    Extruder E1 not working
    711
    • jackd2282undefined
      jackd2282
      I accidentally burn the driver 3 for extruded motor on my duet wifi. I have cut out the driver and stopped the error messaging. Now I can’t get the extruder motor to work on E1. I added M569 P4 S1, switched M584 to E4, switched M308 to E1, and switched M950 to E1. On the tools it has M563 P0 H1 F1 and if I try to change to M563 P0 D1 H1 than it removes the hotend tool from the interface. I am getting no power to the extruder stepper motor even with cold extrusion on. Maybe e1 is broke too. I don’t know. Any suggestions? And would adding an expansion board replace the burnt driver? I hate to replace this board I just bought and it seems like there should be a way to work around it.
      jackd2282undefined 1 Reply Last reply Reply Quote 0
        jackd2282 @jackd2282
        @jackd2282 ; Configuration file for Duet WiFi (firmware version 3)
        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Aug 02 2021 02:19:39 GMT-0500 (Central Daylight Time)
        M550 P"My Printer" ; set printer name
        M669 K1 ; select CoreXY mode
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M569 P3 R-1 ; disable drive 3 and stop monitoring
        M569 P4 S1 ; physical drive 4 goes forwards
        M584 X1 Y0 Z2 E4 ; set drive mapping
        M92 X80.00 Y80.00 Z400.00 E98.00 ; set steps per mm
        M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X6000.00 Y6000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
        M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
        M906 X950 Y950 Z950 E700 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X250 Y250 Z400 S0 ; set axis maxima
        M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
        M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
        M557 X15:215 Y15:195 S20 ; define mesh grid
        M308 S1 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e1temp
        M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
        M563 P0 H1 F0 ; define tool 0
          If it was just the driver that failed, you didn't need to change the heater bindings as well, but if you want to, that's fine, just remember to move the actual cable connections also.
          Your tool definition is missing the D0 to tell it to use the first defined extruder. I thnk this is the main problem. You should have M563 P0 D0 H1 F1
            jackd2282 @Phaedrux
            @phaedrux when I do that the hotend disappears from the ui
              @jackd2282 also I did move the cables and heat works fine
                Can you send M122 and M98 P"config.g" in the Gcode console in DWC and post the results?
                Can you confirm what version of DWC you are using as well?
                jackd2282undefined 2 Replies Last reply Reply Quote 0
                  jackd2282 @Phaedrux
                  @phaedrux I am at work till morning but I will then
                  • chrishammundefined
                    chrishamm administrators @jackd2282
                    @jackd2282 You don't assign the extruder to the first tool so that doesn't seem right. Change back to M563 P0 D0 H1 F0 ; define tool 0 and then rerun config.g as Phaedrux suggested.
                    Duet software engineer
                      jackd2282 @Phaedrux
                      @phaedrux on the expansion board if I can’t get this sorted is that an option instead of a new board?
                        jackd2282 @chrishamm
                        @chrishamm when I change to that it removes the hotend from the interface for some reason
                          @chrishamm also that line is from the repeal config tool where I put the extruder to E1 as well as the hotend
                            @jackd2282 reprap config
                              @jackd2282 With the M584 code from your config.g you map driver 4 to extruder drive 0, so it should be possible to use M563 P0 D0 H1 F0 as well. If no tool shows up, rerunning config.g with M98 P"config.g" as suggested by Phaedrux will show why it does not work.
                                @chrishamm said in Extruder E1 not working:
                                M98 P"config.g"
                                I tried M563 P0 D0 H1 F0 and M563 P0 D0 H1 F1 because both were mentioned and while the tool interface now stays on both for the hot end and M98 P"config.g" showsM98 P"config.g"
                                HTTP is enabled on port 80
                                FTP is disabled
                                TELNET is disabled
                                when I heat up the hotend to 195c to get both extrusion and retraction buttons to become available i get Warning: motor phase A may be disconnected reported by driver(s) 4
                                Warning: motor phase B may be disconnected reported by driver(s) 4 with multiple
                                with multiple stepper motors
                                  Can you send M122 and provide the results?
                                  How did you "burn" driver 3?
                                  Can you provide some photos of the board? Especially close ups of the drivers?
                                    jackd2282 @Phaedrux
                                    @phaedruxM122
                                    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
                                    Board ID: 08DLM-996RU-N85S4-7JKD2-3SN6K-1U97R
                                    Used output buffers: 3 of 24 (23 max)
                                    Static ram: 23876
                                    Dynamic ram: 75020 of which 24 recycled
                                    Never used RAM 15496, free system stack 184 words
                                    Tasks: NETWORK(ready,6.0%,246) HEAT(delaying,0.0%,314) Move(notifyWait,0.1%,364) MAIN(running,93.9%,441) IDLE(ready,0.0%,29), total 100.0%
                                    Owned mutexes: WiFi(NETWORK)
                                    Last reset 00:01:42 ago, cause: software
                                    Last software reset at 2021-08-03 14:09, reason: User, GCodes spinning, available RAM 15496, slot 2
                                    Error status: 0x00
                                    Step timer max interval 0
                                    MCU temperature: min 23.4, current 24.5, max 24.8
                                    Supply voltage: min 27.1, current 27.3, max 27.4, under voltage events: 0, over voltage events: 0, power good: yes
                                    Driver 0: position 0, standstill, SG min/max not available
                                    Driver 1: position 0, standstill, SG min/max not available
                                    Driver 2: position 0, standstill, SG min/max not available
                                    Driver 3: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
                                    Driver 5: position 0
                                    Driver 6: position 0
                                    Driver 7: position 0
                                    Driver 8: position 0
                                    Driver 9: position 0
                                    Driver 10: position 0
                                    Driver 11: position 0
                                    Date/time: 2021-08-03 14:10:58
                                    Slowest loop: 7.65ms; fastest: 0.17ms
                                    === Storage ===
                                    Free file entries: 10
                                    SD card longest read time 2.0ms, write time 0.0ms, max retries 0
                                    === MainDDARing ===
                                    === AuxDDARing ===
                                    Segments left: 0
                                    Movement lock held by null
                                    HTTP is idle in state(s) 0
                                    Telnet is idle in state(s) 0
                                    File is idle in state(s) 0
                                    USB is idle in state(s) 0
                                    Aux is idle in state(s) 0
                                    Trigger is idle in state(s) 0
                                    Queue is idle in state(s) 0
                                    LCD is idle in state(s) 0
                                    Daemon is idle in state(s) 0
                                    Code queue is empty.
                                    === Network ===
                                    Slowest loop: 202.62ms; fastest: 0.08ms
                                    HTTP sessions: 1 of 8
                                    • WiFi -
                                      Network state is active
                                      Failed messages: pending 0, notready 0, noresp 1
                                      WiFi firmware version 1.26
                                      WiFi MAC address 8c:aa:b5:c2:16:2b
                                      WiFi Vcc 3.38, reset reason Turned on by main processor
                                      WiFi flash size 4194304, free heap 26952
                                      WiFi IP address 192.168.1.140
                                      WiFi signal strength -71dBm, mode 802.11n, reconnections 0, sleep mode modem
                                      Clock register 00002002
                                    jackd2282undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                      @jackd2282 I hooked up my new bondtech ddx and my guess is that the motor was wired wrong cause it got hot then the driver burned
                                        Phaedrux Moderator @jackd2282
                                        @jackd2282 said in Extruder E1 not working:
                                        Driver 3 is definitely damaged.
                                        And it sounds like you still have the motor wired incorrectly.
                                        Carefully identify the motors phase pairs first before wiring them up again.
                                        https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
                                          jackd2282 @Phaedrux
                                          @phaedrux I made sure the phases are right and tried all 4 combinations on the motor. No luck. Maybe E1 is also damaged?
                                            Possibly, or the damage to driver 3 is also preventing driver 4 from working.
                                            @phaedrux said in Extruder E1 not working:
                                            Do you notice any damage or pock marks?
