    duet 2 wifi stop in printing
    • flyingpig507undefined
      flyingpig507
      Hi, my DWC reconnect in printing then last progress was lost, the “status” display: No Job running.
      It is DIY Cartesian i3 style. Just stuck in there:
      Here's some information:
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11)
      Duet WiFi Server Version: 1.25
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9K662-MGPSS-6J9DL-3S86P-18V6Z
      Used output buffers: 3 of 24 (10 max)
      Static ram: 23460
      Dynamic ram: 73228 of which 40 recycled
      Never used RAM 15352, free system stack 193 words
      Tasks: NETWORK(ready,183) HEAT(blocked,308) MAIN(running,449) IDLE(ready,20)
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:00:15 ago, cause: software
      Last software reset at 2021-04-26 21:28, reason: StuckInSpinLoop, GCodes spinning, available RAM 15108, slot 2
      Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x200040ac Task MAIN Freestk 772 ok
      Stack: 0041f9c3 00459a3c 610f0200 3f800000 3d7df000 3edb6db7 b61cf800 49742404 3c3fdc9b 440739fd 40e190bc 0000bb9b 00000000 3e4fa932 41ddae4f 4e64e1c0 38533333 3f800000 3f800000 20000011 00000000 00000001 00000000 00000000 20002544 00000001 0041f9c3
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU temperature: min 32.6, current 33.3, max 33.5
      Supply voltage: min 24.8, current 25.0, max 25.2, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max not available
      Driver 1: position 0, standstill, SG min/max not available
      Driver 2: position 0, standstill, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-04-26 21:29:14
      Cache data hit count 17227880
      Slowest loop: 6.87ms; fastest: 0.21ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 1.0ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 177.94ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is active
        WiFi firmware version 1.25
        WiFi MAC address 50:02:91🇩🇪aa:53
        WiFi Vcc 3.49, reset reason Power up
        WiFi flash size 4194304, free heap 26568
        WiFi IP address 192.168.0.198
        WiFi signal strength -60dBm, mode 802.11n, reconnections 0, sleep mode modem
        Clock register 00002002
      config.g
      M550 P"daZhu_i3" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes forwards
      M569 P1 S0 ; physical drive 1 goes forwards
      M92 X100.00 Y100.00 Z800.00 E381.92 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X7200.00 Y7200.00 Z3600.00 E1800.00 ; set maximum speeds (mm/min)
      M906 X600 Y600 Z600 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X172 Y200 Z150 S0 ; set axis maxima
      M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
      ; M558 P0 H5 F120 T7200 ; disable Z probe but set dive height, probe speed and travel speed
      ; M557 X15:190 Y15:195 S20 ; define mesh grid
      M558 P9 C"^zprobe.in" H5 F120 T3000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-42.8 Y-5.5 Z3.011 ; set Z probe trigger value, offset and trigger height
      M557 X10:128 Y10:190 S118:180 ; define mesh grid
      M307 H0 R0.213 C685.2 D3.92 S1.00 V24.0 ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S100 ; set temperature limit for heater 0 to 100C
      M307 H1 R3.569 C137.0 D6.19 S1.00 V24.0 ; disable bang-bang mode for heater and set PWM limit
      Please help me, Thanks.
      felekundefined 1 Reply Last reply Reply Quote 0
      • felekundefined
        felek @flyingpig507
        @flyingpig507
        Hi!
        Did you have similar issue before?
        According to stack trace it looks like some sd card issue.
        Let's replace this sd card.
        alankilianundefined flyingpig507undefined 2 Replies Last reply Reply Quote 0
        • alankilianundefined
          alankilian @felek
          @felek I'm interested in learning more about how you come to this conclusion.
          I see:
          And in RepRapFirmware-3.3beta3/src/Platform/RepRap.cpp" line 734 there is:
          ticksInSpinState = 0;
          spinningModule = moduleGcodes;
          gCodes->Spin();
          Which points me to whatever the method gCodes->Spin() is doing.
          • felekundefined
            felek @alankilian
            @alankilian
            In M122 you have more precise information:
            Next step is download file with map file. You need to do it for your board and firmware version.
            In your case it is this zip file https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Symbols-RepRapFirmware-Duet2.zip
            There is .map file which include functions addresses in memory.
            Then you need to compare your stack address and map file function address.
              flyingpig507 @felek
              @felek
              This is my TF
              This duet board I used almost a year ago. It's been good before (Firmware 1.x). Similar problems was happen until I update Firmware.
              I not sure always used this TF, maybe changed it...
              I will chang other TF try again.
              Thanks you.
                flyingpig507
                I changed TF, it is fine. thank felek (。・∀・)ノ゙
                • sgereviniundefined sgerevini referenced this topic
