    Beams as stiff as steel
    3D Printing General Chat
    10
    12
    890
    • Falkiaundefined
      Falkia
      Something to test.
      https://3dprintingindustry.com/news/repraps-new-open-source-software-3d-prints-pla-beams-as-stiff-as-steel-194515/
      https://github.com/RepRapLtd/Infinite-Z-Beam
      Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
      • mrehorstdmdundefined
        mrehorstdmd
        Yeah, stiff as steel until they leave them in a parked car...
        deckingmanundefined 1 Reply Last reply Reply Quote 1
        • kb58undefined
          kb58
          They probably mix their units... like, "This PLA beam of size X is as stiff as a bar of steel of size Y."
          Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
          achrnundefined 1 Reply Last reply Reply Quote 0
            https://reprapltd.com/3d-printed-beam-that-is-as-stiff-as-steel/
            • o_lampeundefined
              o_lampe @Phaedrux
              @phaedrux
              the most interesting info in this article was for me, that an infinite Z printer can do these struts without support. I haven't heard of this before. I always try to design things to avoid support, but they are often too chunky because of that.
              • deckingmanundefined
                deckingman @mrehorstdmd
                @mrehorstdmd said in Beams as stiff as steel:
                ,.......or inside a heated printer enclosure.
                • achrnundefined
                  achrn @kb58
                  @kb58 said in Beams as stiff as steel:
                  Actually, it's 'this PLA truss is the same stiffness as a steel section with a low stiffness per unit weight of the same weight'. So it's not completely irrelevant comparison.
                  They've demonstrated, mainly, that trusses are stiffer than solid square sections. If only someone had told Sir John Fowler, messrs Bailey, Pratt, Warren, Fink, ...
                  kb58undefined 1 Reply Last reply Reply Quote 0
                  • kb58undefined
                    kb58 @achrn
                    @achrn Haha, yeah. If they proving anything, it's that the cross sectional shape of materials matters for bending strength, and has little or nothing to do with the material itself.
                    • botundefined
                      bot
                      Stiffness != strength. Stiffness is just the slope of the stress/strain curve: ie, how resistant to bending it is.
                      This would fail at a much lower stress than the steel sample. It would simple resist bending to the same degree as the steel (before the PLA breaks). The steel would not break at anywhere near the stress levels the PLA would.
                      *not actually a robot
                      fcwiltundefined 1 Reply Last reply Reply Quote 4
                      • fcwiltundefined
                        fcwilt @bot
                        @bot said in Beams as stiff as steel:
                        Can you explain "stress" and "strain"?
                          dc42 administrators @fcwilt
                          @fcwilt said in Beams as stiff as steel:
                          Stress ~ applied load
                          Strain ~ movement (e.g. stretching or bending) resulting from applied load.
                          Footnote for pedants: it is sometimes said that person is "under strain" but this is technically incorrect. A person can be under stress or exhibiting strain.
                          achrnundefined 1 Reply Last reply Reply Quote 5
                          • achrnundefined
                            achrn @dc42
                            @dc42 said in Beams as stiff as steel:
                            In the good old days (before Amazon) I once tried to get a bookshop to order 'Roarks Formulas for Stress and Strain' (which is a standard structural engineering textbook) and the assistant outright refused to search for it under engineering, insisting on looking in psychology and psychiatry and related fields. They couldn't find it there in the catalogue so maintained they couldn't order it. I gave up, and found it on the shelf in a better bookshop in a more academic city.
