    Some issues configuring external stepper drivers with Duet 0.6
    • anironundefined
      aniron
      Hi, I have added a fabscan shield with four TMC2209 silentstepsticks to my Duet 0.6/Duet shield in the hope of more drivers with less noise in operation (yes I know, get a Duet3 already).
      However, when I try to move the motors on the external drivers, they only make a sound as if they were moving but do not actually budge. Motor has holding torque, so it does receive power.
      I believed I had set the currents using UART, but the trim pot on the board appears to override it. I have tried setting the currents between 0.5-1.5A without any difference in behaviour except increased holding torque and slightly louder noise.
      Same motor and wiring works fine connected to the main board.
      I supply the fabscan shield with +5V via the Duet and +24V externally. The Duet is powered with external 12V and external 5V via the external 12V->5V converter board
      TMC2209's are hooked up to step/dir/en on the Duet expansion header.
      Grateful for any pointers.
      config.g :
      ; Configuration file for Duet 0.6 (firmware version 1.17 to 1.19)
      ; generated by RepRapFirmware Configuration Tool v2 on Fri Aug 09 2019 23:47:07 GMT+0200 (Central European Summer Time)
      G90                                             ; Send absolute coordinates...
      M83                                             ; ...but relative extruder moves
      {Redacted}
      M584 X5 Y4 Z1:2 E6:7                              ; Remap X, Y, E0,E1 to external drivers.
      M569 P0 S0                                     ; Physical drive 0 goes backwards
      M569 P1 S1                                      ; Physical drive 1 goes forwards
      M569 P2 S0                                     ; Physical drive 2 goes backwards
      M569 P3 S0                                     ; Physical drive 3 goes backwards
      M569 P4 S0 H1 T0.1                                ; Physical drive 4 goes backwards
      M569 P5 S1 H1 T0.1                                     ; Physical drive 5 goes forwards
      M569 P6 S1 H1 T0 1                                      ; Physical drive 6 goes forwards
      M569 P7 S1 H1 T0.1                                     ; Physical drive 7 goes forwards
      M92 X80 Y53.33 Z1600.00 E817.00:817.00       ; Set steps per mm
      M566 X1800.00 Y1800.00 Z12.00 E120.00:120.00      ; Set maximum instantaneous speed changes (mm/min)
      M203 X3000.00 Y3000.00 Z180.00 E1200.00:1200.00 ; Set maximum speeds (mm/min)
      M201 X9000.00 Y250.00 Z200.00 E250.00:250.00      ; Set accelerations (mm/s^2)
      M906 X1100.00 Y1100.00 Z800.00 E1400.00:1400.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30                                         ; Set idle timeout
      M208 X-55 Y-5 Z0 S1                                ; Set axis minima
      M208 X273 Y238 Z125 S0                          ; Set axis maxima
      M574 X2 Y2 Z0 S0                                      ; Set active low and disabled endstops
      ;M574 S1                                   ; Set active high endstops
      M558 P5 I1 H5 F120 T6000                  ; Set Z probe type to unmodulated, the axes for which it is used and the dive height + speeds
      G31 P500 X62 Y-6 Z0.7 C-0.00208 S23.5                         ; Set Z probe trigger value, offset and trigger height
      ;Leadscrews
      M671 X-72:326 y0:0 S0.5			;Set Z-leadscrew x-positions
      M557 X20:230 Y20:180 S35                        ; Define mesh grid
      M307 H0 A103.8 C496.1 D4.0 V0.0 B0 S1.00  ; Disable bang-bang mode for the bed heater and set PWM limit and tuned PID parameters
      M305 P0 T100000 B4725 C7.060000e-8 R4700        ; Set thermistor + ADC parameters for heater 0
      M143 H0 S120                                    ; Set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4725 C7.060000e-8 R4700        ; Set thermistor + ADC parameters for heater 1
      M143 H1 S290                                   ; Set temperature limit for heater 1 to 280C
      M307 H1 A419.2 C265.8 D3.2 V0.0 B0             ;Set tuned PID parameters for heater 1
      M305 P3 T100000 B4725 C7.060000e-8 R4700        ; Set thermistor + ADC parameters for heater 3
      M143 H3 S290                                   ; Set temperature limit for heater 3 to 280C
      M307 H3 A451.3 C269.7 D4.7 V0.0 B0           ;Set tuned PID parameters for heater 3
      M106 P0 S0 I0 F500 H-1                          ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D1 H1                                  ; Define tool 0
      G10 P0 X0 Y0 Z0                                 ; Set tool 0 axis offsets
      G10 P0 R0 S0                                    ; Set initial tool 0 active and standby temperatures to 0C
      M563 P1 D0 H3                                 ; Define tool 1
      G10 P1 X20 Y0 Z0                                 ; Set tool 1 axis offsets
      G10 P1 R0 S0                                    ; Set initial tool 1 active and standby temperatures to 0C
      M572 D0 S1.0       ;  Setup pressure advance for tool 0
      M572 D1 S1.0        ; Setup pressure advance for tool 1
        What firmware version are you running on there?
        dc42undefined anironundefined 2 Replies Last reply Reply Quote 0
          dc42 administrators @Phaedrux
          I know nothing about the fabscan shield, however as the Duet supplies 3.3V signals you will need to supply 3.3V power to the TMC2209 drivers, not 5V.
          anironundefined 1 Reply Last reply Reply Quote 1
          • anironundefined
            aniron @dc42
            @dc42 that was an easy change, but alas didnt help the issue.
            Oh, and I also have watterott stepstick protectors on the silentstepsticks, might they be interfering?
            • anironundefined
              aniron @Phaedrux
              @phaedrux
              Software Information
              Firmware Name: RepRapFirmware for Duet
              Firmware Electronics: Duet 0.6
              Firmware Version: 1.26.1 (2020-02-09b1)
              Web Interface Version: 1.22.6
                dc42 administrators @aniron
                @aniron said in Some issues configuring external stepper drivers with Duet 0.6:
                No, assuming they are wired correctly.
                Have you definitely connected the TMC2209 Step inputs to the correct pins on the Duet expansion header?
                anironundefined 1 Reply Last reply Reply Quote 0
                • anironundefined
                  aniron @dc42
                  @dc42 I can check again, but since the X and Y steppers go through the motions (you can hear it quietly whine as if accelerating and decelerating just as expected with actual movement), I would think so.
                  I did get one of the extruder steppers actually moving (only on retract for some reason even with M302 P1) by double checking the wiring between the stepstick and stepper. Shouldn't have assumed all the steppers had the same pinout.
                  Edit: ooh, wait, maybe I have accidentally swapped En and Dir...
                  Edit2: Yup, not only had I turned the 3pin Dupont the wrong way around on the shield, I had also gotten the two rows on the confused on the Duet itself when connecting up E1 and E2. All steppers working now.
                  Mystery solved! Thank you.
