Voron 0 + Duet 3 Mini
@paulhew https://www.omc-stepperonline.com/round-nema-14-bipolar-1-8deg-9-ncm-12-75-oz-in-1-0a-f36x17-5mm-4-wires.html
That's the one. Yeah, it's a bit high, as I said, still tuning. Put probably a roll of filament through at that amperage though and so far it looks fine (had the extruder disassembled yesterday).
@keyz182 Thanks for the info.
Going to steal some of your config!My LDO even @450ma was hot enough to burn my fingers.
Might get one of those steppers, not trusting the LDO at the moment....
Thanks again
P. -
@zapta cult of Voron ... lol ABS Mafia
@sputnikoc3d said in Voron 0 + Duet 3 Mini:
I have a box full of V2.4 parts waiting for the Misumi extrusions to be built.
Hi, i´ve already my V0.1 running. It was the mini afterburner. I´ve just calibrated the extruder...started with 400 ... ended up with 780.
Till now there was nothing melted. I´m using the LDO 36STH20-1004. Running with 900mA
What i had now is that my Duet Board doesn´t like to stay without cooling behind the panels. That socks really.
I´ve to design now a cooling fan for it. Really bad on this little thing with no space.
