Solved Ender 3 Maestro BlTouch not homing
Hi, this is my first post to a forum ever, so apologies in advance.
I upgraded my duet 2 maestro to rrf 3 (RepRapFirmware for Duet 2 Maestro 3.2 (2021-01-05).Now when I try and home Z, I get the following error. "G28Z Error:Z Probe already triggered at start of probing move" Homing Failed.
I am including my config. I worked quite a bit, and tried several things, so I apologize that the config has a bunch commented out (other tries). I am also including my deploy and retract. Thanks in advance.
--config--
; Configuration file for Duet Maestro (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Apr 11 2021 16:56:43 GMT-0700 (Pacific Daylight Time); General preferences
M550 P"Ender" ; set printer name
M918 P1 E4 F2000000 ; configure direct-connect display; Network
M552 P192.168.0.13 S1 ; enable network and set IP address
M553 P255.255.255.0 ; set netmask
M554 P192.168.0.1 ; set gateway
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P3 S0 ; physical drive 3 goes backwards
M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X235 Y235 Z260 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch
G31 P500 X0 Y-45 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
;M307 H7 A-1 C-1 D-1 ; (FOR BLTOUCH)Disable the 7th Heater to free up PWM channel 5 on the Duex board.
M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
M307 H0 A2.429 C140 D5.5 V0 B0 ;Heater 0 model: heating rate 2.429, cooling time constant 140.0, dead time 5.50, max PWM 1.00, calibration voltage 0.0, mode bang-bang
M143 H0 S150 ; set temperature limit for heater 0 to 150C
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M307 H1 R2.781 C145.9:145.5 D4.10 S1.00 V23.5
M143 H1 S275 ; set temperature limit for heater 1 to 275C; Fans
M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss--deploy--
; deployprobe.g
; called to deploy a physical Z probe
M280 P0 S10 ; deploy BLTouch--retract--
; retractprobe.g
; called to retract a physical Z probe
M280 P0 S90 ; retract BLTouch -
Can you post your homeall as well?
Are you able to control the pin of the BLTouch with M401 and M402?
Can you also share the results of M122 and M98 P"config.g"?
Can you try this dynamic test described here: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Dynamic_test
@phaedrux Thank you for the quick response.
M401 and M402 do nothing.
The BL touch flashes red (the whole body).
--M122--
M122
RepRapFirmware for Duet 2 Maestro version 3.2 running on Duet Maestro 1.0
Board ID: 08DJM-956GU-P23TJ-6J9D0-3SD6P-9B0YU
Used output buffers: 3 of 24 (11 max)
Static ram: 22292
Dynamic ram: 73032 of which 76 recycled
Never used RAM 19432, free system stack 162 words
Tasks: NETWORK(ready,206) HEAT(blocked,340) TMC(blocked,117) MAIN(running,477) IDLE(ready,20)
Owned mutexes:
Last reset 00:03:13 ago, cause: power up
Last software reset at 2021-04-25 21:11, reason: User, GCodes spinning, available RAM 19676, slot 0
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 30.7, current 39.1, max 39.5
Supply voltage: min 0.0, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 1200, standstill, read errors 0, write errors 0, ifcnt 11, reads 32204, writes 11, timeouts 0, DMA errors 0
Driver 1: position 4800, standstill, read errors 0, write errors 0, ifcnt 11, reads 32204, writes 11, timeouts 0, DMA errors 0
Driver 2: position 2000, standstill, read errors 0, write errors 0, ifcnt 11, reads 32204, writes 11, timeouts 0, DMA errors 0
Driver 3: position 0, standstill, read errors 0, write errors 0, ifcnt 8, reads 32207, writes 8, timeouts 0, DMA errors 0
Driver 4: position 0, standstill, read errors 0, write errors 0, ifcnt 6, reads 32209, writes 6, timeouts 0, DMA errors 0
Driver 5: position 0, assumed not present
Driver 6: position 0, assumed not present
Date/time: 2021-04-29 17:08:28
Slowest loop: 21.79ms; fastest: 0.15ms
=== Storage ===
Free file entries: 10
SD card 0 detected, interface speed: 15.0MBytes/sec
SD card longest read time 9.9ms, write time 0.0ms, max retries 0
DMs created 83, maxWait 91255ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 12, completed moves 12, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Bed heaters = 0 -1, chamberHeaters = -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 10.75ms; fastest: 0.02ms
HTTP sessions: 1 of 8
Interface state active, link 100Mbps full duplex--M98 P"config.g--
M98 P"config.g
Error: M98: control character in string--M98 P config.g---
M98 P config.g
Warning: Macro file config.g not found--homeall.g--
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Apr 11 2021 16:56:44 GMT-0700 (Pacific Daylight Time)
G91 ; relative positioning
G1 H1 X-240 Y-240 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-240 Y-240 F240 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X15 Y60 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning -
@scarwear said in Ender 3 Maestro BlTouch not homing:
--M98 P"config.g--
M98 P"config.g
--M98 P config.g---
M98 P config.g
Warning: Macro file config.g not foundM98 P"config.g"
exactly like that.@scarwear said in Ender 3 Maestro BlTouch not homing:
The BL touch flashes red (the whole body).Do you mean that sending M401/M402 causes the Bltouch to start flashing? Does the pin go up and down at startup?
@phaedrux said in Ender 3 Maestro BlTouch not homing:
M98 P"config.g"
As soon as I turn on the printer the BLtouch immediately starts the fast flashing (LED). The BLtouch never drops and retracts the PIN for self test.
--M98 P"config.g"---
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: bad model parametersThanks again.
I think your BLTouch may have a bent pin or something then, because it should drop and raise the pin as a self test. Flashing red at startup means it's failing that test. You can remove the set screw at the top of the BLTouch to remove the pin to check it.
Config.g is wrong....
should beM950 S0 C"zprobe.mod" ; create servo pin 0 for BLTouch M558 P9 C"zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speedsChange that to
Check deployprobe.g
content should be:M280 P0 S10
Check retractprobe.g
content should be:M280 P0 S90
; Z-Probe M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X15:215 Y15:195 S20 ; define mesh grid
The pullup is correct. That's what the config tool generates, and I compared to my own maestro config and it's the same. He's also posted his deploy and retract above and it's correct too.
If the pin isn't deploying at power up for a self test then it hasn't even gotten to the config part yet.
Worked for me and others...
https://forum.duet3d.com/topic/13924/maestro-rrf3-and-bltouch-issues/16 -
@diy-o-sphere @Phaedrux you were correct. Bent Pin. The simple things :). All is good now. Thank you both. Now off to do some printing.
