Delta mesh leveling not working.
I am new to duet, just installed duet 2 wifi on my flsun q5.
all is working well except when I print there is no bed mesh compensation. so my nozzle is grinding into the bed on the corners.
I have tried everything I can think of to get it working.
Ran g32 and g29 then printed and same result.
put g29 s1 in start gcode. same thing, grinding my bed.
Every time I home g28 then g29 s1 it tells me "Warning: G29: the height map was loaded when the current Z=0 datum was not determined probing. This may result in a height offset."
Any help? -
Please post your config.g, homedelta.g, bed.g and your slicer start gcode. It would also help to see the results of M122 and M98 P"config.g".
Also check out these pages
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter
https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation -
@phaedrux ; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Apr 04 2021 16:38:36 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"Flsun_Q5_Duet" ; set printer name
M665 R107.5 L215 B100 H300 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z80.00 E413.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop; Z-Probe
M558 P5 C"^!zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P500 X0 Y0 Z19.36 ; set Z probe trigger value, offset and trigger height
M557 R85 S20 ; define mesh grid; Heaters
M143 H1 S275 ; set temperature limit for heater 1 to 275C; Fans
M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M501 ; load saved parameters from non-volatile memory -
@phaedrux ; bed.g
; called to perform automatic delta calibration via G32
; Probe the bed at 3 peripheral and 3 halfway points, and perform 6-factor auto compensation
; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
G30 P0 X0 Y84.9 H0 Z-99999
G30 P1 X73.53 Y-42.45 H0 Z-99999
G30 P2 X-73.53 Y-42.45 H0 Z-99999
G30 P3 X0 Y42.4 H0 Z-99999
G30 P4 X36.72 Y-21.2 H0 Z-99999
G30 P5 X-36.72 Y-21.2 H0 Z-99999
G30 P6 X0 Y0 H0 Z-99999 S6
; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed) -
@phaedrux ; homedelta.g
G91 ; relative positioning
G1 H1 X305 Y305 Z305 F1800 ; move all towers to the high end stopping at the endstops (first pass)
G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
G90 ; absolute positioning
G1 X0 Y0 F6000 ; move X+Y to the centre
G29 s1Start gcode
G28
G29 S1G1 Z15.0 F6000 ;Move the platform down 15mm
;Prime the extruder
G92 E0
G1 F200 E3
G92 E0 -
@phaedrux
I spent all day going through the guides and nothing changed.
Every time I the bed map it look good. I can see where my bed is uneven a little.
When I print the nozzle grinds into the bed and within 40 mm is printing in air then back to grinding the bed. -
@darkuncle33 said in Delta mesh leveling not working.:
Start gcode
G28
G29 S1You should be doing a calibration between homing the towers and loading the heightmap. Add G32 between the G28 and G29.
@phaedrux
I don't see how I can do that. I have a removeable probe. I tried that and it just started printing with the probe attached. -
@phaedrux
I put a pause "M25" on the start gcode after the g29, so I could take the probe off. That worked, It is printing now, Is that how it should be done? Is there something I am still doing wrong? With the factory firmware you only need to use the probe once or if you change something, not before every print. So taking it of mid print is not an issue. -
Well when you home the towers you are assuming that the homed height is correct for the distance to the bed, but it might not be. Normally you'd do at least a single G30 at the center of the bed to re-establish an accurate position for the z0 point before loading the heightmap. But with a delta i's even more common to do a quick calibration run before each print just for best results. That is complicated by the removable probe in this case, but still probably the best way to go.
@phaedrux
I am happy to take the probe off before every print because I am getting really nice first layers that way. Now I am going to see if there is a way to have a message on the paneldue that says "Attach probe" and "Remove probe" with two print pauses in the start gcode. That you make the hole thing look more polished. -
Check out the M291 command. It can pause and display a prompt for ok/cancel.
Your M665 H value is way to high for a Q5.
with a stock q5 it should be no more than 220.
