    Bringing older (new) board up to current FW
    • 3DPMicroundefined
      3DPMicro
      Pulled out my backup Duet Ethernet board in the hope that I can bring it up to the later RRF 3 with accelerometers and use it on a new build. I haven't been keeping up with the progression so I'm not sure its doable but if it is what is the sequence for upgrading ?
      The controller is V1.02. I believe it had FW 1.18.1 but I must have erased it at one point because all that is on the SD is the SYS, Macros, WWW and g-codes folders and their contents. Before looking at the SD I connected YAT but got nothing in return after sending M115.
      Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
      o_lampeundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @3DPMicro
        @3dpmicro
        In your case you might find the 'fallback' strategies useful described here
        Good luck
          dc42 administrators @3DPMicro
          @3dpmicro I suggest you do the following:
          • Use Bossa to install RRF 3.3beta3 directly
          • Then you should be able to communicate with the Duet using YAT
          • Using a PC, create a /firmware folder on the SD card and copy DuetWiFiServer.bin and Duet2_SDiap32_WiFiEth.bin into it. Also rename or delete the existing /www folder, create a new /www folder, and extract DuetWebControl_SD.zip into it.
          • Put the card back in the Duet and restart the Duet. Send M997 S1 from YAT to install the WiFi firmware.
          • Then use M587 to set up the access point parameters (see the Getting Connected guide).
          3DPMicroundefined 1 Reply Last reply Reply Quote 0
          • 3DPMicroundefined
            3DPMicro @dc42
            @dc42 thank you Sir. Its alive and well
