    Solved Persistent PanelDue Trouble
    PanelDue
    paneldue firmware troubleshooting
    457
    • redrout
      redrout last edited by
      Hey there,
      I'm having some persistent issues with my paneldue 7i. I updated my Duet 2 Wifi with RRF 3.2.2 a bit ago, and installed the PanelDue, where it did not work. I did a little reading and worked on updating the firmware via bossa with version 3.3.0-rc3. Everything worked correctly, but the PanelDue wouldn't complete a connection with the Duet. I'm using the 4-pin connectors on both the PanelDue and the Duet. I feel like listing what I've attempted would help, so here goes;
      1. checked continuity of the 4-pin cable (it works)
      2. included the M575 P1 S1 B57600 command (tried with other values for Snnn, also tried omitting the command altogether)
      3. Triple-checked the connections with pictures on the paneldue guides (https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update)
      4. installed an older firmware (3.2.0, checked also with the chip on the board with release 3.2.0, mine has ATSAM 4S4B)
      5. Attempted to update that firmware to 3.3.0 following the paneldue guide steps
        The following error message appears
        Error: Failed to communicate with PanelDue bootloader (no START signal received). Please try again or press the Erase and Reset switches on
        PanelDue.
      6. Went round and round a couple times with the erase and reset button and tried the command multiple times
      7. Reinstalled the 3.3.0 paneldue firmware to the paneldue via bossa with the erase and reset procedure (with verification)
      8. Checked the terminals for burns, scratches, blown out caps, etc. basically anything that looked like it shouldn't be there.
      I try to read up and fix things myself, but I'm getting to the end of my rope here? Have I missed something obvious, or do I have something faulty? Thx for any help at all in advance
      (PS I'm not sure why it only allows me to select 'plugins for DWC and DSF category')
        What issues exactly are you having? What isn't working? Or rather, what is it actually doing? Does the screen light up at all?
        When you have flashed the firmware with Bossa does the screen let you interact with it? Does it display the normal menu items when powered by USB?
        Your Duet firmware should be 3.3.
        Your PanelDue firmware should be either 3.2.11 or 3.3 RC3 if you want to try testing.
        Which firmware file specifically did you use to flash the Panel?
        M575 P1 S1 B57600 must be in config.g for it to work.
        How are your wires ordered for the 4 pin connector? Did you make the cable yourself or did it come with the Panel? When you plug it in and power on does it power up as well?
        redrout 1 Reply Last reply Reply Quote 0
        • redrout
          redrout @Phaedrux last edited by
          @phaedrux Thanks for the help, I'm going to flash the paneldue firmware to 3.3 RC3 and check up on it.
          The problem i'm facing with the paneldue is that it boots up, shows me the logo, and then displays the 'connecting' status in the upper right hand corner, as if it's not receiving any data from the duet.
          It should be noted that I can home axes from the paneldue, but that appears to be all I can do. I can't heat the extruder.
          The cable is one I got with one of my stepper motors that I terminated with the connectors I got with the duet. I've checked the continuity and wire configuration of the cables multiple times, everything is as presented in the paneldue guide.
          I'll follow up on this soon, I've got a fairly long job on the printer at the moment, I'd like to try everything you suggested before I ask for any further help.
          Again, thanks a million for any help,
          RBIII
          mfs12 1 Reply Last reply Reply Quote 0
          • mfs12
            mfs12 @redrout last edited by mfs12
            Hey @redrout, this problem sounds a little strange. If g-codes are working in general, i.e. homing gcodes, then other communication should work as well.
            You are using Paneldue firmware 3.3.0-rc3 on a Paneldue 7.0i.
            Please upload a copy of your configuration.
            And please test the following commands and post the reply.
            M115
            Visit me on github at https://github.com/mfs12/
            • redrout
              redrout @mfs12 last edited by
              Right, thanks a ton for waiting lol.
              The output of the M115 command is as follows:
              FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03
              My config file is as follows:
              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue May 25 2021 23:51:34 GMT-0500 (Central Daylight Time)
              M550 P"*****" ; set printer name
              M551 P"*****" ; set password
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P0 S0 ; physical drive 0 goes backwards
              M92 X80.00 Y80.00 Z1590.00 E420.00 ; set steps per mm
              M566 X90.00 Y90.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X8000.00 Y8000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
              M201 X50.00 Y50.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
              M906 X1100 Y2200 Z800 E700 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X640 Y540 Z1000 S0 ; set axis maxima
              M574 Z1 S1 P"!zstop" ; configure active low endstop for low end on Z via pin zstop
              ; M574 Z1 S2 ; configure z to use a probe at the min
              ;M558 P9 C"^zprobe.in" H3 F100 T2000 ; specify probe and input pin, also enable pullup resistor
              ;M557 X15:20 Y15:195 S20 ; define mesh grid
              ;G31 P100 X10 Y10 Z2 ; define offset and sensitivity for bltouch
              ;M950 S0 C"exp.heater3" ; create servo pin index
              M308 S1 P"e0temp" Y"pt1000" ; configure sensor 1 as thermistor on pin e0temp
              M307 H3 A-1 C-1 D-1 ; unbind heater pin 3 for use in bltouch
              M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
              M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
              M563 P1 D0 H1 F1 ; define tool 1
              G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
              G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
              I'm still learning a lot, so let me know if I've botched the configuration.
              Thanks
              Phaedrux dc42 2 Replies Last reply Reply Quote 0
                Phaedrux Moderator @redrout last edited by
                @redrout said in Persistent PanelDue Trouble:
                Well the only line that matters for PanelDue is the enable command which you already have, so no problem there.
                • mfs12
                  Hey @redrout, as @Phaedrux mentioned your configuration looks ok.
                  • Are there any errors displayed in PanelDue's console tab?
                  • How long is the cable form PanelDue to Duet2?
                    dc42 administrators @redrout last edited by
                    @redrout if you can send commands to the Duet then transmission from PanelDue to Duet must be working. So most likely there is a problem with the wire that connects UTXD on the Duet to DIN on the PanelDue.
                    • redrout
                      redrout last edited by redrout
                      Thanks for the replies, I did some more reading, and replaced the cable with a shorter one (4 feet before to 6 inches or so now). I tested the current cable and it looks good, but the issue still persists (can still send commands but stuck connecting). On the off chance I had a bad wire again I swapped the UTXD - DIN wire with the URXD - DOUT wire on the terminals and tried again, but the same problem happens. I looked at some of the traces on the duet and the paneldue, but nothing looks obviously amiss.
                      • mfs12
                        mfs12 last edited by mfs12
                        Hey @redrout,
                        • are there errors in the console tab?
                        • what state does paneldue report in the top right corner?
                        • redrout
                          @mfs12 The console tab doesn't display anything, even if I do send commands to the board via the PanelDue. The PanelDue reports "Connecting"
                          thx
                            It definitely sounds like it's just not connecting, though seems to be functional otherwise and you're able to flash the firmware, etc.
                            Your config looks ok, it just needs the command to enable it and set the baud rate. Have you verified in the setup page of the paneldue that the baud rate is set to match the config? 57600?
                            • mfs12
                              Hey @redrout, did you send the M115 command from DWC or PanelDue?
                              If PanelDue reports "connecting" the connection was not yet established. This points to either a physical connection problem (cabling or sockets) or not matching uart configuration of the Duet3d board and PanelDue.
                              To improve debugging such problems in future i will consider improving error reporting about connection issue in PanelDue's message log.
                              • redrout
                                @mfs12 I appreciate the improvement potential, but is there any way for me to resolve this issue on my end? I just don't know what to do with my paneldue now, since it doesn't receive information it seems to be little better than a paperweight.
                                  Are you able to test with a new shorter 4 wire cable and/or the 10 pin ribbon cable?
                                  When and where did you purchase the PanelDue?
                                  • mfs12
                                    Hey @redrout,
                                    closing this thread due to inactivity. Please re-open if your issue persists with newer version of paneldue.
