    Carriage won't reach bed
    Using Duet Controllers
    mini 5+ delta
    798
    • norwestieundefined
      norwestie
      I'm trying to get the bed leveling set. I commanded the hotend down but it stopped about 35mm above the bed. Using the RRF configurator, it allowed a max build height of 260mm but my Kossel is 300mm. Is that where my problem is?
      I've read through the guides but I don't see where the solution is.
      Anycubic Kossel Linear Plus
      Duet Mini 5+ Ethernet
      Firmware 3.3RC2
      SIamundefined 1 Reply Last reply Reply Quote 0
      • SIamundefined
        SIam @norwestie
        @norwestie normally your z axis should go down until it hits the endstop but first post your config.g and your home xyz g files
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        norwestieundefined 1 Reply Last reply Reply Quote 0
          norwestie @SIam
          @siam My endstops are at the top of my frame, nothing at the bottom. Here are my settings:
          ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Apr 26 2021 15:06:50 GMT-0700 (Pacific Daylight Time)
          M550 P"My Printer" ; set printer name
          M665 R134.4 L271.5 B116 H260 ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
          M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0.0 S0 ; physical drive 0.0 goes backwards
          M569 P0.1 S0 ; physical drive 0.1 goes backwards
          M569 P0.2 S0 ; physical drive 0.2 goes backwards
          M569 P0.3 S0 ; physical drive 0.3 goes backwards
          M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
          M92 X80.00 Y80.00 Z80.00 E98.60 ; set steps per mm
          M566 X1200.00 Y1200.00 Z1200.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 Z0 S1 ; set minimum Z
          M574 X2 S1 P"io0.in" ; configure active-high endstop for high end on X via pin io0.in
          M574 Y2 S1 P"io1.in" ; configure active-high endstop for high end on Y via pin io1.in
          M574 Z2 S1 P"io2.in" ; configure active-high endstop for high end on Z via pin io2.in
          M558 P4 R0.4 H3 F300 T1000 ; set Z probe type to switch and the dive height + speeds
          G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
          M557 R85 S20 ; define mesh grid
          M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
          M307 H0 R0.172 C503.9 D0.21 S1.00 V11.9 ; disable bang-bang mode for the bed heater and set PWM limit
          M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
          M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
          M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
          M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
          M501
          And HomeAll
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Apr 22 2021 11:11:46 GMT-0700 (Pacific Daylight Time)
          G91 ; relative positioning
          G1 H1 X235 Y215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X-5 Y-5 F6000 ; go back a few mm
          G1 H1 X235 Y215 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G1 H1 Z205 F360 ; move Z up stopping at the endstop
          G90 ; absolute positioning
          G92 Z200 ; set Z position to axis maximum (you may want to adjust this)
          ;G91 ; relative positioning
          ;G1 Z5 F100 ; lift Z relative to current position
          ;G90 ; absolute positioning
          Firmware 3.3RC2
            droftarts administrators
            @norwestie see https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
            The H parameter in M665 sets the Z height. As it says in the above guide:
            H = height of the nozzle above the bed when all three carriages are just high enough to trigger the endstop switches. Measure it as best you can, to within about 5mm. Calibration will adjust it.
              norwestie @droftarts
              @droftarts Thank you!
              Firmware 3.3RC2
                As it's a delta, your homing file is homedelta.g not homeall.g
                  norwestie @Phaedrux
                  @phaedrux I commented out the commands to drop the carriage after homing, measured and changed the distance from bed to homed position and attempted to lower again. Send the M208 and tried to get the probe to the bed but again it wouldn't go all the way down. It stopped about 40mm above. What am I doing wrong?
                  Firmware 3.3RC2
                    Phaedrux Moderator @norwestie
                    @norwestie said in Carriage won't reach bed:
                    I don't know. Show us your files.
                      norwestie @Phaedrux
                      @phaedrux Here is home delta.g:
                      ; homedelta.g
                      G1 H1 X265 Y265 Z265 F1800 ; move all towers to the high end stopping at the endstops (first pass)
                      G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
                      G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
                      G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
                      G1 X0 Y0 F6000 ; move X+Y to the centre
                      and config.g:
                      M550 P"Kossel" ; set printer name
                      M665 R134.4 L271.5 B116 H283 ; Set delta radius, diagonal rod length, printable radius and homed height
                      M501
                      Firmware 3.3RC2
                        @norwestie What's in your config_override.g? You have an M501 to load it, and it's probably overriding the settings in config.g.
                          @droftarts
                          ; config-override.g file generated in response to M500 at 2021-05-09 09:34
                          ; Delta parameters
                          M665 L271.500:271.500:271.500 R134.400 H260.000 B116.0 X0.000 Y0.000 Z0.000
                          M666 X0.000 Y0.000 Z0.000 A0.00 B0.00
                          ; Heater model parameters
                          M307 H0 R0.172 C503.900:503.900 D0.21 S1.00 V11.9 B0
                          M307 H1 R2.429 C140.000:140.000 D5.50 S1.00 V0.0 B0
                          ; Workplace coordinates
                          G10 L2 P1 X0.00 Y0.00 Z0.00
                          G10 L2 P2 X0.00 Y0.00 Z0.00
                          G10 L2 P3 X0.00 Y0.00 Z0.00
                          G10 L2 P4 X0.00 Y0.00 Z0.00
                          G10 L2 P5 X0.00 Y0.00 Z0.00
                          G10 L2 P6 X0.00 Y0.00 Z0.00
                          G10 L2 P7 X0.00 Y0.00 Z0.00
                          G10 L2 P8 X0.00 Y0.00 Z0.00
                          G10 L2 P9 X0.00 Y0.00 Z0.00
                          M486 S-1
                          Firmware 3.3RC2
                            droftarts administrators @norwestie
                            @norwestie it’s the M665 … H260 in config_override.g that’s overriding the value set in config.g. Start the Duet, then send M665, which will report the current setting. H will be 260. Send (same as in config):
                            Then M665 again to check. Then send M500 to save a new config_override.g with this setting.
                            Alternatively, remove the M501 from config.g, which stops the override being run. But any calibration changes will need to be copied into config.g manually. Easiest way to do that is to run calibration, save calibration with M500, then copy the bits that you want from config_override to config.g.
                              @droftarts said in Carriage won't reach bed:
                              Thank you again. This is all Greek to me so I rely heavily to you and the community for help.
                              Firmware 3.3RC2
                              Gaouundefined 1 Reply Last reply Reply Quote 0
                              • Gaouundefined
                                Gaou @norwestie
                                i am greek and most of these looks greek to me to ....
                                the M665 is what defines a printer as a delta to my understanding.
                                M665 Rxxx( is the radious of ur builded printer the internal one), Lxxx( the length of the rods that hold ur effectors) Bxxx( is the radious of ur bed) abd Hxxx( is the height of ur nozzle to the bed when the limit switces are enabled) .
                                Delta Printer || Duet 0.85 || firmware 1.23
                                Laser K40 || Duet 0.85 || Firmware 1.26.1 || Web 1.22
