    Mesh bed leveling not working
    1.4k
    • pats.printsundefined
      pats.prints
      My ender with the duet boards runs flawlessly, but my anet a8 plus prints to close on one side and extremely high on the other. The printer has a PEI bed with an inductive sensor, G29 S1 at the start of every print. printer is on RRF 3.3. G32 for independent leveling works.
      I've tested a different bed surface with capacitive sensor, no matter what it prints at an angle and is always high on one and low on the other.
      I've seen a file mesh.g mentioned but neither printer saves that file
      Thanks for the help
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Jun 27 2021 09:31:03 GMT-0400 (Eastern Daylight Time)
      M550 P"Anet A8" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P3 S0 ; physical drive 3 goes Backwards
      M569 P4 S0 ; physical drive 4 goes backwards
      M584 X0 Y1 Z2:4 E3 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E396.00 ; set steps per mm
      M566 X600.00 Y600.00 Z18.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
      M906 X900 Y900 Z900 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-13 Y-10 Z0 S1 ; set axis minima
      M208 X300 Y300 Z340 S0 ; set axis maxima
      M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P5 C"!^zprobe.in" H3 F300 T7500 ; set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y-50 Z3 ; set Z probe trigger value, offset and trigger height
      M557 X15:290 Y15:245 S30 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 B0 R0.169 C511.4 D2.46 S1.00 V23.3 ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S130 ; set temperature limit for heater 0 to 130C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M307 H1 B0 R1.713 C195.9 D6.17 S1.00 V23.3 ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S275 ; set temperature limit for heater 1 to 275C
      M671 X-25:365 Y150:150 S2 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      T0 ; select first tool
      config.g
      bed.g
      heightmap.csv
      fcwiltundefined Argoundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @pats.prints
        @pats-prints
        I tested a few capacitive sensors and found that their response time was quite slow compared to inductive sensors.
        Have you tried lower the probing speed from 300 to, say, 100?
        You may also want to probe each point multiple times. To do that add A10 to your M558 command. With the default value of S=0.03 it will probe up to 10 times trying to get 2 consecutive readings within 0.03 as specified by S.
        You can also force averaging of a number of readings. For example if you include A3 and S-1 it will probe each point 3 times and average them.
        pats.printsundefined 1 Reply Last reply Reply Quote 0
          pats.prints @fcwilt
          @fcwilt it was at 150 until earlier this morning when I mirrored the settings on my ender.
          I'll give those a shot, thanks
            pats.prints
            @fcwilt
            M558 P5 C"!^zprobe.in" H3 F80 T5000 A10
            tested slower probing, same issue. The lead screws turn while its running so I know mesh is at least working. I had the same issue when I had a bl touch on the printer.
            fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
            • fcwiltundefined
              fcwilt @pats.prints
              @pats-prints
              80 points is not a very dense grid.
              I probe the max which is around 400 or so.
                pats.prints
                it prints about 2mm in the air on one side and scrapes the bed on the other, don't think probe density is the issue
                • fcwiltundefined
                  fcwilt @pats.prints
                  @pats-prints said in Mesh bed leveling not working:
                  2mm? That is a lot.
                  Still if mesh compensation is working it should be able to cope unless there is a Z speed issue - I think I remember reading something about that.
                  I see you are using G32 to auto-level the bed.
                  Is that working? If auto-level is not setup correctly each pass makes things worse.
                  You should complete the auto-level procedure by setting the Z=0 datum with a G30 positioning the probe at the center of the bed.
                  You also follow auto-level with G29.
                  Do you have a file mesh.g?
                    Phaedrux Moderator @pats.prints
                    @fcwilt
                    Those ridges look like backlash causing your print head to tilt back and forth causing the probe to move up and down depending on the direction.
                    Do you have a lot of play if you grab the print head and try and move it by hand? Are your belts tight?
                      pats.prints
                      I've tried with the same results running both g29 and g32, neither of my printers save a mesh.g file, not sure why
                      There is a fair bit of play in the gantry, belts are tight
                        Because it's a file you create akin to bed.g.
                        G32 calls bed.g
                        G29 would call mesh.g if it existed.
                        If you move the X axis back and forth can you visually tell that it's tilting the probe/nozzle back and forth as well?
                        pats.printsundefined 1 Reply Last reply Reply Quote 1
                          pats.prints @Phaedrux
                          @phaedrux no, moved it back and forth rapidly no issues, hotend doesn't seem to move at all.
                          My last ditch effort I just tried was moving my ender's pei sheet and calibrating on that. Same problem.
                          A thought just crossed my mind that on the cheapo anet they used two different lead screws? Causing this issue no matter what I do to fix it
                            Well the image of your heightmap is tell tale backlash. It's higher in one direction and lower in the other. Until you identify and eliminate that backlash, it will persist.
                              @phaedrux I'll see if the prusa X helps, otherwise this printer is going in the trash
                                What's a prusa X?
                                • Argoundefined
                                  Argo @pats.prints
                                  @pats-prints
                                  I see your probe‘s offset is 15mm on Y.
                                  If your axis is slightly tilted it’s more pronounced for the probe and the mesh is not usable.
                                    @phaedrux meant the prusa bear x upgrade
                                      pats.prints @Argo
                                      @argo the probe is offset x 0 y -50, it has happened across multiple sensors and bed types the nozzle slopes to be in the air on the low end of the x and scrapes the bed on the higher end of the x
                                      I guess I should also mention I started with 2.0 firmware and recently switched to 3.3 to see if it would help
                                        pats.prints
                                        The bear parts didn't fit but I tried 2 LMU88 bearings on each side for the x carriage and had horrible binding. Went back to the stock long bearing- and still the exact same issue. the bed looks fine on the height map viewer.
                                        I think I'm just going to buy some corexy machine and throw the anet in the trash
                                        thanks for your input
                                        fcwiltundefined 1 Reply Last reply Reply Quote 1
                                        • fcwiltundefined
                                          fcwilt @pats.prints
                                          @pats-prints
                                          Sometimes that is the best thing to do.
                                          I had three deltas and decided I didn't like them - gave two away, trashed the third.
