    Spindle not showing in DWC-CNC RRF3 on Duet WiFi
    CNC
    spindle control m950 web control tool cnc speed control setup cnc setup duet wifi
    2.6k
    • cjmundefined
      cjm @Wurke
      @Wurke I have the same issue. My spindle responds to M3/M4/M5 correctly but is not shown on DWC, although it was in a previous version.
      Interestingly, the object model reports the spindle's state correctly (i.e. shows the selected RPM and whether it is running, stopped etc) but always reports "configured = false":
      I suspect that DWC sees "configured = false" and then decides not to show any information in the spindle panel.
      Wurkeundefined chrishammundefined 2 Replies Last reply Reply Quote 0
      • Wurkeundefined
        Wurke @cjm
        @cjm That sounds likely. How do I access the objects model? Is it worth adding this as an issue on the Github? It's not currently on there. Just as a reminder.
        cjmundefined 1 Reply Last reply Reply Quote 0
        • cjmundefined
          cjm @Wurke
          @Wurke Its available under the Settings menu item in DWC:
          I've raised the issue with @sindarius who generated the CNC version of DWC and understand he's working on a fix.
          However, it's not entirely clear to me whether the root cause for the issue lies with DWC or the Duet firmware so perhaps worth raising on the Github.
          • Wurkeundefined
            Wurke
            @cjm odd. I don't have object model in the side bar.
            • cjmundefined
              cjm @Wurke
              @Wurke Maybe we're using different versions of DWC ?
              Wurkeundefined 1 Reply Last reply Reply Quote 0
              • Wurkeundefined
                Wurke @cjm
                @cjm mine shows as Duet Web Control 3.3.0-CNC07
                • cjmundefined
                  cjm @Wurke
                  @Wurke Interesting, so does mine...
                  • cjmundefined
                    cjm @cjm
                    @cjm I've just noticed that the CNC version of DWC has been merged into the latest "mainstream" DWC beta [Duet Web Control 3.4-b2] and have loaded this, but the spindle is still invisible.
                    I can see the object model menu in this new version so perhaps worth your trying this?
                    • cjmundefined
                      cjm @dc42
                      @dc42 I've tried placing M453 before and after the spindle configuration but the spindle is still not shown in DWC.
                      Although my spindle appears to be configured correctly in that it responds properly to M3/M4/M5 and the object model shows the RPM and spindle state , I note that the object model always reports spindle "configuration = false".
                      Could it be that this is why DWC doesn't display the spindle state on the Dashboard?
                      • Wurkeundefined
                        Wurke @cjm
                        @cjm Updated that. Still nothing. So frustrating. Its probably all working but the UI is letting everything down.
                        • cjmundefined
                          cjm @Wurke
                          @Wurke I believe that to show the object model, you need to enable the "Object Model Browser". This is found under the "Integrated Plugins" section of the General Settings page:
                          • Wurkeundefined
                            Wurke
                            @cjm I almost asked if it was a plugin. Got it. I can now see that under spindle I have the same as you. configured = false. The other values match my config.g
                            R4ffersundefined 1 Reply Last reply Reply Quote -1
                            • R4ffersundefined
                              R4ffers @Wurke
                              @bonjipoo evening guys, mine also shows the same under the object model. I do have a spindle section under the DRO section in the UI but doesn't show any info.
                              Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
                              • chrishammundefined
                                chrishamm administrators @cjm
                                @cjm @Sindarius spindle.configured is a left-over property from an earlier RRF version and it has been replaced with state -> unconfigured. I'll make sure it will be removed from the next DWC version.
                                Duet software engineer
                                Sindariusundefined 1 Reply Last reply Reply Quote 0
                                • Sindariusundefined
                                  Sindarius @chrishamm
                                  There is a new version of the DWC-CNC with an updated spindle panel
                                  https://github.com/Duet3D/DWC-CNC/releases/tag/3.3.0-CNC08
                                  Future updates will be done on the main Duet Web Control
                                  cjmundefined R4ffersundefined Wurkeundefined 4 Replies Last reply Reply Quote 2
                                  • cjmundefined
                                    cjm @Sindarius
                                    @sindarius Thank you! I’ll try it when I’m back after the weekend.
                                    • R4ffersundefined
                                      R4ffers @Sindarius
                                      @sindarius woo hooo it works, thanks much appreciated.
                                      Wurkeundefined 1 Reply Last reply Reply Quote 1
                                      • Wurkeundefined
                                        Wurke @R4ffers
                                        @r4ffers How do you update this? Do you need to replace files directly on the SD card?
                                        R4ffersundefined 2 Replies Last reply Reply Quote 0
                                        • R4ffersundefined
                                          R4ffers @Wurke
                                          @wurke ,Good afternoon. I just went to duet on GitHub, the CNC dwc is on there. Click on latest and download. If you're running in SBC mode then go to general and click GitHub from there. Upload downloaded zip.
                                          • R4ffersundefined
                                            R4ffers @Wurke
                                            @wurke u may need to do M997 also, can't remember
