    IDEX: homing X or U -> only X carriage moves in both cases.
    • customPrintundefined
      customPrint
      Hope all are doing well these days.
      More on the subject line:
      Using M564, I can move both the X and U carriages independently via command line or using pre-sets, as expected.
      When tiring to homing either one, which one first doesn't matter, the X carriage only moves in both cases.
      When X is homed:
      -it pushes the U carriage.
      -for all intents and purposes homes on the X designated endstop.
      -X tool position is updated
      When U is homed:
      -X carriage pushes the U-carriage.
      _Homes on the X-endstop.
      -I get an "G28 U Error: homing failed" message.
      -X Tool position is updated.
      Post either homing, X and U carriages will move independently, via command line or using pre-sets.
      Flipping the X and U motor mapping in config.sys', the above happens minus X pushing U carriage as they are 'flipped'.
      Endstop wise, X-endstop is the furthest on the right, and U-endstop (E0 wired) about an 1" to the left of the X-endstop. I want both to home on the right side of the axis.
      Code
      Config.sys - partial:
      Both X and U homing are the same:
      Thanks
      -Peter
      sebkritikelundefined 1 Reply Last reply Reply Quote 0
      • sebkritikelundefined
        sebkritikel @customPrint
        @customprint I see you've posted in the past - could you upload your entire config.g, homex.g, homeu.g, and perhaps homeall.g? Thanks!
        Large(ish?) IDEX - 6HC, 1HCL
        Stratasys Dimension 1200es to 6HC Conversion
        customPrintundefined 1 Reply Last reply Reply Quote 0
          customPrint @sebkritikel
          @sebkritikel
          Yeah getting this to work has been a learning experience. Made a bit of headway when I included the P4 in the M584 line. But clearly missing something else.
          Thanks for responding.
          -Peter
          Here are screen grabs:
          Config.sys
          and Homing. Though never used HomeAll.
          HomeX:
          HomeU:
          HomeAll:
            @customprint Thanks for the response! I’ll take a more detailed look tomorrow, but inspect the lines in homeu.g - this may be from the configurator not being smart about IDEX. In the home U lines, you’re actually commanding the X axis to move, not the U axis. Change that to move the U (not X) axis in the appropriate direction towards the end stop, and you’ll be well on your way I think.
            • o_lampeundefined
              o_lampe
              The way you put the values for the second extruder is wrong in all lines after M584:
              The right way to put them is
              • M350.....E16:16
              • M92 ..... E420:420
              • M566.....E120:120
              • etc...
              You also have to define a second tool, where you declare the U axis as replacement for X
              M563 P1 Dn Hm Fx X2 ; where 2 is the driver number of 'U'
              G10 P1 U{ "about 1 inch to the left"} Y0 Znn.nn ; put the offset between X and U here
                customPrint
                Thanks Sebritikel and o_lampe,
                Yeah the files were created by the configurator and I tried various modifications using https://duet3d.dozuki.com/Wiki/ConfiguringMultipleIndependentXcarriagesCartesian#Section_Calibration
                as well posts found on the 'nets.
                Later today I'll try the changes you say are needed o_lampe and any that you offer Sebritikel and report back when I do.
                If you find anything else to try or have any other suggestions feel free to pass along.
                Have a good day/night.
                -Peter
                  customPrint
                  @sebkritikel: yeah changing the X to U made all the difference . D'oh! seems stupidly obvious now.
                  @o_lampe: Made the changes and added the second tool screen grab below.
                  All is working as I expect, on to the next steps of my custom testing.
                  Again thanks for the time to look at my code.
                  -Peter
