    Proud of myself....question about Duet 3 Mini 5+
    • RyanPundefined
      RyanP
      So I had a Duet Wifi board die on me. Admittedly it was a clone (I bought two for backups in case something happened to my genuine boards). Well, clones suck. They work temporarily, but suck in the long run.
      So when it died, I decided to buy two Duet 3 Mini 5+ as I like the price by comparison to the Duet 2 Wifi and I wanted to be up to date.
      I am proud that I was able to port my machine over to the Duet 3 firmware and new board without having to rely on this forum. I took my time and read over all the instructions and data. Took me a few days to learn the ins and outs of Duet 3 firmware, I am up and running, and all is good except one thing....noise. The D3M5+ is quite a bit noisier than either my older genuines D2Wifi, or its clone.
      Is there something I should be adding to my Config.g to quiet it down?
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Jul 11 2021 21:02:44 GMT-0400 (Eastern Daylight Time)
      M550 P"Mr. Orange"                                 ; set printer name
      H564 H0
      ; NETWORK
      M552 S1                                           ; enable network
      M586 P0 S1                               		  ; enable HTTP
      M586 P1 S0                               		  ; disable FTP
      M586 P2 S0							     		  ; disable telnet
      M569 P0.0 S0                                      ; physical drive 0.0 goes Forward
      M569 P0.1 S0                                      ; physical drive 0.1 goes forwards
      M569 P0.2 S1                                      ; physical drive 0.2 goes backwards
      M569 P0.3 S1									  ; physical drive 0.3 goes backwards
      M569 P0.4 S1                                      ; physical drive 0.4 goes backwards
      M584 X0.0 Y0.1 Z0.2:0.4 E0.3                      ; set drive mapping
      M350 X16 Y16 Z16 U16 E16 I1						  ; configure microstepping with interpolation
      ; Estep
      M92 X79.88 Y79.77 Z399.95 U399.95 E139.03       ; set steps per mm
      ; Movement Settings
      M566 X600 Y600 Z60 U60 E2000                    ; Jerk mm/min
      M203 X30000 Y30000 Z600 U600 E15000               ; Max Speeds (mm/min)
      M201 X3000 Y3000 Z240 U240 E3000                  ; Max Accell (mm/s^2)
      M204 P5000 T3000                                  ; print and travel accellerations
      m593 F50										  ; dynamic accelleration @ 50Hz
      M906 X1000 Y1400 Z1000 U1000 E1000 I80            ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                           ; Set idle timeout
      ; AXIS LIMITS
      M208 X0 Y0 Z-1 S1                                 ; set axis minima
      M208 X300 Y300 Z400 S0                   		  ; set axis maxima
      M574 X1 S1 P"io5.in"                               ; configure active-high endstop for low end on X via pin !io5.in
      M574 Y1 S1 P"io6.in"                               ; configure active-high endstop for low end on Y via pin !io6.in
      M574 Z0 S2
      M950 S0 C"io3.out"                                 ; create servo pin 0 for BLTouch
      M558 P9 C"^io3.in" H4 F600 T12000 A3 S0.03 B0 R0   ; set Z probe type to bltouch and the dive height + speeds
      G31 P25 X0.7 Y-35.6 Z1.6                          ; set Z probe trigger value, offset and trigger height
      M557 X20:270 S50 Y30:270 S60	                   ; define mesh grid
      M376 H3.56				   						   ; define compensation taper
      M308 S0 P"temp0" Y"thermistor" T100000 B4092       ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
      M307 H0 A111 C921.1 D0.4 V13.1 B0 S1	           ;hotbed pid tuned for 55d
      M308 S1 P"temp1" Y"thermistor" T100000 B4092       ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 A497.7 C148.2 D5.6 V13.3 B0				   ; PID tuning for hotend at 220
      M950 F0 C"out5" Q500                               ; create Heat Sink fan 0 on pin out5 and set its frequency
      M106 P0 S1 H1 T30                                  ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"out3" Q500                               ; create fan 1 on pin out3 and set its frequency
      M106 P1 C"PartCool" S0 H-1                         ; set fan 1 value. Thermostatic control is turned 0ff
      M950 F2 C"out4" Q500                               ; create fan 2 on pin out4 and set its frequency
      M106 P2 C"PartCool" S0 H-1                         ; set fan 2 value. Thermostatic control is turned off
      M563 P0 S"Hotend" D0 H1 F1:2                       ; define tool 0
      M671 X-20:320 Y150:150 S0.5
      M572 D0 S0.05
      M564 H0
      M501                                               ; load saved parameters from non-volatile memory
      undefined
      CR10S, August 2018
      Anycubic Photon S December 2019
      Ender 5 Feb 2020
      Ender 5 Plus May 2020
      Anycubic Photon Mono X Nov 2020
      https://3dimensiongames.com/
      Nurgelrotundefined 1 Reply Last reply Reply Quote 1
      • Nurgelrotundefined
        Nurgelrot @RyanP
        @ryanp Look into V values for your M569 lines... I use 40ish your mileage will vary... read up on what it does set how you want.. etc...
        RyanPundefined 1 Reply Last reply Reply Quote 1
        • RyanPundefined
          RyanP @Nurgelrot
          @nurgelrot
          Thanks so much. It is as quiet as I could ever imaging. Incredible. Now I just need to tune it.
          CR10S, August 2018
          Ender 5 Feb 2020
            Check this out: https://duet3d.dozuki.com/Wiki/Tuning_Stepper_Motor_Drivers
            • o_lampeundefined
              o_lampe
              Seems funny that the default "stealth"Chop mode of Duet3mini is louder than spreadcycle?!
              ...but when it works, it works.
                dc42 administrators @o_lampe
                @o_lampe said in Proud of myself....question about Duet 3 Mini 5+:
                The default is to switch over to spread cycle at a low speed. This is to avoid issues that you can get with missed steps and false short-to-ground warnings on some machines.
                RyanPundefined 1 Reply Last reply Reply Quote 0
                • RyanPundefined
                  RyanP @dc42
                  When I get back to my office later today I may have some further questions to grow my knowledge of proper setting of my config.g as I was experiencing skipped steps.
                  CR10S, August 2018
                  Ender 5 Feb 2020
