    G29 command skipping grid points
    • aldialloundefined
      aldiallo
      Hi all,
      I have an issue when running G29 command on my Ender 5 where I'm getting the error message: Warning : Skipping grid point ( X,Y) because Z probe cannot reach it as you can see below:
      This must be an issue with my config.g and how i defined my grid and number of points to test but I cannot figure out exactly what parameter I got wrong, here's my config.g if someone can help point me to pin point the issue.
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Oct 04 2020 22:37:40 GMT+0200 (heure d’été d’Europe centrale)
      M550 P"Ender 5 Plus" ; set printer name
      M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.0 S0 ; physical drive 0.0 goes backwards
      M569 P0.1 S0 ; physical drive 0.1 goes backwards
      M569 P0.2 S0 ; physical drive 0.2 goes backwards
      M569 P0.4 S0 ; physical drive 0.4 goes backwards
      M584 X0.0 Y0.1 Z0.2:0.3 E0.4 ; set drive mapping
      M92 X80.00 Y80.00 Z800.00 E130.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z1200.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X350 Y350 Z400 S0 ; set axis maxima
      M574 X2 S1 P"io1.in" ; configure active-high endstop for high end on X via pin io1.in
      M574 Y2 S1 P"io2.in" ; configure active-high endstop for high end on Y via pin io2.in
      M574 Z2 S2 ; configure Z-probe endstop for high end on Z
      M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
      M558 P9 C"^io4.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-42 Y-20 Z2.503 ; set Z probe trigger value, offset and trigger height
      M557 X15:350 Y15:350 S30 ; define mesh grid
      M308 S0 P"temp1" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp1
      M308 S1 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin temp0
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
      M106 P0 C"Part cooling fan" S0 H1 T45 ; set fan 0 name and value. Thermostatic control is turned on
      M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
      M106 P1 C"Hot-end fan" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
      M950 F2 C"out4" Q500 ; create fan 2 on pin out4 and set its frequency
      M106 P2 C"Motherboard fan" S1 H-1 ; set fan 2 name and value. Thermostatic control is turned off
      M950 F3 C"out9" Q500 ; create fan 2 on pin out4 and set its frequency
      M106 P3 C"Case fan" S1 H-1 ; set fan 2 name and value. Thermostatic control is turned off
      M563 P0 S"E0" D0 H1 F0 ; define tool 0
      M563 P1 S"E1" D1 H2 F0 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      ; Filament runout sensor
      ;M581 E2 T1 S0 C1 ; Filament run-out sensor triggers a pause
      M501
      Thanks in advance for you help
        jay_s_uk @aldiallo
        @aldiallo said in G29 command skipping grid points:
        Your probe offset is -42 in x
        to be able to probe X350, your nozzle needs to be at X392 (350+ the 42 offset). This is outside the maximum axis limits so its skipped.
        If you want to remove those warnings, change your mesh probing to
        M557 X15:300 Y15:320
        aldialloundefined 1 Reply Last reply Reply Quote 1
        • aldialloundefined
          aldiallo @jay_s_uk
          @jay_s_uk
          Thank you, will give that a try.
          • aldialloundefined
            aldiallo
            just tried it and I'm no longer getting the error but now I'm a bit concerned about the results, not sure if this is good or not:
              Is there anything about your bed or probe mount that is different when in that area?
              aldialloundefined 1 Reply Last reply Reply Quote 0
              • aldialloundefined
                aldiallo @Phaedrux
                @phaedrux
                Nothing at first sight, bed look flat to me but what I can say is that the first layer sticks better in the middle and back and also on the front right side, I'm a bit far on the left corner, so need to redo my manual bed level again. This is using the stock bltouch with the stock mount but not the stock glass bed as I replaced it with TH3D EzFlex smooth PEI and a magnetic base
