    DuetPanel i7 - Fysect Clone on Duet 3
    PanelDue
    • reFlexlabundefined
      reFlexlab
      Hello every body, I am currently building a machine in which i have integrated a duet 3 and i wired a Duet Panel i7 Fysect clone, the wiring seems to be ok since i am getting visual output from the screen.
      The problem is that the screen is blocked in a Connecting mode.
      Have you heard of the same issue before?
      Thanks in advance 🙂
      @ reFlexLab Paris # MMMM project
      Modular Multimaterial Multiprocess Manufacturing
      jay_s_ukundefined Nurgelrotundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @reFlexlab
        @reflexlab have you enabled it in your firmware using M575?
        • Nurgelrotundefined
          Nurgelrot @reFlexlab
          @reflexlab Are you sure RX/TX is the right way around? Sometimes its the simple things... and what's you M575 line look like in config.g
          reFlexlabundefined 1 Reply Last reply Reply Quote 0
            reFlexlab @Nurgelrot
            @nurgelrot ```
            M575 P1 S1 B57600
            Nurgelrotundefined 1 Reply Last reply Reply Quote 0
              @reflexlab Well other only time I've seen it suck in Connecting like that and my config was right I had Tx -> Tx and Rx -> Rx rather than having them crossed so the PD and board couldn't actually hear each other. If that's not it try reflashing the Firmware on the PD at that point your sorta out of options.
              Oh and just confirm you're plugged in IO.0 on the duet right? Or are you trying to use the ribbon cable?
              Also looks like you might be on <v3 firmware on PD based on the location of the "." between the numbers. if your on firmware V3 on the Duet you probably want to update the firmware on the PD anyway. Don't know what the compatibility is between version but everything current is usually the best way to go.
              • mfs12undefined
                mfs12
                Checking as solved due to inactivity.
                Visit me on github at https://github.com/mfs12/
