    Extruder motor doesn't move
    240
    • zfeng
      zfeng last edited by
      Hi, I'm using a Duet2 Ethernet board, I have my own PID controller for temperature control. After homing the xyz axis, I could not enable the 3d printer extruder. Like shown here in the photo. I don't know if the extruder motion is prohibited because hot end temperature doesn't reach a certain value, or there's something else wrong with my system. Please advise, thank you.
      • SIam
        SIam last edited by
        If the extruder is cold or to cold you can't move it hope this link helps you:
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M302_Allow_cold_extrudes
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        zfeng 1 Reply Last reply Reply Quote 1
        • zfeng
          zfeng @SIam last edited by
          @siam Still not working. The retract and extrude control in extrusion control panel can't be active. Even I set M302 P1, the extruder control panel can't be use. In the E0 port of the board, I didn't see the red led is on after I plug the motor. In order to move the extruder, do I need set the temperature control input for the extruder heater?
          I have another question for the external extruder heater PID control. I have an external PID temperature controller for the extruder head control. How can I interface with the external temperature controller with the duet board?
            Phaedrux Moderator @zfeng last edited by
            @zfeng said in Extruder motor doesn't move:
            You'd have to provide a lot more details on the external controller.
            After sending M302 P1, try sending G1 E10 to see if the extruder will move.
            zfeng 1 Reply Last reply Reply Quote 0
            • zfeng
              zfeng @Phaedrux last edited by
              @phaedrux I tried G1 E10 code and yes the extruder moved a bit. But the extruder control section is still not active. The feed amount and feedrate can be selected, but the retract and extrude functions are down.
                What firmware and DWC version are you running?
                • zfeng
                  @phaedrux The firmware is 2.05, what is DWC?
                  • droftarts
                    droftarts Moderator last edited by droftarts
                    @zfeng DWC is the web interface. For version go to System > General. There was one version that didn’t enable the buttons, so update to the version here: https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1
                    Upload the file ‘DuetWebControl-SD-2.0.7.zip’ to the Duet in the system tab to update DWC.
                    You can also update the firmware from 2.05 to 2.05.1 (this has a number of bug fixes) by uploading the Duet2CombinedFirmware.bin file.
                    If that doesn’t work, post your config.g file; maybe you have no tools defined.
                    • zfeng
                      zfeng @droftarts last edited by
                      @droftarts I checked the version of the firmware is 2.05.1, and DWC is 2.0.7
                      SIam 1 Reply Last reply Reply Quote 0
                      • SIam
                        SIam @zfeng last edited by SIam
                        @zfeng post your config.g i can only see on your screenshot that you have not or not correct a thermistor or a heater configured
                        • zfeng
                          @siam 0:/sys/config.g
                          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jun 04 2021 14:52:41 GMT-0400 (Eastern Daylight Time)
                          M550 P"MassiveDimension" ; set printer name
                          M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
                          M586 P0 S1 ; enable HTTP
                          M586 P1 S0 ; disable FTP
                          M586 P2 S0 ; disable Telnet
                          M569 P0 S0 ; physical drive 0 goes backwards
                          M569 P5 S1 ; physical drive 5 goes forwards
                          M584 X0 Y1 Z2 E5 ; set drive mapping
                          M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
                          M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                          M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                          M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M208 X350 Y280 Z85 S0 ; set axis maxima
                          M574 X1 Y1 Z1 S0 ; set active low and disabled endstops
                          M558 P1 H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                          G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                          M557 X15:215 Y15:195 S20 ; define mesh grid
                          M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
                          M106 P0 S0 I0 F500 H T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M106 P1 S1 I0 F500 H T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M563 P1 D0 F0 ; define tool 1
                          G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
                          G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
                          T1 ; select first tool
                          MassiveDimension
                          Send code...
                          Status
                          Off
                          Tool Position
                          X
                          0.0
                          Y
                          0.0
                          Z
                          0.00
                          Extruder Drives
                          Drive 0
                          0.0
                          Speeds
                          Requested Speed
                          0 mm/s
                          Top Speed
                          0 mm/s
                          Sensors
                          Vin
                          1.3 V
                          MCU Temperature
                          27.0 C
                          Fan RPM
                          0
                          Z-Probe
                          999
                          Tools
                          Extra
                          Control All
                          Tool Heater Current Active Standby
                          Tool 1
                          T1 - Load Filament n/a n/a
                          Bed Heater 0
                          off 2000.0 C
                          0
                          0
                          Temperature Chart
                          System Directory
                            It looks like you have a bed heater defined, but not a tool heater. I can't recall but I think you might need to define a heater in RRF2.
                            Any reason you want to stay on RRF2?
                            • zfeng
                              @phaedrux What does RRF2 mean? Do I need to define tool heater before activating extruder? Can I bypass it?
                                RepRapFirmware 2 last version was 2.05.1 released over a year ago and no longer updated.
                                RepRapFirmware 3 is currently at version 3.2.2 and is actively being developed.
                                https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                                • zfeng
                                  @phaedrux How can I upgrade my board to RRF3?
                                    If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
                                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
                                    That will get your firmware and DWC up to date.
                                    You can see the change logs here:
                                    https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
                                    For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
                                    https://configtool.reprapfirmware.org/Start
                                    Backup your existing config files in the sys folder in case you want to switch back to RRF3. IT’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
                                    These documents will come in handy during the conversion.
                                    • Dougal1957
                                      Dougal1957 last edited by Dougal1957
                                      I also see from your Config that you are setting T1 as active but you only have T0 defined.
                                      Maybe @droftarts or @Phaedrux can just confirm they are far more expert than I am!
                                        Phaedrux Moderator @Dougal1957 last edited by
                                        @dougal1957 Almost. He is calling T1 at the end, but the tool he has defined is also T1. And the tool being defined doesn't have a heater assigned. I don't think that those things in themselves would cause a problem, but it's been a long time since I've used RRF2.
                                        Updating to RRF3 and using a cleaned up config.g might do wonders either way.
                                        • zfeng
                                          @phaedrux I upgraded the firmware, but now I seem to have problem with the endstops. The settings for my endstops type before upgrading were all "active-low", and endstop location all at low-end. But after upgrading, the active-low button disappeared and I selected switch instead, but after updating the new config file, I could not homing any axis due to the G28X failed to enable endstops error.
                                            Post your new config.g please.
                                            I suspect that you'll just need to invert the signal by adding a ! to the pin name.
                                            M574 X1 S1 P"!xstop"
                                            • zfeng
                                              @phaedrux ; Configuration file for Duet WiFi (firmware version 2.03)
                                              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 09 2021 17:54:24 GMT-0400 (Eastern Daylight Time)
                                              M550 P"My Printer" ; set printer name
                                              M552 S1 ; enable network
                                              M208 X230 Y210 Z200 S0 ; set axis maxima
                                              M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                                              M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
                                              M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                              M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                                Your config is still the same as before for RRF2. You'll need to redo it for RRF3.
                                                I suggest trying to generate a fresh one with the config tool using what you have from your current config to inform you. That will give you the correct syntax at least and can tweak from there.
                                                Also use M115 to verify that the firmware is actually update now.
                                                • zfeng
                                                  @phaedrux Sorry pasted the wrong one.
                                                  ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 09 2021 18:36:12 GMT-0400 (Eastern Daylight Time)
                                                  M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
                                                  M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
                                                  M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop
                                                  zfeng Phaedrux 2 Replies Last reply Reply Quote 0
                                                  • zfeng
                                                    zfeng @zfeng last edited by
                                                    @zfeng I used M115 and verified it's updated.
                                                      Does this work now, or not?
                                                      zfeng 2 Replies Last reply Reply Quote 0
