    Arduino as Z-Probe questions
    958
    • AdrAsundefined
      AdrAs
      Many thanks for that clarification! I've got a 1.02 wifi, so I guess I need to work with resistors
      • AdrAsundefined
        AdrAs @dc42
        @dc42 said in Arduino as Z-Probe questions:
        Duet WiFi version 1.04 has 30V tolerance on the Z probe pin. Older Duet WiFis are not.
        I've got a 1.02 WIFI, so I guess this means the Z probe pin can only handle 3.3V, right?
          dc42 administrators @AdrAs
          @AdrAs said in Arduino as Z-Probe questions:
          Yes.
          • alankilianundefined
            alankilian
            I learned some new stuff about the Duet series boards today!
            I love days like this.
            • AdrAsundefined
              AdrAs
              That's great. And I learned, that I skip all the arduino 5V conversion stuff, and just go for an ESP module for my project 🙂 More Mhz, more memory, and free WIFI I'll never use 😄
                alankilian
                They also make 3.3 Volt Arduino-compatible boards if you want to stick with that.
                (And a Trinket USB-attached Arduino, although I've had problems with trinkets before.)
                AdrAsundefined 1 Reply Last reply Reply Quote 0
                • AdrAsundefined
                  AdrAs @alankilian
                  @alankilian Thanks, they are a bit too slow though. I need at least 16 Mhz
                  fcwiltundefined alankilianundefined 2 Replies Last reply Reply Quote 0
                  • fcwiltundefined
                    fcwilt @AdrAs
                    There are several Arduino boards that use 3.3 volts and have 16 MHz or better clock speeds.
                    I was looking at one the other day that had 1M of program memory, 256KB of ram and a clock speed of 64MHz.
                      alankilian @AdrAs
                      There are SOME of Arduino-compatible 3.3 Volt boards that run fast available.
                      • AdrAsundefined
                        AdrAs @alankilian
                        @alankilian Thanks for the list. However I couldn't find anything which is small, running on 3.3v and has >16 mhz. Nevermind though, The ESP should arrive today and suits all my needs for now.
                        • fcwiltundefined
                          fcwilt @AdrAs
                          Did you see this one:
                          nano-33-ble
                          No WiFi but even smaller than the ESP and runs at a respectable 64 MHz.
                          • zaptaundefined
                            zapta
                            For 3.3v Arcuino the SMT32 blue/blackpill are a good choice. Inexpensive, good documentation, support hardware debugger, support the Arduino framework, have USB C connector (e.g. for serial output), have a builtin DFU bootloader (for dongle-less field programming), and are compatible with platformio (great dev experience).
                            E.g.
                            https://www.amazon.com/Aideepen-Programming-Emulator-Downloader-STM32F103C8T6/dp/B07WRL3DF8
                            https://www.aliexpress.com/item/4001049840288.html
                            • AdrAsundefined
                              AdrAs
                              @fcwilt @zapta
                              Thank you guys, both look awesome.
                              • AdrAsundefined
                                AdrAs
                                @dc42 I've got another question I hope you can help me.
                                • When are the deployprobe and retractprobe macros executed? Only when a BLTouch is connected, or for the other probe types as well?
                                  For BLTouch they are executed before and after every probing move. For other probe types, when running G29 S0 they are executed at the start and the end of the entire probing operation. They are also executed when you run M401 and M402.
                                  • AdrAsundefined
                                    AdrAs
                                    Ok, thank you very much!
