    Where is my config.g
    Firmware installation
    446
    • tecnoundefined
      tecno
      Just received my Mini 5+
      In my sysyems folder there is no config.g to be found.
      How can I get this file?
      Cheers Bengt
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • SIamundefined
        SIam
        Here you can generate the required files
        https://configtool.reprapfirmware.org/Start
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        • tecnoundefined
          tecno @tecno
          @tecno Thank you!
          • tecnoundefined
            tecno @tecno
            That config tool does not work with Mini 5+ WiFi
            Can not set drivers !!!
            Assume I have to edit the generated config.g
            • T3P3Tonyundefined
              T3P3Tony administrators @tecno
              @tecno what aspect does not work with the Mini 5+ ?
              www.duet3d.com
              Argoundefined 1 Reply Last reply Reply Quote 0
              • Argoundefined
                Argo @T3P3Tony
                @t3p3tony
                Maybe I'm blind but I don't see how to generate a config with 7 drives.
                The "+" is not clickable after 5 added drives.
                There is also no Duet 3 Mini 2+ Dual-stepper Expansion Board available to add.
                • tecnoundefined
                  tecno
                  Can not add second Z
                  Can not choose driver? to axis = options greyed out
                  Can not set Z probe = options not working = greyed out
                  So for a newbe this is kind of frustrating
                  • T3P3Tonyundefined
                    @tecno @Argo I see yes, the mini 2+ is not yet added to the config tool so generate the config with a single Z axis, then you can edit the M584 command to add the additional drivers.
                    I know this is already logged to be added to the config tool on the next update.
                    www.duet3d.com
                    • tecnoundefined
                      tecno @T3P3Tony
                      @t3p3tony said in Where is my config.g:
                      M584 X0.2 Y0.1 Z0.3 Z1.4 E0.0
                      Is above syntax correct adding a second Z?
                        jay_s_uk @tecno
                        @tecno no
                        M584 X0.2 Y0.1 Z0.3:0.4 E0.0
                        assuming you're using the 4th and 5th drivers
                        tecnoundefined 1 Reply Last reply Reply Quote 1
                        • tecnoundefined
                          tecno @jay_s_uk
                          @jay_s_uk said in Where is my config.g:
                          @tecno no
                          Thank you!
