Magnetic Filament Sensor alternatives?
@adrian52 Thanks but it's a little too expensive and difficult to get all the "external" parts...I think I'll go with two switches as simple filament runout sensors...
@the_dragonlord
The bigtreetech sensor is about US$25. Its not nearly as precise (~7mm) as the more expensive options. I found that it works much better when mounted so the sensor itself cannot move about (e.g. to the printer frame). I use it on my ender 5 and have it mounted before the extruder motor. Not the most optimal - but it gets the job done.
@stuartofmt said in Magnetic Filament Sensor alternatives?:
@the_dragonlord
mmhhh interesting... can you give me a link for the sensor please? Are you using it "as is" or have you modded it in some way?
I second , that BTT sensor is working ok.
Gone trough about 3 rolls of filament -
@stuartofmt thanks! If I'm not wrong this works "only" as a runout sensor not as clog sensor too, am I right? In case what's its advantage related to a normal switch? Other thing: in the site it's written it's compatible only with Marlin...what's necessary to do to make it work with RFF?
Thanks!
@the_dragonlord said in Magnetic Filament Sensor alternatives?:
No it should function similarly to the magnetic sensor, just lower resolution.
@phaedrux said in Magnetic Filament Sensor alternatives?:
wow, excellent....but are the wiring ant the FW configuration the same as the original? I'd need two of them so could I add it to E0 end stop and E1 end stop?
@the_dragonlord This might be one worth considering (specifically with the clog detection requirement)?
Finally I've solved the problem because I found an original Magnetic Rotating sensor kit without the housing, so I've ordered it and I'll print the housing
