    Missing Steps - Cant Print SpreadCycle StealthChop tuning help
    286
    32.1k
      dc42 administrators @oc_geek
      All those of you having this problem and running firmware 3.3beta2, please upgrade to the firmware build at https://www.dropbox.com/sh/0mwfe22wepk5efh/AAB6Lp0rwBPjVK2R4SxbKhLya?dl=0. If the problem continues when running this firmware, please post M122 logs as before.
      If you are not yet running 3.3beta2 but you are happy to run it, please upgrade to 3.3beta2 first (from the unstable package feed if running with SBC, or from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.3beta2 if running standalone), then upgrade the main board firmware to the version in the above link.
      carcamerarigundefined 3 Replies Last reply Reply Quote 1
      • carcamerarigundefined
        carcamerarig @dc42
        @dc42 On it now, thanks and ill report back. Whats the map file for?
          carcamerarig @dc42
          Pre print
          m122
          RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+2 (2021-04-13 18:55:38) running on Duet 3 Mini5plus WiFi (standalone mode)
          Board ID: Z9NZN-A296U-D65J0-40KM4-LY03Z-ZPQPD
          Used output buffers: 3 of 40 (18 max)
          Static ram: 100040
          Dynamic ram: 106532 of which 0 recycled
          Never used RAM 34276, free system stack 112 words
          Tasks: NETWORK(ready,222) HEAT(notifyWait,314) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,332) TMC(notifyWait,99) MAIN(running,335) IDLE(ready,20) AIN(notifyWait,266)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:01:56 ago, cause: software
          Last software reset at 2021-04-08 23:50, reason: User, GCodes spinning, available RAM 34628, slot 2
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00446000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          Aux1 errors 0,0,0
          MCU revision 3, ADC conversions started 138432, completed 138431, timed out 0, errs 0
          Supply voltage: min 23.8, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/662/662, gc cycles 1
          Driver 0: position 39400, standstill, SG min/max 150/502, read errors 0, write errors 1, ifcnt 34, reads 6815, writes 14, timeouts 0, DMA errors 0
          Driver 1: position 19000, standstill, SG min/max 42/402, read errors 0, write errors 1, ifcnt 34, reads 6815, writes 14, timeouts 0, DMA errors 0
          Driver 2: position 20000, standstill, SG min/max 114/496, read errors 0, write errors 1, ifcnt 32, reads 6815, writes 13, timeouts 0, DMA errors 0
          Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 22, reads 6818, writes 10, timeouts 0, DMA errors 0
          Driver 4: position 0, standstill, SG min/max 54/280, read errors 0, write errors 1, ifcnt 32, reads 6816, writes 13, timeouts 0, DMA errors 0
          Driver 5: position 0, assumed not present
          Driver 6: position 0, assumed not present
          Date/time: 2021-04-13 19:28:15
          Cache data hit count 198108627
          Slowest loop: 5.51ms; fastest: 0.07ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 1.5ms, write time 0.0ms, max retries 0
          DMs created 83, maxWait 47069ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 42, completed moves 42, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
          === AuxDDARing ===
          Bed heaters = 0 -1, chamberHeaters = -1 -1
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty.
          === Filament sensors ===
          Extruder 0 sensor: ok
          === CAN ===
          Messages queued 1063, send timeouts 1059, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 16)
          Last cancelled message type 30 dest 127
          === Network ===
          Slowest loop: 10.12ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          - WiFi -
          Network state is active
          WiFi firmware version 1.25beta0
          WiFi MAC address f4:cf:a2:6f:e9:78
          WiFi Vcc 3.36, reset reason Power up
          WiFi flash size 2097152, free heap 25016
          WiFi IP address 192.168.1.226
          WiFi signal strength -42dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00002002
          1st move from purge bang
          m122
          Used output buffers: 3 of 40 (26 max)
          Static ram: 100040
          Dynamic ram: 106532 of which 176 recycled
          Never used RAM 34100, free system stack 112 words
          Tasks: NETWORK(ready,222) HEAT(delaying,300) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(notifyWait,332) TMC(notifyWait,99) MAIN(running,335) IDLE(ready,20) AIN(notifyWait,266)
          Last reset 00:05:40 ago, cause: software
          Error status: 0x00
          Aux0 errors 0,0,0
          Aux1 errors 0,0,0
          MCU revision 3, ADC conversions started 402873, completed 402872, timed out 0, errs 0
          Supply voltage: min 23.5, current 23.6, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/1964/1934, gc cycles 3
          Driver 0: position 30573, ok, SG min/max 0/396, read errors 0, write errors 0, ifcnt 40, reads 13009, writes 6, timeouts 0, DMA errors 0
          Driver 1: position 21158, ok, SG min/max 2/466, read errors 0, write errors 0, ifcnt 40, reads 13009, writes 6, timeouts 0, DMA errors 0
          Driver 2: position 108, standstill, SG min/max 0/278, read errors 0, write errors 0, ifcnt 37, reads 13011, writes 5, timeouts 0, DMA errors 0
          Driver 3: position 0, ok, SG min/max 0/340, read errors 0, write errors 0, ifcnt 24, reads 13013, writes 2, timeouts 0, DMA errors 0
          Driver 4: position 0, standstill, SG min/max 0/284, read errors 0, write errors 0, ifcnt 37, reads 13010, writes 5, timeouts 0, DMA errors 0
          Date/time: 2021-04-13 19:31:59
          Cache data hit count 533316832
          Slowest loop: 115.81ms; fastest: 0.09ms
          === Storage ===
          Free file entries: 9
          SD card longest read time 1.3ms, write time 0.0ms, max retries 0
          DMs created 83, maxWait 145636ms, bed compensation in use: mesh, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 297, completed moves 275, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 1, 0], CDDA state 3
          === AuxDDARing ===
          Heater 0 is on, I-accum = 0.6
          Heater 1 is on, I-accum = 0.4
          Segments left: 1
          File is doing "G1 X184.099 Y93.163 E0.43669" in state(s) 0
          === CAN ===
          Messages queued 2021, send timeouts 2021, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
          Last cancelled message type 4514 dest 127
          === Network ===
          Slowest loop: 200.83ms; fastest: 0.08ms
          - WiFi -
          Failed messages: pending 0, notready 0, noresp 1
          WiFi flash size 2097152, free heap 26592
          WiFi signal strength -43dBm, mode 802.11n, reconnections 0, sleep mode modem
          Travel bang 2
          m122
          Used output buffers: 3 of 40 (27 max)
          Static ram: 100040
          Tasks: NETWORK(ready,222) HEAT(notifyWait,298) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,332) TMC(notifyWait,99) MAIN(running,335) IDLE(ready,20) AIN(notifyWait,266)
          Last reset 00:09:34 ago, cause: software
          Error status: 0x00
          Aux0 errors 0,0,0
          Aux1 errors 0,0,0
          MCU revision 3, ADC conversions started 668004, completed 668003, timed out 0, errs 0
          Supply voltage: min 23.4, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/1556/1502, gc cycles 6
          Driver 0: position 21006, ok, SG min/max 0/466, read errors 0, write errors 0, ifcnt 40, reads 12887, writes 0, timeouts 0, DMA errors 0
          Driver 1: position 20378, ok, SG min/max 0/440, read errors 0, write errors 0, ifcnt 40, reads 12887, writes 0, timeouts 0, DMA errors 0
          Driver 2: position 122, standstill, SG min/max 0/4, read errors 0, write errors 0, ifcnt 37, reads 12886, writes 0, timeouts 0, DMA errors 0
          Driver 3: position 0, ok, SG min/max 0/490, read errors 0, write errors 0, ifcnt 24, reads 12887, writes 0, timeouts 0, DMA errors 0
          Driver 4: position 0, standstill, SG min/max 0/8, read errors 0, write errors 0, ifcnt 37, reads 12887, writes 0, timeouts 0, DMA errors 0
          Date/time: 2021-04-13 19:35:54
          Cache data hit count 824357935
          Slowest loop: 99.51ms; fastest: 0.09ms
          === Storage ===
          SD card longest read time 46.6ms, write time 0.0ms, max retries 0
          DMs created 83, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 607, completed moves 600, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 10, 0], CDDA state 3
          === AuxDDARing ===
          Heater 0 is on, I-accum = 0.4
          Segments left: 1
          File is doing "G1 X91.220 Y90.225 E0.61454" in state(s) 0
          === CAN ===
          Messages queued 2109, send timeouts 2109, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
          === Network ===
          Slowest loop: 201.84ms; fastest: 0.08ms
          - WiFi -
          Failed messages: pending 0, notready 0, noresp 2
          WiFi signal strength -45dBm, mode 802.11n, reconnections 0, sleep mode modem
          Layer 4 solid infill bang
          m122
          Static ram: 100040
          Last reset 00:19:56 ago, cause: software
          Error status: 0x00
          Aux0 errors 0,0,0
          Aux1 errors 0,0,0
          MCU revision 3, ADC conversions started 1383243, completed 1383242, timed out 0, errs 0
          Supply voltage: min 23.4, current 23.8, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/476/422, gc cycles 14
          Driver 0: position 12223, ok, SG min/max 0/508, read errors 0, write errors 0, ifcnt 40, reads 35114, writes 0, timeouts 0, DMA errors 0
          Driver 1: position 23768, ok, SG min/max 0/490, read errors 0, write errors 0, ifcnt 40, reads 35114, writes 0, timeouts 0, DMA errors 0
          Driver 2: position 338, ok, SG min/max 0/218, read errors 0, write errors 0, ifcnt 37, reads 35114, writes 0, timeouts 0, DMA errors 0
          Driver 3: position 0, ok, SG min/max 0/500, read errors 0, write errors 0, ifcnt 24, reads 35114, writes 0, timeouts 0, DMA errors 0
          Driver 4: position 0, ok, SG min/max 0/264, read errors 0, write errors 0, ifcnt 37, reads 35114, writes 0, timeouts 0, DMA errors 0
          Date/time: 2021-04-13 19:46:15
          Cache data hit count 1699858608
          Slowest loop: 93.01ms; fastest: 0.09ms
          === Storage ===
          SD card longest read time 85.2ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          Scheduled moves 3320, completed moves 3311, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 86, 0], CDDA state 3
          === AuxDDARing ===
          Heater 0 is on, I-accum = 0.5
          Heater 1 is on, I-accum = 0.7
          Segments left: 1
          File is doing "G1 X61.113 Y115.954 E1.24148" in state(s) 0
          === CAN ===
          Messages queued 5596, send timeouts 5596, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
          === Network ===
          Slowest loop: 199.63ms; fastest: 0.08ms
          - WiFi -
          Failed messages: pending 0, notready 0, noresp 3
          WiFi signal strength -44dBm, mode 802.11n, reconnections 0, sleep mode modem
            carcamerarig @dc42
            g15% infill mini bangs (after cancel)
            m122
            Used output buffers: 4 of 40 (27 max)
            Static ram: 100040
            Tasks: NETWORK(ready,220) HEAT(delaying,298) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,332) TMC(notifyWait,99) MAIN(running,335) IDLE(ready,20) AIN(notifyWait,266)
            Last reset 00:22:44 ago, cause: software
            Error status: 0x00
            Aux0 errors 0,0,0
            Aux1 errors 0,0,0
            MCU revision 3, ADC conversions started 1578534, completed 1578533, timed out 0, errs 0
            Supply voltage: min 23.4, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/480/480, gc cycles 16
            Driver 0: position 2000, standstill, SG min/max 0/492, read errors 0, write errors 0, ifcnt 41, reads 9590, writes 1, timeouts 0, DMA errors 0
            Driver 1: position 0, standstill, SG min/max 0/466, read errors 0, write errors 0, ifcnt 41, reads 9590, writes 1, timeouts 0, DMA errors 0
            Driver 2: position 4510, standstill, SG min/max 0/302, read errors 0, write errors 0, ifcnt 38, reads 9591, writes 1, timeouts 0, DMA errors 0
            Driver 3: position 0, standstill, SG min/max 2/506, read errors 0, write errors 0, ifcnt 25, reads 9591, writes 1, timeouts 0, DMA errors 0
            Driver 4: position 0, standstill, SG min/max 0/176, read errors 0, write errors 0, ifcnt 38, reads 9590, writes 1, timeouts 0, DMA errors 0
            Date/time: 2021-04-13 19:49:03
            Cache data hit count 1952316320
            Slowest loop: 111.22ms; fastest: 0.07ms
            === Storage ===
            SD card longest read time 30.4ms, write time 5.0ms, max retries 0
            === MainDDARing ===
            Scheduled moves 6966, completed moves 6966, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 82, 0], CDDA state -1
            === AuxDDARing ===
            Heater 1 is on, I-accum = 0.6
            Segments left: 0
            === CAN ===
            Messages queued 1512, send timeouts 1512, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
            === Network ===
            Slowest loop: 199.57ms; fastest: 0.08ms
            - WiFi -
            Failed messages: pending 0, notready 0, noresp 4
            M569 P0.0
            Drive 0 runs in reverse, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 0 (inf mm/sec), pwmScaleSum 10, pwmScaleAuto 3, pwmOfsAuto 255, pwmGradAuto 49, pos 4
            M569 P0.1
            Drive 1 runs in reverse, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 0 (inf mm/sec), pwmScaleSum 15, pwmScaleAuto 8, pwmOfsAuto 255, pwmGradAuto 44, pos 644
            G90                                         ; Send absolute coordinates...
            M83                                         ; ...but relative extruder moves
            M550 P"Duet Caribou 420"                        	; Set machine name
            M552 S1                                     	; Enable network
            ;M586 P0 S1                                  ; Enable HTTP
            ;M586 P1 S0                                  ; Disable FTP
            ;M586 P2 S0                                  ; Disable Telnet
            M575 P1 S1 B57600							; Panel Due
            ; Drive Mappings
            M569 P0.0 S0 V0                             ; Drive 0: X Axis
            M569 P0.1 S0 V0                             ; Drive 1: Y Axis
            M569 P0.2 S0 V0                             ; Drive 2:  Z Axis
            M569 P0.3 S0 V0                             ; Drive 3: E Axis
            M569 P0.4 S0 V0                             ; Drive 4: E1 used for Z1
            ; Motor remapping for dual Z and axis Limits
            M584 X0 Y1 Z2:4 E3				; two Z motors connected to driver outputs Z and E1
            M671 X-37:287 Y0:0 S4			; leadscrews at left (connected to Z) and right (connected to E1) of X axis
            ; Micrpstepping and Speed
            M350 X32 Y32 E16 Z16 I1                     ; Configure microstepping with interpolation
            M92 X200.00 Y200.00 Z400.00 E830.00         ; Set steps per mm
            ; Speeds, Acceleration and Jerk
            M566 X900 Y900 Z25.00 E600.00 P1      ; Set maximum instantaneous speed changes (mm/min)
            M203 X7500.00 Y7500.00 Z720.00 E1200.00     ; Set maximum speeds (mm/min)
            M201 X1500.00 Y1500.00 Z1200.00 E4000.00     ; Set accelerations (mm/s^2)
            ; Motor currents
            M906 X700.00 Y700.00 Z700.00 E700.00 I20    ; Set motor currents (mA) and motor idle factor in percent X,Y,Z=1000/1.414 E=1400/1.414
            M84 S30                                     ; Set idle timeout
            ; Printer geometry
            M208 X0:250 Y-4:215 Z-0.5:410               ; Axis Limits
            M564 H0							            ; allow unhomed movement
            ; Endstops for each Axis
            M574 X1 S3								 	; Set endstops controlled by motor load detection
            M574 Y1 S3                               	; Set endstops controlled by motor load detection
            ; Stallgaurd Sensitivy
            M915 X S-2 F0 H200 R0		                ; Set X axis Sensitivity
            M915 Y S-1 F0 H200 R0		                ; Set y axis Sensitivity
            ; Input Shaper
            ;M593 F58.5 P4 S0.2  ; Input Shaping 3.3/3.4
            ;M593 F54.26
            ; Z-Probe Super PINDA
            M574 Z1 S2														; Set endstops controlled by probe
            M558 P5 C"^io3.in" I1 H1 F500 T4800 A30 S0.004
            ; Mesh Grid
            M557 X24:221 Y10:195 P8	                         ; Define mesh grid for probing
            ; Sheets
            ;G31 P1000 X23 Y5 Z1.730 	                    ; Satin Sheet
            G31 P1000 X23 Y5 Z1.91 	  	                  ; Textured Sheet
            ;G31 P1000 X23 Y5 Z1.445 					    ; PEI Sheet
            ;G31 P1000 X23 Y5 Z1.445 					    ; PEI Sheet 0.6 nozzle -10 offset
            ; Heatbed Heaters and Thermistor Bed
            M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.060000e-8       ; Set thermistor + ADC parameters for heater 0 Bed
            M950 H0 C"out0" T0 Q10					                        ; Creates Bed Heater Qnn PWM frequency in Hz. Valid range: 0-65535, default: 500. (optional) 10hz stopped clicking
            M307 H0 R0.273 C345.3 D10.89 S1.00 V23.8						; PID 3.2
            M140 H0										                    ; Bed uses Heater 0
            M143 H0 S120                                                    ; Set temperature limit for heater 0 to 120C Bed
            ; HotEnd Heaters and Thermistor HotEnd
            M308 S1 P"temp1" Y"thermistor" T500000 B4725 C1.19622e-7	       	; define E0 temperature sensor e3d
            M950 H1 C"out1" T1 						                            ; Create HotEnd Heater
            M307 H1 R2.383 C178.5:130.6 D5.32 S1.00 V23.9						; PID
            M143 H1 S285                                                    	; Set temperature limit for heater 1 to 285C HotEnd
            M302 S185 R185
            M950 F1 C"out5" Q250				; Creates HOTEND Fan
            M106 P1 T45 S235 H1                 ; HOTEND Fan Settings
            M950 F0 C"out6" Q100				; Creates PARTS COOLING FAN
            M106 P0 H-1                         ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off PARTS COOLING FAN
            M563 P0 D0 H1 F0                            ; Define tool 0
            G10 P0 X0 Y0 Z0                             ; Set tool 0 axis offsets
            G10 P0 R0 S0                                ; Set initial tool 0 active and standby temperatures to 0C
            ; StealthCop calibration
            M17
            G4 P150
            G1 X1 Y1 Z1
            G4 S2
            M84 ; disable motors
            ; Filament Sensor Logic
            M98 P"0:/macros/02_Functions/StartupFilamentSensorCheck"  ; Runout Sensor Logic: Startup with filament = runout sensor active   Startup without filament = autoload active
            ![Screenshot 2021-04-13 at 19.51.45.png](/assets/uploads/files/1618340118910-screenshot-2021-04-13-at-19.51.45.png)
            ![Screenshot 2021-04-13 at 19.51.39.png](/assets/uploads/files/1618340118851-screenshot-2021-04-13-at-19.51.39.png)
              droftarts administrators @carcamerarig
              @carcamerarig said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
              Helps with debugging, you can ignore it.
              carcamerarigundefined 1 Reply Last reply Reply Quote 0
                carcamerarig @droftarts
                @droftarts am I supposed to install it though?
                  dc42 administrators @carcamerarig
                  No.
                  carcamerarigundefined 1 Reply Last reply Reply Quote 1
                    carcamerarig @dc42
                    link text
                      @carcamerarig, thanks for the data.
                      The M122 report shows that there were no driver comms timeout errors this time.
                      Your M569 report shows that you are running drivers 0 and 1 in stealthChop mode with tpwmthrs set to zero, so that the drivers will never change over to spreadCycle. This means that you will get issues above some speed threshold. So the travel bang and mini bangs may just be caused by running too fast in stealthChop mode.
                      Can you try the same print in spreadCycle mode?
                        carcamerarig @dc42
                        Thanks David, so many configs now what would be your recommendation on switchover point?
                          Here are some options:
                          1. Run in stealthChop all the time, and set the maximum speed low enough that stealthChop doesn't cause any problems. My guess is that this is what the Prusa printers do when you print in silent mode. You will need to execute a good tuning procedure during homing to ensure good steathChop calibration so that it works well enough at speed. You risk getting a layer shift if the print head hits a blob or overhang, because in stealthChop mode there is little torque reserve at the higher speeds.
                          2. My preference is to set a very low speed for switching over, to get the benefit of low standstill noise without losing torque while printing. As long as microstep interpolation is enabled, the motors should be fairly quiet anyway, except at mid-band resonance speeds. The firmware default is tpwmthrs (aka M569 V parameter) = 4000, which corresponds to a speed of 4.7mm/sec on a Cartesian printer with 80 steps/mm.
                          3. If in doubt, run in spreadCycle mode (D2 parameter in the M569 command) until any motion problems have been eliminated, and only then try using stealthChop.
                          SputnikOC3dundefined 1 Reply Last reply Reply Quote 0
                          • SputnikOC3dundefined
                            SputnikOC3d @dc42
                            @dc42 - prior to the config.g file you see posted above - the OP was running with the driver set into SpreadCycle by the D parameter. He is on a prusa style bedslinger [ Caribou 3d ]
                            Stealthchop was only utilized during homing for stallguard as machine has no mechanical endstops. Its then forced into Spreadcycle. The issues is just as pervasive in Forced Spreadcycle as it is in stealthchop.
                            OP produced M112 prior to home / after home / and during print - the diag tool told us it was in spreadcycle mode before homing / in stealthchop during and immediately after homing op's / and then in Spreadcycle mode during print.
                            Not sure if we screwed something up with parameters and settings but - we couldnt find the issue.
                              dc42 administrators @SputnikOC3d
                              @sputnikoc3d said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                              Yes, I am aware that the original problem occurred when the drivers were reported as being in spreadCycle mode by M569. I would like to know whether in that same scenario, the problem still occurs using the updated firmware that I made available this evening.
                              carcamerarigundefined 3 Replies Last reply Reply Quote 0
                                carcamerarig @dc42
                                @dc42 Travel bangs and infill mini bangs still but looks like no timeouts??
                                M569 P0.1
                                Drive 1 runs in reverse, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 668
                                M569 P0.0
                                Drive 0 runs in reverse, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 252
                                13/04/2021, 22:33:34	M122
                                Static ram: 100040
                                Never used RAM 34276, free system stack 116 words
                                Tasks: NETWORK(ready,225) HEAT(delaying,314) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,332) TMC(notifyWait,99) MAIN(running,428) IDLE(ready,20) AIN(notifyWait,266)
                                Last reset 00:02:59 ago, cause: software
                                Last software reset at 2021-04-13 22:30, reason: User, GCodes spinning, available RAM 34100, slot 1
                                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                Error status: 0x00
                                Aux0 errors 0,0,0
                                Aux1 errors 0,0,0
                                MCU revision 3, ADC conversions started 214326, completed 214325, timed out 0, errs 0
                                Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/134/134, gc cycles 2
                                Driver 0: position 20800, standstill, SG min/max 2/406, read errors 0, write errors 1, ifcnt 49, reads 10555, writes 14, timeouts 0, DMA errors 0
                                Driver 1: position 20000, standstill, SG min/max 104/392, read errors 0, write errors 1, ifcnt 49, reads 10555, writes 14, timeouts 0, DMA errors 0
                                Driver 2: position 1164, standstill, SG min/max 2/304, read errors 0, write errors 1, ifcnt 46, reads 10555, writes 13, timeouts 0, DMA errors 0
                                Driver 3: position 0, standstill, SG min/max 218/218, read errors 0, write errors 1, ifcnt 35, reads 10558, writes 10, timeouts 0, DMA errors 0
                                Driver 4: position 0, standstill, SG min/max 0/268, read errors 0, write errors 1, ifcnt 46, reads 10556, writes 13, timeouts 0, DMA errors 0
                                Date/time: 2021-04-13 22:33:29
                                Cache data hit count 310421309
                                Slowest loop: 7.13ms; fastest: 0.07ms
                                === Storage ===
                                DMs created 83, maxWait 148832ms, bed compensation in use: none, comp offset 0.000
                                === MainDDARing ===
                                Scheduled moves 10, completed moves 10, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                === AuxDDARing ===
                                Segments left: 0
                                === CAN ===
                                Messages queued 1624, send timeouts 1620, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 16)
                                === Network ===
                                Slowest loop: 9.48ms; fastest: 0.00ms
                                - WiFi -
                                WiFi flash size 2097152, free heap 25096
                                WiFi signal strength -41dBm, mode 802.11n, reconnections 0, sleep mode modem
                                13/04/2021, 22:30:45	Connection established
                                13/04/2021, 22:34:15	M569 P0.0 D2
                                13/04/2021, 22:34:09	M569 P0.1 D2
                                13/04/2021, 22:39:21	m122
                                Used output buffers: 3 of 40 (30 max)
                                Static ram: 100040
                                Tasks: NETWORK(ready,225) HEAT(delaying,298) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(notifyWait,332) TMC(notifyWait,65) MAIN(running,428) IDLE(ready,20) AIN(notifyWait,266)
                                Last reset 00:08:47 ago, cause: software
                                Error status: 0x00
                                Aux0 errors 0,0,0
                                Aux1 errors 0,0,0
                                MCU revision 3, ADC conversions started 619504, completed 619503, timed out 0, errs 0
                                Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/428/374, gc cycles 6
                                Driver 0: position 16039, ok, SG min/max 0/330, read errors 0, write errors 0, ifcnt 52, reads 14822, writes 1, timeouts 0, DMA errors 0
                                Driver 1: position 22867, ok, SG min/max 0/324, read errors 0, write errors 0, ifcnt 52, reads 14822, writes 1, timeouts 0, DMA errors 0
                                Driver 2: position 86, ok, SG min/max 0/156, read errors 0, write errors 0, ifcnt 48, reads 14822, writes 1, timeouts 0, DMA errors 0
                                Driver 3: position 0, ok, SG min/max 0/486, read errors 0, write errors 0, ifcnt 37, reads 14821, writes 2, timeouts 0, DMA errors 0
                                Driver 4: position 0, ok, SG min/max 0/86, read errors 0, write errors 0, ifcnt 48, reads 14822, writes 1, timeouts 0, DMA errors 0
                                Date/time: 2021-04-13 22:39:16
                                Cache data hit count 825217284
                                Slowest loop: 108.71ms; fastest: 0.09ms
                                === Storage ===
                                SD card longest read time 98.7ms, write time 0.0ms, max retries 0
                                DMs created 83, maxWait 212274ms, bed compensation in use: mesh, comp offset 0.000
                                === MainDDARing ===
                                Scheduled moves 825, completed moves 820, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 16, 0], CDDA state 3
                                === AuxDDARing ===
                                Heater 0 is on, I-accum = 0.0
                                Segments left: 1
                                File is doing "G1 X78.581 Y114.333 E0.60317" in state(s) 0
                                === CAN ===
                                Messages queued 2353, send timeouts 2353, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                                === Network ===
                                Slowest loop: 201.51ms; fastest: 0.08ms
                                - WiFi -
                                WiFi flash size 2097152, free heap 26560
                                13/04/2021, 22:35:16	M32 "0:/gcodes/456.gcode"
                                File 0:/gcodes/456.gcode selected for printing
                                13/04/2021, 22:35:00	m122
                                Static ram: 100040
                                Tasks: NETWORK(ready,225) HEAT(delaying,314) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(notifyWait,332) TMC(notifyWait,99) MAIN(running,428) IDLE(ready,20) AIN(notifyWait,266)
                                Last reset 00:04:25 ago, cause: software
                                Error status: 0x00
                                Aux0 errors 0,0,0
                                Aux1 errors 0,0,0
                                MCU revision 3, ADC conversions started 316722, completed 316721, timed out 0, errs 0
                                Supply voltage: min 23.8, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                                Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/158/158, gc cycles 3
                                Driver 0: position 20800, standstill, SG min/max 146/146, read errors 0, write errors 0, ifcnt 51, reads 5053, writes 2, timeouts 0, DMA errors 0
                                Driver 1: position 20000, standstill, SG min/max 154/154, read errors 0, write errors 0, ifcnt 51, reads 5052, writes 2, timeouts 0, DMA errors 0
                                Driver 2: position 1164, standstill, SG min/max 156/156, read errors 0, write errors 0, ifcnt 47, reads 5054, writes 1, timeouts 0, DMA errors 0
                                Driver 3: position 0, standstill, SG min/max 218/218, read errors 0, write errors 0, ifcnt 35, reads 5055, writes 0, timeouts 0, DMA errors 0
                                Driver 4: position 0, standstill, SG min/max 52/52, read errors 0, write errors 0, ifcnt 47, reads 5053, writes 1, timeouts 0, DMA errors 0
                                Date/time: 2021-04-13 22:34:55
                                Cache data hit count 459975350
                                Slowest loop: 9.14ms; fastest: 0.13ms
                                === Storage ===
                                SD card longest read time 0.9ms, write time 5.1ms, max retries 0
                                === MainDDARing ===
                                === AuxDDARing ===
                                Segments left: 0
                                === CAN ===
                                Messages queued 773, send timeouts 773, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                                === Network ===
                                Slowest loop: 199.88ms; fastest: 0.08ms
                                - WiFi -
                                WiFi flash size 2097152, free heap 21944
                                  carcamerarig @dc42
                                  13/04/2021, 22:42:45	m122
                                  Static ram: 100040
                                  Tasks: NETWORK(ready,220) HEAT(delaying,298) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(notifyWait,332) TMC(notifyWait,65) MAIN(running,428) IDLE(ready,20) AIN(notifyWait,266)
                                  Last reset 00:12:11 ago, cause: software
                                  Error status: 0x00
                                  Aux0 errors 0,0,0
                                  Aux1 errors 0,0,0
                                  MCU revision 3, ADC conversions started 850815, completed 850814, timed out 0, errs 0
                                  Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/1316/1262, gc cycles 8
                                  Driver 0: position 17212, ok, SG min/max 0/348, read errors 0, write errors 0, ifcnt 52, reads 11257, writes 0, timeouts 0, DMA errors 0
                                  Driver 1: position 18596, ok, SG min/max 0/230, read errors 0, write errors 0, ifcnt 52, reads 11258, writes 0, timeouts 0, DMA errors 0
                                  Driver 2: position 438, ok, SG min/max 0/224, read errors 0, write errors 0, ifcnt 48, reads 11258, writes 0, timeouts 0, DMA errors 0
                                  Driver 3: position 0, ok, SG min/max 0/430, read errors 0, write errors 0, ifcnt 37, reads 11257, writes 0, timeouts 0, DMA errors 0
                                  Driver 4: position 0, ok, SG min/max 0/258, read errors 0, write errors 0, ifcnt 48, reads 11258, writes 0, timeouts 0, DMA errors 0
                                  Date/time: 2021-04-13 22:42:40
                                  Cache data hit count 1084782186
                                  Slowest loop: 97.18ms; fastest: 0.09ms
                                  === Storage ===
                                  SD card longest read time 96.3ms, write time 0.0ms, max retries 0
                                  === MainDDARing ===
                                  Scheduled moves 4801, completed moves 4795, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 71, 0], CDDA state 3
                                  === AuxDDARing ===
                                  Heater 0 is on, I-accum = 0.3
                                  Segments left: 1
                                  File is doing "G1 F2700.000" in state(s) 0
                                  === CAN ===
                                  Messages queued 1836, send timeouts 1836, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                                  === Network ===
                                  Slowest loop: 200.57ms; fastest: 0.08ms
                                  - WiFi -
                                  13/04/2021, 22:43:02	m122
                                  Static ram: 100040
                                  Tasks: NETWORK(ready,220) HEAT(delaying,298) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,332) TMC(notifyWait,65) MAIN(running,428) IDLE(ready,20) AIN(notifyWait,266)
                                  Last reset 00:12:27 ago, cause: software
                                  Error status: 0x00
                                  Aux0 errors 0,0,0
                                  Aux1 errors 0,0,0
                                  MCU revision 3, ADC conversions started 869712, completed 869711, timed out 0, errs 0
                                  Supply voltage: min 23.4, current 23.5, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                                  Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/1700/1646, gc cycles 8
                                  Driver 0: position 34544, ok, SG min/max 0/324, read errors 0, write errors 0, ifcnt 52, reads 920, writes 0, timeouts 0, DMA errors 0
                                  Driver 1: position 19084, ok, SG min/max 0/316, read errors 0, write errors 0, ifcnt 52, reads 919, writes 0, timeouts 0, DMA errors 0
                                  Driver 2: position 505, standstill, SG min/max 0/186, read errors 0, write errors 0, ifcnt 48, reads 919, writes 0, timeouts 0, DMA errors 0
                                  Driver 3: position 0, ok, SG min/max 2/416, read errors 0, write errors 0, ifcnt 37, reads 920, writes 0, timeouts 0, DMA errors 0
                                  Driver 4: position 0, standstill, SG min/max 0/116, read errors 0, write errors 0, ifcnt 48, reads 920, writes 0, timeouts 0, DMA errors 0
                                  Date/time: 2021-04-13 22:42:57
                                  Cache data hit count 1105969862
                                  Slowest loop: 92.88ms; fastest: 0.09ms
                                  === Storage ===
                                  SD card longest read time 0.7ms, write time 0.0ms, max retries 0
                                  === MainDDARing ===
                                  Scheduled moves 5253, completed moves 5214, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 9, 0], CDDA state 3
                                  === AuxDDARing ===
                                  Segments left: 1
                                  File is doing "G1 X185.377 Y115.273 E0.03611" in state(s) 0
                                  === CAN ===
                                  Messages queued 150, send timeouts 150, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                                  === Network ===
                                  Slowest loop: 202.17ms; fastest: 0.09ms
                                  - WiFi -
                                  M0 H1
                                  Cancelled printing file 0:/gcodes/456.gcode, print time was 0h 8m
                                  Error: Bad command: called when a print is cancelled after a pause.
                                  13/04/2021, 22:43:29	Printing paused at X62.7 Y116.3 Z1.2
                                  13/04/2021, 22:43:26	M25
                                  Resume state saved
                                  13/04/2021, 22:43:19	m122
                                  Static ram: 100040
                                  Tasks: NETWORK(ready,212) HEAT(delaying,298) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,332) TMC(notifyWait,65) MAIN(running,428) IDLE(ready,20) AIN(notifyWait,266)
                                  Last reset 00:12:44 ago, cause: software
                                  Error status: 0x00
                                  Aux0 errors 0,0,0
                                  Aux1 errors 0,0,0
                                  MCU revision 3, ADC conversions started 889003, completed 889002, timed out 0, errs 0
                                  Supply voltage: min 23.5, current 23.5, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                  Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/116/62, gc cycles 9
                                  Driver 0: position 17212, ok, SG min/max 0/326, read errors 0, write errors 0, ifcnt 52, reads 939, writes 0, timeouts 0, DMA errors 0
                                  Driver 1: position 23018, ok, SG min/max 0/14, read errors 0, write errors 0, ifcnt 52, reads 940, writes 0, timeouts 0, DMA errors 0
                                  Driver 2: position 493, ok, SG min/max 0/14, read errors 0, write errors 0, ifcnt 48, reads 940, writes 0, timeouts 0, DMA errors 0
                                  Driver 3: position 0, ok, SG min/max 14/470, read errors 0, write errors 0, ifcnt 37, reads 939, writes 0, timeouts 0, DMA errors 0
                                  Driver 4: position 0, ok, SG min/max 0/8, read errors 0, write errors 0, ifcnt 48, reads 939, writes 0, timeouts 0, DMA errors 0
                                  Date/time: 2021-04-13 22:43:14
                                  Cache data hit count 1127617842
                                  Slowest loop: 93.12ms; fastest: 0.09ms
                                  === Storage ===
                                  SD card longest read time 91.6ms, write time 0.0ms, max retries 0
                                  === MainDDARing ===
                                  Scheduled moves 5978, completed moves 5972, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 11, 0], CDDA state 3
                                  === AuxDDARing ===
                                  Segments left: 1
                                  File is doing "G1 X86.466 Y92.573 E0.75422" in state(s) 0
                                  === CAN ===
                                  Messages queued 153, send timeouts 153, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                                  === Network ===
                                  Slowest loop: 281.40ms; fastest: 0.08ms
                                  - WiFi -
                                    carcamerarig @dc42
                                    Sorry that was Home in stealthchop M569 P0.0 S0 V0 M569 P0.1 S0 V0.
                                    Send M569 P0.0 D2, M569 P0.1 D2 for the print after homing.
                                    M122 after each incident and M569 P0.0 / 0.1 to confirm spreadcycle.
                                      @carcamerarig, please can you post the results of M569 P0 and M569 P1 next time as well the M122 report, to confirm the driver parameters.
                                        carcamerarig @dc42
                                        @dc42 top of the 1st of the 2 report posts??
                                          Ah I see them now. What were the "incidents" ?
                                            carcamerarig @dc42
                                            Travel bangs the same as before between models and mini bangs on infil 15%
                                            I’ll upload video again but it takes a while
