    Arduino as Z-Probe questions
    903
    • AdrAsundefined
      AdrAs
      I'm currently working on a project which involves an Arduino microcontroller as probe interface. Arduino is generally running on 5V. Is it possible to use it to trigger the Z_PROBE_IN pin using the Arduino? How would I go about it? And what is the Z_PROBE_MOD pin for?
      • alankilianundefined
        alankilian
        Sure you can.
        There are are couple of ways you can do it to keep the Duet safe:
        • Configure the Arduino output as an Open-Collector output and add a pullup resistor to 3.3 Volts.
        • Place a diode between the Arduino and Duet (Cathode towards Arduino) and add a pullup resistor to 3.3 Volts on the Duet side.
        It would probably be a good idea to add a series resistor between the two parts just to add more safety. I don't know, maybe 1,000 Ohms?
        The Z_PROBE_MOD pin is an output from the DUet tht can control a servo to deploy a BLTough for example.
        • AdrAsundefined
          AdrAs
          @alankilian said in Arduino as Z-Probe questions:
          Does that mean, I can use that pin, to ouput a servo pwm signal from the duet using the following configuration?
          M950 S0 C"zprobe.mod"  ; assign GPIO port 0 to heater3 on expansion connector, servo mode
          M280 P0 S80  ; set 80deg servo position on GPIO port 0
          Can I hook that pin up to the Arduino to read the signal issued by the M280 command?
            alankilian
            You can do that.
            Also, and maybe easier, you can just make it a PWM output and change the duty cycle of the pulses instead of reading a 1-2 millisecond high-going pulse every 20 milliseconds which is what a Servo pin will produce.
            PWM and servo functions described HERE.
              dc42 administrators @AdrAs
              @AdrAs said in Arduino as Z-Probe questions:
              Unless it's an old Duet, the Z probe input pin can tolerate up to 30V so you can connect the Arduino output to it directly.
              Whether you can use Z_PROBE_MOD to control a servo depends on which Duet you have.
              AdrAsundefined 1 Reply Last reply Reply Quote 1
              • AdrAsundefined
                AdrAs @dc42
                @dc42 I've got a Duet 2 Wifi
                What do you consider as an old Duet?
                  Duet WiFi version 1.04 has 30V tolerance on the Z probe pin. Older Duet WiFis are not.
                  On Duet WiFi the Z Mod pin is not PWM capable, so it cannot be used to drive a servo.
                  AdrAsundefined 1 Reply Last reply Reply Quote 0
                  • AdrAsundefined
                    AdrAs
                    Many thanks for that clarification! I've got a 1.02 wifi, so I guess I need to work with resistors
                    • AdrAsundefined
                      AdrAs @dc42
                      @dc42 said in Arduino as Z-Probe questions:
                      I've got a 1.02 WIFI, so I guess this means the Z probe pin can only handle 3.3V, right?
                        Yes.
                          alankilian
                          I learned some new stuff about the Duet series boards today!
                          I love days like this.
                          • AdrAsundefined
                            AdrAs
                            That's great. And I learned, that I skip all the arduino 5V conversion stuff, and just go for an ESP module for my project 🙂 More Mhz, more memory, and free WIFI I'll never use 😄
                              alankilian
                              They also make 3.3 Volt Arduino-compatible boards if you want to stick with that.
                              (And a Trinket USB-attached Arduino, although I've had problems with trinkets before.)
                              • AdrAsundefined
                                AdrAs @alankilian
                                @alankilian Thanks, they are a bit too slow though. I need at least 16 Mhz
                                fcwiltundefined alankilianundefined 2 Replies Last reply Reply Quote 0
                                • fcwiltundefined
                                  fcwilt @AdrAs
                                  There are several Arduino boards that use 3.3 volts and have 16 MHz or better clock speeds.
                                  I was looking at one the other day that had 1M of program memory, 256KB of ram and a clock speed of 64MHz.
                                    alankilian @AdrAs
                                    There are SOME of Arduino-compatible 3.3 Volt boards that run fast available.
                                    • AdrAsundefined
                                      AdrAs @alankilian
                                      @alankilian Thanks for the list. However I couldn't find anything which is small, running on 3.3v and has >16 mhz. Nevermind though, The ESP should arrive today and suits all my needs for now.
                                      • fcwiltundefined
                                        fcwilt @AdrAs
                                        Did you see this one:
                                        nano-33-ble
                                        No WiFi but even smaller than the ESP and runs at a respectable 64 MHz.
                                        • zaptaundefined
                                          zapta
                                          For 3.3v Arcuino the SMT32 blue/blackpill are a good choice. Inexpensive, good documentation, support hardware debugger, support the Arduino framework, have USB C connector (e.g. for serial output), have a builtin DFU bootloader (for dongle-less field programming), and are compatible with platformio (great dev experience).
                                          E.g.
                                          https://www.amazon.com/Aideepen-Programming-Emulator-Downloader-STM32F103C8T6/dp/B07WRL3DF8
                                          https://www.aliexpress.com/item/4001049840288.html
                                          • AdrAsundefined
                                            AdrAs
                                            @fcwilt @zapta
                                            Thank you guys, both look awesome.
