    Bed levelling using multiple independent Z motors
    955
    • CHARLI55undefined
      CHARLI55
      • Hello, I have a problem with a BLV MGN with Duet Wifi and RepRapFirmware 3, "Leveling the bed with several independent Z motors",
        I have done everything that says the page https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors, but still when I send a G32 the extruder goes to the screws and when the bed is finished, no solution is leveled?
        I attach my data from config.g and bed.g.
        I'm very sorry for the bad translation from Spanish to English. Thanks.
      ; config.g
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 10 2021 17:47:01 GMT+0200 (hora de verano de Europa central)
      G90                                             ; send absolute coordinates...
      M83                                             ; ...but relative extruder moves
      M550 P"My Printer"                              ; set printer name
      M669 K1                                         ; select CoreXY mode
      M552 S1                                         ; enable network
      M586 P0 S1                                      ; enable HTTP
      M586 P1 S0                                      ; disable FTP
      M586 P2 S0                                      ; disable Telnet
      M569 P0 S1                                      ; physical drive X goes forwards
      M569 P1 S1                                      ; physical drive Y goes forwards
      M569 P2 S1                                      ; physical drive Z goes forwards
      M569 P3 S1                                      ; physical drive E0 goes forwards
      M569 P4 S1                                      ; physical drive E1 goes forwards
      M569 P5 S1                                      ; physical drive Z goes forwards
      M569 P6 S1                                      ; physical drive Z goes forwards
      M584 X0 Y1 Z2:5:6 E3:4                          ; set drive mapping
      M671 X176:305:46 Y3:285:285 S0.5                ; leadscrews at rear left, front middle and rear right
      M350 X16 Y16 Z16 E16:16 I1                      ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E420.00:420.00        ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00:120.00      ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00      ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800:800 I30                ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                         ; Set idle timeout
      M208 X0 Y0 Z0 S1                                ; set axis minima
      M208 X320 Y320 Z400 S0                          ; set axis maxima
      M574 X1 S1 P"xstop"                             ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                             ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2                                      ; configure Z-probe endstop for low end on Z
      M950 S2 C"exp.heater5"                          ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000             ; set Z probe type to bltouch and the dive height + speeds
      M574 Z1 S2										; set endstop controlled by probed
      G31 P500 X0 Y0 Z2.5                             ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20                        ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138  ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                           ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B1 S1.00                                ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                         ; map heated bed to heater 0
      M143 H0 S120                                    ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138   ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                            ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                    ; set temperature limit for heater 1 to 280C
      M308 S2 P"e1temp" Y"thermistor" T100000 B4138   ; configure sensor 1 as thermistor on pin e0temp
      M950 H2 C"e1heat" T2                            ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H2 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S280                                    ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                            ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                  ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                            ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                               ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                ; define tool 0
      G10 P0 X0 Y0 Z0                                 ; set tool 0 axis offsets
      G10 P0 R0 S0                                    ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 D1 H2 F0                                ; define tool 1
      G10 P1 X0 Y0 Z0                                 ; set tool 1 axis offsets
      G10 P1 R0 S0                                    ; set initial tool 0 active and standby temperatures to 0C
      M575 P1 S1 B57600                               ; enable support for PanelDue
      ; bed.g
      G28 ; home
      M401 ; deploy Z probe (omit if using bltouch)
      G30 P0 X176 Y3 Z-99999 ; probe near a leadscrew
      G30 P1 X305 Y285 Z-99999 ; probe near a leadscrew
      G30 P2 X46 Y285 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
      M402 ; retract probe (omit if using bltouch)
      jay_s_ukundefined Nuramoriundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @CHARLI55
        @charli55 one thing you don't need is M401/M402 in your bed file as thats handled by the firmware.
        Were there any outputs?
        Having S0.5 on M671 limits the adjustment to anything out of whack more than 0.5. I suggest increasing this value above what you expect the maximum out of level to be, e.g. S10
        CHARLI55undefined 2 Replies Last reply Reply Quote 0
        • CHARLI55undefined
          CHARLI55 @jay_s_uk
          I change it, try and comment, thank you.
          • Nuramoriundefined
            Nuramori @CHARLI55
            @charli55 you can’t do a triple z axis solution with just a duet2wifi. You need a duex2 or duex5 expansion board. Your config.g seems to suggest that you haven’t done this. We have a very strong blv community on Facebook and now our own discord server for this; I also am one of the two main people that have done the independent triple z axis redesigns that are used on it. I’m happy to help you through it.
            jay_s_ukundefined CHARLI55undefined 2 Replies Last reply Reply Quote 0
              jay_s_uk @Nuramori
              @nuramori why does it suggest that? he's mapped drivers 5 and 6 to Z, suggesting 3 drivers being used.
              Nuramoriundefined 1 Reply Last reply Reply Quote 0
              • CHARLI55undefined
                CHARLI55 @Nuramori
                @nuramori M584 X0 Y1 Z2:5:6 E3:4
                I have duet wifi + duex5
                • Nuramoriundefined
                  Nuramori @jay_s_uk
                  @jay_s_uk just a brain fart. I’ve gotten used to the preceding nomenclature for drivers like 0.1, 1.2 so it looked like there wasn’t an expansion board associated with it. My bad.
                  • CHARLI55undefined
                    CHARLI55 @jay_s_uk
                    @jay_s_uk M671 X176:305:46 Y3:285:285 S1.0
                    The engines still do not move
                    Z
                      jay_s_uk @CHARLI55
                      @charli55 is there any output in the console?
                      CHARLI55undefined 1 Reply Last reply Reply Quote 0
                      • CHARLI55undefined
                        CHARLI55 @jay_s_uk
                        @jay_s_uk Error: Compensation or calibration cancelled due to probing errors
                        13/4/2021 20:28:34 g32
                        Error: Z probe was not triggered during probing move
                        • CHARLI55undefined
                          CHARLI55 @CHARLI55
                          @charli55
                          If it is true that it is not activated in the first spindle, the red IR LED does not turn on
                          • o_lampeundefined
                            o_lampe @CHARLI55
                            @charli55
                            Does the z-probe work in the center of the bed? Maybe you have to increase the 'dive height' of the z-probe?
                            • CHARLI55undefined
                              CHARLI55
                              But I don't know what happens if the bed almost touches the IR
                              • CHARLI55undefined
                                CHARLI55
                                Thanks, it's already solved. Spindle adjustments made: -0.287 -0.128 -0.303, points used 3, (mean, deviation) before (-0.238, 0.079) after (0.000, 0.000
                                • CHARLI55undefined
                                  CHARLI55 @CHARLI55
                                  @charli55 said in Bed levelling using multiple independent Z motors:
                                  your dive height isn't high enough to accomodate the bed skew
