    Arduino as Z-Probe questions
    958
    • alankilianundefined
      alankilian
      You can do that.
      Also, and maybe easier, you can just make it a PWM output and change the duty cycle of the pulses instead of reading a 1-2 millisecond high-going pulse every 20 milliseconds which is what a Servo pin will produce.
      PWM and servo functions described HERE.
        dc42 administrators @AdrAs
        @AdrAs said in Arduino as Z-Probe questions:
        I'm currently working on a project which involves an Arduino microcontroller as probe interface. Arduino is generally running on 5V. Is it possible to use it to trigger the Z_PROBE_IN pin using the Arduino? How would I go about it? And what is the Z_PROBE_MOD pin for?
        Unless it's an old Duet, the Z probe input pin can tolerate up to 30V so you can connect the Arduino output to it directly.
        Whether you can use Z_PROBE_MOD to control a servo depends on which Duet you have.
        AdrAsundefined 1 Reply Last reply Reply Quote 1
        • AdrAsundefined
          AdrAs @dc42
          @dc42 I've got a Duet 2 Wifi
          What do you consider as an old Duet?
            Duet WiFi version 1.04 has 30V tolerance on the Z probe pin. Older Duet WiFis are not.
            On Duet WiFi the Z Mod pin is not PWM capable, so it cannot be used to drive a servo.
            AdrAsundefined 1 Reply Last reply Reply Quote 0
            • AdrAsundefined
              AdrAs
              Many thanks for that clarification! I've got a 1.02 wifi, so I guess I need to work with resistors
              • AdrAsundefined
                AdrAs @dc42
                @dc42 said in Arduino as Z-Probe questions:
                I've got a 1.02 WIFI, so I guess this means the Z probe pin can only handle 3.3V, right?
                  Yes.
                    alankilian
                    I learned some new stuff about the Duet series boards today!
                    I love days like this.
                    • AdrAsundefined
                      AdrAs
                      That's great. And I learned, that I skip all the arduino 5V conversion stuff, and just go for an ESP module for my project 🙂 More Mhz, more memory, and free WIFI I'll never use 😄
                        alankilian
                        They also make 3.3 Volt Arduino-compatible boards if you want to stick with that.
                        (And a Trinket USB-attached Arduino, although I've had problems with trinkets before.)
                        • AdrAsundefined
                          AdrAs @alankilian
                          @alankilian Thanks, they are a bit too slow though. I need at least 16 Mhz
                          fcwiltundefined alankilianundefined 2 Replies Last reply Reply Quote 0
                          • fcwiltundefined
                            fcwilt @AdrAs
                            There are several Arduino boards that use 3.3 volts and have 16 MHz or better clock speeds.
                            I was looking at one the other day that had 1M of program memory, 256KB of ram and a clock speed of 64MHz.
                              alankilian @AdrAs
                              There are SOME of Arduino-compatible 3.3 Volt boards that run fast available.
                              • AdrAsundefined
                                AdrAs @alankilian
                                @alankilian Thanks for the list. However I couldn't find anything which is small, running on 3.3v and has >16 mhz. Nevermind though, The ESP should arrive today and suits all my needs for now.
                                • fcwiltundefined
                                  fcwilt @AdrAs
                                  Did you see this one:
                                  nano-33-ble
                                  No WiFi but even smaller than the ESP and runs at a respectable 64 MHz.
                                  • zaptaundefined
                                    zapta
                                    For 3.3v Arcuino the SMT32 blue/blackpill are a good choice. Inexpensive, good documentation, support hardware debugger, support the Arduino framework, have USB C connector (e.g. for serial output), have a builtin DFU bootloader (for dongle-less field programming), and are compatible with platformio (great dev experience).
                                    E.g.
                                    https://www.amazon.com/Aideepen-Programming-Emulator-Downloader-STM32F103C8T6/dp/B07WRL3DF8
                                    https://www.aliexpress.com/item/4001049840288.html
                                    • AdrAsundefined
                                      AdrAs
                                      @fcwilt @zapta
                                      Thank you guys, both look awesome.
                                      • AdrAsundefined
                                        AdrAs
                                        @dc42 I've got another question I hope you can help me.
                                        • When are the deployprobe and retractprobe macros executed? Only when a BLTouch is connected, or for the other probe types as well?
                                          For BLTouch they are executed before and after every probing move. For other probe types, when running G29 S0 they are executed at the start and the end of the entire probing operation. They are also executed when you run M401 and M402.
                                          • AdrAsundefined
                                            AdrAs
                                            Ok, thank you very much!
