Automatic Tool Offset (XYZ) for Syringe Printer?
Using Duet Controllers
1.4k
  • undefined
    HebigT
    undefinedI've turned an E3D Toolchanger into a Syringe dispensing printer. I'm dispensing materials with viscosities similar to silicone caulking.
    One major difference between my printer and an FFF printer is that nozzle changes are frequent - typically before each print to ensure reliable dispensing.
    Does anyone think automatic tool offsets can be done using optical endstops for X, Y and a physical endstop for Z? I have several of these, which I've confirmed to work on 3.3V:
    https://www.ia.omron.com/product/item/2263/
    Z is the most straight forward, since I can just mount a switch somewhere on the buildplate and have the tool tip actuate it.
    For X and Y, one commercial syringe printer uses a "LASER Beam Break" sensor. The nozzle is automatically jogged to break the x-axis sensor beam, same for the y-axis, and then the nozzle center is calculated. This gave me the idea of using the optical endstops.
    For implementing in firmware, is M585 a good place for me to start?
    https://duet3d.dozuki.com/Wiki/Gcode#Section_M585_Probe_Tool
    Here's how the syringe tips look:
    I've tried TAMV, and I use it for my FDM printer, but it proved to be unreliable for the syringe tips which are different sizes and colors, and the camera I use can't detect the nozzle center reliably.
    Firmware: V3.3 on Duet 2 Ethernet
    I appreciate any feedback!
    undefined 1 Reply Last reply 20 Aug 2021, 19:58 Reply Quote 0
    • undefined
      Phaedrux Moderator @HebigT
      @hebigt said in Automatic Tool Offset (XYZ) for Syringe Printer?:
      That sounds like the best place to start. Though I think in CNC applications they are using a ring shaped metallic sensor that will trip the switch when it makes contact with the conductive tool tip. Not sure how it would work with multiple switches for X and Y.
      Is there much X/Y variation between tips once they are mounted?
      undefined 1 Reply Last reply 21 Aug 2021, 01:01 Reply Quote 1
      • undefined
        HebigT @Phaedrux
        @phaedrux Thanks for the reply. I'll give this a try and update with what happens.
        Some of the tips are straight, but others deviate across their length by 1mm, sometimes more or less. But they are inexpensive, which is a plus.
        • undefined
          supahobnobba
          hi @hebigt!
          Having recently done this on a multi-material syringe extruder, I can confirm that M585 is a method that works. Originally, we started down the path with optical sensors but couldn't find something that fit the budget (as cheap and quick as possible).
          Our solution:
          • Use a USB microscope , similar to TAMV in that it is in the upright position, and hook it up to a PC.
          • Take the usb feed and overlay a crosshair on it.
          • Using a macro, step over to the center of T0's needle and store X0, Y0 using G10
          • Macro should move the nominal amount between needles (calculate in CAD or eyeball it so T1 is in the camera's view)
          • Step into the center of T1's needle and store that with G10 as well.
          I've seen better than 20um accuracy with this method. If the needle isn't straight, either bend it, reseat it on the luer, or toss it for another one.
          For Z, as mentioned by @Phaedrux, we used a simple block of aluminum and alligator clip to the needle to make a conductive sensor. Do the Z before the XY tool offset to ensure both tools are on the same plane.
          Happy to dive in a little deeper but unfortunately can't share pictures of our setup.
          undefined 1 Reply Last reply 5 Sept 2021, 23:02 Reply Quote 2
          • undefined
            HebigT @supahobnobba
            @supahobnobba
            Great to hear from you and thanks for sharing your experience with it. The method you described is what I ended up doing, and it has worked well for us. I still want to try the optical endstop + M585 route when I find some time. I salvaged the optical sensors from a decommissioned piece of equipment.
            I even designed a mount for all three sensors. No Idea if it will work, though. Especially with the very small contact point on the z-axis switch in the middle.
            Thanks again!
            • undefined
              HebigT
              @Phaedrux @supahobnobba
              Update:
              The automatic 'offsetting' for the Tool's syringe tip length (Z offset) works very reliably.
              The X and Y offset has some issues but I think it can be tweaked to make it work.
              M585 works, but not in the way I expected. It sets the offset to (starting position - ending position) + expected distance.
              Videos:
              Auto Z-offset
              Auto XY Offset
              I ended up using meta-commands to get this far, and I think it could be done with G30 (for Z-offset) and G1 H4 commands instead of using M585.
              ? 1 Reply Last reply 9 May 2022, 23:11 Reply Quote 1
              • undefined HebigT marked this topic as a question 9 May 2022, 18:14
              • undefined HebigT marked this topic as a regular topic 9 May 2022, 18:24
                A Former User @HebigT
                @hebigt
                Hey
                Could you share some information about the meta command?
                I'm also want to have a tool endstop but couldn't find out which commands I have to use, so that the offset applies automatically.
                Thanks a lot!!
                Richard
                undefined 1 Reply Last reply 10 May 2022, 15:28 Reply Quote 0
                • undefined
                  HebigT @A Former User
                  @gruna-studio
                  Hey, I used the meta commands outlined here:
                  https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands
                  and the object model ( the object model plugin for DWC was very helpful)
                  For the most part, I just needed to reference the position of an axis once it hit the endstop, initialize a variable for it, and then use that variable later on.
                  For example, for the z-axis, the printer first homes to the buildplate with a microswitch to set zero, but each tool has a syringe tip which sits below that microswitch. Also, the "Z-axis offset switch" is mounted on that printed part which makes it sit some unknown distance above the buildplate.
                  I figured out that distance by jogging the tool until it actuated the switch (M119 to check endstop status), and then moved the tool off the switch and measured down to the buildplate.
                  The macro I use does this:
                  1. Home the printer
                  2. Define the new Z-axis endstop
                  3. Pick up the tool
                  4. move the tool over the switch
                  5. Move the Z-axis until the syringe tip hits the switch (M585)
                  6. Store the current position as a variable
                  7. Do some simple math to figure out how far down the syringe tip is from the Z-axis homing switch (not the offset switch), using the measured height of the switch+mount and the known current position.
                  8. Assign that new value to the offset for that tool (G10...)
                  9. Save the offset to config-override.g with M500
                  One tip: Use M114 in the console to view the current axis position with more decimals places.
                  ? 1 Reply Last reply 10 May 2022, 17:29 Reply Quote 1
                    @hebigt
                    Thanks a lot for this detailed description!!
                    I'll try it out ASAP.
                    That will make my workflow a lot better.
                    Edit: I've never used meta data's before. Is there an example for it concerning the tool switch?
                    For the x and z axis I'll install a camera cased automatic offset.
                    I'll open a new thread when this happend
                    Richard
                    undefined 1 Reply Last reply 10 May 2022, 21:58 Reply Quote 1
                    • undefined
                      @gruna-studio
                      What type of machine are you using? Printer or CNC or something else?
                      Unfortunately, I can't share the macro I wrote, but I promise it's nothing special.
                      For meta commands I searched the forum for examples and then practiced using the console in DWC.
                      That Meta command link is very helpful. And here's an explanation of the object model:
                      https://duet3d.dozuki.com/Wiki/Object_Model_of_RepRapFirmware
                      Examples with syntax:
                      ; Initialize a variable
                      var offset_thickness = 14 ;Units are mm
                      ; Initialize a variable to some existing value in the object model, such as the current position of the z-axis
                      var z_position = move.axis[2].machinePosition ; The 2 gives the index # for the z-axis on my printer
                      ; Write an existing variable to the console
                      echo var.z_position
                      ;  Update the tool offset with an existing variable
                      G10 P0 X0 Y0 Z{var.z_position}
                      Conditional statements are also possible
                      ; if statement to alert the machine operator if the tool offset is unusually small
                      if tools[0].offsets[2] > -20.0
                          M291 P"The Z-offset for Tool 0 is smaller than expected. Ensure the syringe barrel is properly seated in the mount" R"Warning!" S1 T0
                      ? IndeX4Dundefined 2 Replies Last reply 11 May 2022, 03:10 Reply Quote 0
                        This post is deleted!
                        • IndeX4Dundefined
                          IndeX4D @HebigT
                          @hebigt
                          I made a new account because its going professional, now.
                          Thanks for your fast reply. I think I'll work it out. This short example is quiet helpful!!
                          I have two custom toolchanger with a 103x103x103cm built volume with
                          lovely closed loop steppers.
                          undefined 1 Reply Last reply 11 May 2022, 15:32 Reply Quote 2
                          • undefined
                            HebigT @IndeX4D
                            @index4d
                            Exiciting!
                            Looking forward to following your progress.
                            IndeX4Dundefined 1 Reply Last reply 16 May 2022, 13:32 Reply Quote 0
                            • IndeX4Dundefined
                              IndeX4D @HebigT
                              Short question... till I have more time for this meta commands, I´ll work with M585, but I have alwayyys the problem, that Duet could´nt find the new zstop.
                              Please take a quick look where my mistake is.
                              Thanlks
                              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Aug 02 2021 16:15:35 GMT+0200 (Mitteleuropäische Sommerzeit)
                              G90                                                        ; send absolute coordinates...
                              M83                                                        ; ...but relative extruder moves
                              M550 P"Duet 3"                                             ; set printer name
                              M552 s1
                              M550 P"Black Flamingo"
                              M587 S"AndroidAPebc3_EXT" P"hhhhhhhh"
                              G4 S4
                              M574 C1 S3
                              M574 C0 Z0
                              M915 P0.5 C S0 F0 R1
                              ; Drives ;closed loop
                              M569.1 P20.0 T2 C5 R69 I0 D0 H10            ; Configure the 1HCL board at CAN address.20quadrature encoder 128 steps/motor full
                              M569.1 P21.0 T2 C5 R69 I0 D0 H10           ; Configure the 1HCL board at CAN address.21quadrature encoder 128 steps/motor full step.
                              M569.1 P30.0 T2 C5 R100 I0 D0 H10            ; Configure the 1HCL board at CAN address.21quadrature encoder 128 steps/motor full step.
                              M569 P20.0 D4 S0  ; Configure the motor on the 1HCL at can address 20 as being in closed-loop drive mode (D4) and not reversed (S1)
                              M569 P21.0 D4 S1  ; Configure the motor on the 1HCL at can address 21 as being in closed-loop drive mode (D4) and not reversed (S1)
                              M569 P30.0 D4 S0  ; Configure the motor on the 1HCL at can address 21 as being in closed-loop drive mode (D4) and not reversed (S1)
                              Other drives; open loop;
                              M569 P0.0 S0                                               ; physical drive 0.0 goes forwards
                              M569 P0.1 S0                                               ; physical drive 0.2 goes forwards
                              M569 P0.2 S0                                               ; physical drive 0.2 goes forwards
                              M569 P0.3 S0
                              M569 P0.5 S0
                              M569 P100.0 S1                                              ; physical drive 0.2 goes forwards
                              M569 P110.0 S1                                              ; physical drive 0.2 goes forwards
                              M584 X30.0 Y20.0:21.0 Z0.0:0.1:0.2:0.3 C0.5 E100.0:110.0                         ; set drive mapping
                              M350 X32 Y32 Z128 E16:16:16 I1                                         ; configure microstepping with interpolation
                              M92  X80.00 Y80.00 Z5120.00 C91.022 E409.00:409.00:409.00          ; set steps per mm
                              M566 X600.00 Y600.00 Z60.00 C3000 E1000.00:1000.00:600.00                    ; set maximum instantaneous speed changes (mm/min)
                              M203 X12000.00 Y12000.00 Z500.00 C10000 E6000.00:6000.00:6000.00          ; set maximum speeds (mm/min)
                              M201 X1600.00 Y1600.00 Z500.00 C550 E2500.00:2500.00         ; set accelerations (mm/s^2)
                              M906 X1700 Y1700 Z2300:2300:2300:2300 C600 E1000:1000 I30                      ; set motor currents (mA) and motor idle factor in per cent
                              M84 S300                                                             ; Set idle timeout
                              M671 X-140:-140:990:990 Y-140:990:990:-140 S20 ; leadscrews at front left1 and n´back2. back rigth3 and front4
                              M208 X0 Y-100 Z0 S1                                      ; set axis minima
                              M208 X860 Y860 Z850 S0                                  ; set axis maxima
                              M574 X2 S1 P"^30.io1.in"                                      ; configure active-high endstop for high end on X via pin ^io3.in
                              M574 Y2 S1 P"^20.io1.in+21.io1.in"                                      ; configure active-high endstop for high end on Y via pin ^io1.in
                              ; Z probe
                              M558 P5 C"0.io1.in" H8 F2000 I0 T5000 	; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
                              G31 P200 X0 Y0 Z0	 				    ; Set Z probe trigger value, offset and trigger height; Z probe
                              M556 S50 X0 Y0 Z0                                         ; set orthogonal axis compensation parameters
                              M557 X50:700 Y50:700 S65                           ; define mesh grid
                              ;Tool Switch
                              M558 K1 P5 C"0.io2.in" H8 F2000 I0 T5000 ; create probe #1 for use with M585, active low
                              G31 P200 X0 Y0 Z0
                              M308 S0 P"temp0" Y"thermistor" T100000 B4138               ; configure sensor 0 as thermistor on pin temp0
                              M950 H0 C"out0" T0                                         ; create bed heater output on out0 and map it to sensor 0
                              M307 H0 B0 R0.243 C586.2 D33.87 S1.00 V0                   ; disable bang-bang mode for the bed heater and set PWM limit
                              M140 H0
                              M143 H0 S120
                              M308 S1 P"100.temp0" Y"thermistor" T100000 B4138           ; configure sensor 1 as PT1000 on pin 121.temp0
                              M950 H1 C"100.out0" T1                                     ; create nozzle heater output on out1 and map it to sensor 1
                              M307 H1 B0 R1.553 C487.8 D10.35 S1.00 V0                   ; disable bang-bang mode for heater  and set PWM limit
                              M143 H1 S250
                              M308 S2 P"110.temp0" Y"thermistor" T100000 B4138            ; configure sensor 2 as PT1000 on pin 121.temp0
                              M950 H2 C"110.out0" T2                                         ; create nozzle heater output on out1 and map it to sensor 2
                              M307 H2 B0 R1.553 C487.8 D10.35 S1.00 V0                   ; disable bang-bang mode for heater  and set PWM limit
                              M143 H2 S250                                               ; set temperature limit for heater 1 to 250C
                              M950 F0 C"100.out1" Q500                                   ; create fan 0 on pin 100.out1 and set its frequency
                              M106 P0 S0 H-1                                             ; set fan 0 value. Thermostatic control is turned off
                              M563 P0 D0 H1                                              ; tool uses extruder 0, heater 1
                              M950 F1 C"100.out2" Q500                                   ; create fan 1 on pin 100.out2 and set its frequency
                              M106 P1 S1 H1 T45                                          ; set fan 1 value. Thermostatic control is turned on
                              M563 P0 D0 H1 F1                                           ; tool uses extruder 0, heater 1
                              M950 F2 C"110.out1" Q500                                    ; create fan 2 on pin 101.out1 and set its frequency
                              M106 P2 S1 H-1                                             ; set fan 2 value. Thermostatic control is turned off
                              M563 P1 D1 H2                                              ; tool uses extruder 0, heater 2
                              M950 F3 C"110.out2" Q500                                    ; create fan 3 on pin 101.out2 and set its frequency
                              M106 P3 S1 H2 T45                                          ; set fan 3 value. Thermostatic control is turned on
                              M563 P1 D1 H2 F2                                           ; tool uses extruder 1, heater 2
                              ; Magnete
                              M950 F8 C"0.out8" Q500 CMagnet0                              ; create magnet 0  on pin out9 and set its frequency
                              M950 F9 C"0.out7" Q500 CMagnet1                              ; create magnet 0  on pin out9 and set its frequency
                              M950 F10 C"21.out0" Q500 CMagnet2                           ; create magnet 0  on pin out9 and set its frequency
                              M950 F11 C"21.out1" Q500 CMagnet3                           ; create magnet 0  on pin out9 and set its frequency
                              M563 P0 D0 H1 F0                                           ; define tool 0
                              G10 P0 X-9 Y-39 Z-3.65                                             ; set initial tool 0 active and standby temperatures to 0C
                              G10 P0 R0 S0
                              M563 P1 D1 H2 F2                                          ; define tool 1                                          ; set initial tool 0 active and standby temperatures to 0C
                              G10 P1 X-8.4 Y-39.2 Z-4
                              G10 P1 R0 S0
                              M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"         ; set voltage thresholds and actions to run on power loss
                              G1 X660.2 Y100 Z100 F3000
                              G1 X660.2 Y-60.1 F3000
                              M585 Z120 F600 P1 S1
                              thanks a lot!
                              undefined 1 Reply Last reply 16 May 2022, 14:31 Reply Quote 0
                              • undefined
                                HebigT @IndeX4D
                                @index4d
                                I see you have some endstop definitions in your config.g (M574), but I don't immediately see where you are defining the new Zstop - are you trying to set it up as you would a z-probe?
                                In my approach, I just set up the new "z-stop" as an additional endstop.
                                M574 Z0 P"zstop" S1
                                Note that I'm using Firmware 3.4 and a Duet 2.
                                IndeX4Dundefined 1 Reply Last reply 17 May 2022, 11:12 Reply Quote 0
                                • IndeX4Dundefined IndeX4D referenced this topic 16 May 2022, 22:27
                                • IndeX4Dundefined
                                  IndeX4D @HebigT
                                  @hebigt
                                  thanks a lot for your fast reply!
                                  you´re doing the most effizient posts 😄
                                  • undefined
                                    HebigT
                                    I think I can close out this thread now
                                    Both the Automatic Z and XY offset are working.
                                    For XY offsets (using the optical endstops) I had to probe each side of the syringe tip - i.e. probe the tip on both sides in the x direction, probe both sides in the y-direction... I think this is how some dual extruder FDM printers set the XY offsets.
                                    I used gcode meta commands to query current machine positions and then referenced those values later on. Every now and then I used an IF statement to check whether a variable already exists.
                                    I used a USB microscope to check the syringe tip alignment across tools and it looks good.
                                    For anyone coming across this in the future, I used Fisnar tapered tips and blunt-end steel tips. I found that some plastic tapered tips didn't work well with the optical endstops. (Blue, pink, orange colored tips might be more transparent to gallium-arsenide LED?). The steel, blunt-end tips work great.
                                    • undefined HebigT marked this topic as a question 20 May 2022, 14:53
                                    • undefined HebigT has marked this topic as solved 20 May 2022, 14:53
                                    • undefined HebigT referenced this topic 15 Jul 2022, 19:53
                                    • undefined HebigT referenced this topic 15 Jul 2022, 19:55
