    Steel Hotbed with iso like grids and induction heating?
    • gallaghersartundefined
      gallaghersart
      Is there a reason why hotbeds are not steel? Besides cost?
      On the pro side
      • whole bed can be magnetized to allow hotter beds
      • Electric induction cooktop heaters can be attached to bottom with metal screws / no glue
      • much less warping than aluminum
      Attached is a quick image of the bottom of steel bed. Just to give ides of a type of grid pattern. NOT finial. Induction heaters would be screwed on at the internal holes. Bed is 500mm x 500mm usable, 580mm x 580mm actual size. The larger holes on the sides are for future top side attachmentsGallaghersArt_magbed_01_500x500.jpg
      Falkiaundefined 1 Reply Last reply Reply Quote 0
      • Falkiaundefined
        Falkia @gallaghersart
        @gallaghersart aluminum has better conductivity compared to steel and regarding warping I think a cast and milled aluminum plate is better than steel. I think your idea is interesting.
        Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
        • oliofundefined
          oliof
          Reminds me of Dr. Bowyer's idea of a solenoid heated bed.
          • BoAundefined
            BoA
            I think aluminium heatbed can be also induction heated.
              Phaedrux Moderator @BoA
              @boa Aluminum works poorly with induction heating.
                gallaghersart
                *** FYI, By Posting this and other Ideas on this website, my personal websites and others I hereby say this is open source and forgo any patent rights so all can use. Acknowledgment would be nice, but not required.
                thanks!
                `mike
