Y300 F6000 ; go to first probe point
            G30             ; home Z by probing the bed
            G1 H1 Y617 F4000 ; move quickly to Y axis endstop and stop there (first pass)
            G1 H2 Y-5 F6000  ; go back a few mm
            G1 H1 Y617 F360  ; move slowly to Y axis endstop once more (second pass)
            homey.g
            ; homey.g
            ; called to home the Y axis
            G1 H2 Z-5 F6000  ; lower Z again
            homez.g
            ; homez.g
            ; called to home the Z axis
            G1 X300 Y300 F4000 ; go to first probe point
            ;G91              ; relative positioning
            ;G1 Z5 F100       ; lift Z relative to current position
            ;G90              ; absolute positioning
            beg.g
            ; bed.g
            ;M561 ; clear any bed transform
            ;G29  ; probe the bed and enable compensation
            G28 ; home
            G30 P0 X0 Y300 Z-99999 ; probe near a leadscrew, half way along Y axis
            G30 P1 X600 Y300 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
            Prusaslicer start gcode
            M572 D0 S0.025 ;hemeera pressure avance attempt
            G90 ; use absolute coordinates
            M83 ; extruder relative mode
            M104 S170 ; set extruder temp for bed leveling
            M140 S[first_layer_bed_temperature] ; set bed temp
            ;M109 R170 ; wait for bed leveling temp
            M190 S[first_layer_bed_temperature] ; wait for bed temp
            ;G28 ; home all without mesh bed level
            G32
            G29 ; mesh bed leveling
            G29 S1
            M104 S[first_layer_temperature] ; set extruder temp
            G92 E0.0
            G1 Y0 X0 F4000
            G1 Z3 F720
            M109 S[first_layer_temperature] ; wait for extruder temp
            ; intro line
            G1 X0 F1000
            G1 Z0.2 F720
            G1 X60 E38.0 F900
            G1 X130 E30.0 F700
            G92 E0.0
            Let me know if anything else would be helpful.
            o_lampeundefined Phaedruxundefined 4 Replies Last reply Reply Quote 0
            • singhm29undefined
              singhm29 @o_lampe
              @o_lampe
              Yea I figured that this could just be a minor setting I mixed up when I set things up however I did use the configurator as my base to get me started. I would not be surprised if I fudged something in that process, ive become to used to Marlin but love the hardware Duet offers just wish I could get my head around the firmware.
              Its a cartesian frame where the bed drops down as the print progresses
              X axis endstop is on the print head and homes to the minimum
              Y axis endstop is in the back left corner and homes to a maximum
              Z axis endstop is the BLtouch which homes to a minumum
              • o_lampeundefined
                o_lampe @singhm29
                I'm no expert for BLTouch. Is it the usual way to define 'io7' as in- and output?
                  Phaedrux Moderator @o_lampe
                  @o_lampe said in Very confused with Duet mesh level correction:
                  Yes that's ok. The Duet 3 has a range of generalized io ports.
                    You only need to define a single value for Z. It will be applied to all drivers assigned to that axis. It's only for multiple extruders that the values must be defined for each, since extruders are independant.
                      Just to be perfectly clear can you confirm that 0,0 is at the front left corner, -x moves to the left, +x to the right, -y to the front, +y to the back?
                        G28 ; home G30 P0 X0 Y300 Z-99999 ; probe near a leadscrew, half way along Y axis G30 P1 X600 Y300 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                        In bed.g you may want to add a G30 at the center of the bed after the sides have been probed and the tilt adjusted, because the act of changing the tilt can have an effect on the position of Z0. You may also want to double up on the tilt correction by adding a second pass.
                        G28 ; home
                        G90        G30 P0 X0 Y300 Z-99999 ; probe near a leadscrew, half way along Y axis        G30 P1 X600 Y300 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                          G29 ; mesh bed leveling G29 S1
                          The second G29 S1 is redundant. I don't think it would cause a problem, but once the G29 is performed the mesh is active, so no need to load the saved mesh afterwards.
                            Make those corrections and see how it goes.
                            Also keep in mind that the 2 point tilt correction is only going to correct for tilt along the X axis. You'll still need to manually level the bed to eliminate any tilt on the Y axis as much as possible for mesh compensation to be most effective.
                            Your heightmap image indicates that there is a strong downward tilt back to front. That may be the bed tilting, but it may also be the XY gantry tilting down towards the back. Check the frame for squareness.
                            • singhm29undefined
                              singhm29
                              Thanks for the feedback. All changes were made other than changing any hardware yet.
                              Confirmed movement
                              Result from G29 without running G32
                              Result from G32 followed by G29
                              Other interesting things I observed
                              -when running G29 it skips the first row because the Bltouch would end up trying to probe off the bed
                              -after this I homed to center and again set to Z=0, the distance was no longer 1 paper sheet but a much larger distance
                              In terms of bed tilt along the Y axis I'm trying to imagine how I would correct that, normally if I have a bad nozzle crash I will move down the Z axis to the lowest point turn off stepper motors and then manually move down until my bed rests on both Z axis stepper motors to equal out both sides. I feel like that would correct X axis skew and help Y axis but im not sure after that what I could change...I guess I could also verify that there is actually tilt occuring by manually leveling the bed and turning off any compensation and seeing if jogging the Z axis up and down results in a change of Z distance between the front and back?
                                Yes that would be a good test. Is that large amount of tilt at the bed, or in the gantry?
                                • singhm29undefined
                                  singhm29 @Phaedrux
                                  @phaedrux
                                  I wasn't too sure if it was the gantry or the bed so I tried correcting both.
                                  Here was my bed level before doing any changes to the physical bed.
                                  Here it was after I loosened the bed corners so that the springs were all completely loose and then I moved the gantry to rest on the steppers at the bottom of the Z axis (equalizing the Z gantry tilt from left to right and back to front). From here again I set the Z probe offset which changed from 2.5 to 3.1mm. Here is what I got from that
                                  Not particularly promising...so being humble I decided to give another go at bed leveling manually. Here is the result from that 3dfb185b-0687-45f1-9f7e-da333b3f6267-image.png
                                  Now to give some context I am not new to bed leveling manually as I have been printing since 2015 but here what was really baffling.
                                  I turned off G29, G32 and G29 S1 from my start gcode printed for a round and the first layer came out well.
                                  I turned on G29 and G32 and lo and behold with no physical changes to the bed I now had this
                                  Thinking it was possibly the presence of G29 followed by G29 S1 I turned it back on to see if that would cause an issue. Again the new bed level came out great.
                                  So I am back to a good looking bed but I have no idea how it was fixed. I'm hoping this will stick and wont be doing any physical changes. Lets see how long this lasts! Open to any thoughts but either way appreciate walking me through the possible issues.
