    Tool change issues after firmware update 1.19.2
    7.1k
    • MrTundefined
      MrT
      Dear
      I have updated the firmware today
      I have notices that the tool change stoped working like it use to
      what is happening is as follow
      when I set tool 0 to active it will go and get tool 0
      when I set tool 0 to standby it will bing tool 0 back
      when I set tool1 to active I will start the script but stop in the middle
      if I go from tool 0 to tool 1 it will keep tool 0 active then stop the scrip in the middle of piking up tool1
      not sure if what I say is understandable
      In the hope to get some feed back
      this issue render my dual tool setup non functional
      Best Regards
      Manuel Topiol
      • T3P3Tonyundefined
        T3P3Tony administrators
        Can you post your tool change macros please, I will try and recreate the issue.
        What version of the firmware did you upgrade from?
        www.duet3d.com
        • MrTundefined
          MrT
          Good Evening T3P3Tony
          Firmware Info
          Firmware Name: RepRapFirmware for Duet WiFi
          Firmware Electronics: Duet WiFi 1.0
          Firmware Version: 1.19.2 (2017-09-01)
          WiFi Server Version: 1.19.2
          Web Interface Version: 1.19
          tfree0:
          G90
          M83
          G91
          G1 Z5 F6000
          G90
          G1 X-15 F6000
          G1 Y180 F6000
          G1 X30 F6000
          G1 X70 F6000
          tfree1
          G90
          M83
          G91
          G1 Z5 F6000
          G90
          G1 X195 Y50 F6000
          G1 Y180 F6000
          G1 X50 F6000
          G1 Y50 F6000
          tpre0
          G90
          M83
          G0 X50 F6000
          G1 Y180 F6000
          G1 X5 F6000
          G1 Y50 F6000
          tpre1
          G90
          M83
          G0 X50 F6000
          G1 Y180 F6000
          G1 X175 F6000
          G1 Y50 F6000
          Its a very strange situation both tools are on stand by if I activate tool1 it will pick tool1 without problem but tool 0 will be the active one
          with firmware 1.18.2 did not have this issue
          thanks for your support
          Best Regards
          Manuel T
          • MrTundefined
            MrT
            Hi again i restored the old firmware and it worked like it use to there is definitively something that changed in the 1.19.2 after selecting tool1, tool0 is the active one
            some help would be appreciated
            also something I have noticed
            in 1.18.2 it was not necessary to add the channel for bed heating if it was connected to a thermistor in 1.19.2 if a don't add the channel it will display 2000 instead of the temperature
            Best regards
            Manuel
              It is documented in the upgrade notes that 1.19 series firmware needs a M305 command for every temperature sensor in use. But you should not need to include the channel in that command, because each heater channel defaults to using its own thermistor.
              What sort of printer do you have: a simple dual nozzle printer, IDEX, or something else?
              Few people use the tpre files. When tpre is run, no tool is selected, which limits what you can do in them. Most people use just tfree and tpost files.
              • MrTundefined
                MrT
                Dear dc42
                I always had a m305 for the sensors , just I noticed after the update the bed temperature was 2000 i checked the cabling and other , after some time I just added the channel and it started working again.
                The printer I have is a ultimate clone that I have build and milled my self ,
                HW
                magnetic tool change with 2 heads and 2 parking spaces
                stepper 0.9 ,
                all moving parts from Misumi
                e3d and titans
                duetwifi and dc42 ir prob
                the issue at hand is not located in the tfree and or tpre or tpost
                I get the same problem when i do the tool change from the slicer extruder start / extruder end or even manually just by clicking on the tool in the duetwifi web interface changing from standby to active from tool0 to tool1
                this issue is not happening on the 1.18.2
                Thanks and best regards
                Manuel Topiol
                • MrTundefined
                  MrT
                  T3p3tony good day
                  By any chance have you been able to reproduce my issue
                  Best regards
                  Manuel
                  • MrTundefined
                    MrT
                    Friendly bump
                    Best regards
                    Manuel
                    • T3P3Tonyundefined
                      I am not at home this weekend, I will try and have a look early in the week. I have an idex machine which is not the same but i might be able to work it out.
                      Am I correct in understanding that the issue is not the movement in any of the tool change macros? The moves to park and pickup the new head work correctly the only issue is when you select T1, T0 remains activated in firmware?
                      www.duet3d.com
                      • MrTundefined
                        MrT
                        Good day
                        yes your assumption is correct
                        Thanks for the help
                        Best Regards
                        Manuel
                        • MrTundefined
                          MrT
                          Dear good night
                          Had a chance to look at my issue ?
                          Thanks
                          Best regards
                          Manuel Topiol
                          • T3P3Tonyundefined
                            Hi, I have tested tool changes using an IDEX machine with the following setup:
                            Using your Tpre,Tfree files, modified only slightly so they do not crash the heads on my IDEX, i can't reproduce the problem.
                            Starting with T0 selected, I enter T1, the movements associated with Tfree0 occur, then the ones in Tpre1. With T1 selected I enter T0, the movements associated with Tfree1 occure, the Tpre0.
                            The selected hotend (as shown in DWC) changes as commanded.
                            Things I am doing differently from you:
                            1. Using an Idex printer so X mapping is different from T0 and T1
                            2. Homing in my Tpre/TFree files to protect the two heads from crashing.
                            www.duet3d.com
                            • MrTundefined
                              MrT
                              Thanks for the reply
                              So from where could this problem come from ?
                              I am out of idea , and I can't understand why with 1.18.2 it's working and not with 1.19.2 ,I changed nothing to my setup 😞
                              Best regards
                              Manuel
                                Please post your config.g file, and confirm that you have no tpost0.g or tpost1.g file.
                                • MrTundefined
                                  MrT
                                  The problem is not associated with movements generated by the tpost tpre and three, the problem is with the tool active and standby
                                  Let's say when I start the printer I home x y and z then I click on tool0 it goes and collects tool0 no problem there ,the tool is loaded and active
                                  When I click again on tool0 it goes to unload and parks the tool0 and put the tool in standby
                                  Now when I go and click on tool1 it goes as expected loading tool1 but after it has collected tool1 it puts tool1 in standby and tool0 as active but the tool1 is still loaded
                                  The result is the same for the 3 test I have made , 1 just by clicking on the web use interface, 2 by sending gcode to the printer , or 3 adding gcode in the slicer to deal with the tool changed , there is no scenario where I can keep my tool1 active
                                  it is definitively something to do with the firmware
                                  I really need some help on this issue
                                  Thanks for your understanding
                                  Best regards
                                  Manuel
                                  • T3P3Tonyundefined
                                    As David says please post your config.g and your T post files (if you have any)
                                    www.duet3d.com
                                    • MrTundefined
                                      MrT
                                      Dear Sorry was on my mobile did not see David's Post
                                      please find her under the config file
                                      M111 S0
                                      G21
                                      G90
                                      M83
                                      M555 P2
                                      M208 X0 Y0 Z-1 S1
                                      M208 X200 Y200 Z306 S0
                                      M574 X1 Z2 S0
                                      M574 Y1 S0
                                      M558 P1 X0 Y0 Z1 H3 F200 T6000
                                      G31 P500 X0 Y0 Z0.3
                                      M557 X10:140 Y10:140 S20
                                      M569 P0 S0
                                      M569 P1 S0
                                      M569 P2 S1
                                      M569 P3 S1
                                      M569 P4 S1
                                      M350 X16 Y16 E16:16 I1
                                      M350 Z16 I0
                                      M92 X160 Y160 Z400 E837:837
                                      M566 X400 Y400 Z15 E100:100
                                      M203 X10000 Y10000 Z2400 E1500:1500
                                      M201 X1200 Y1200 Z200 E3000:3000
                                      M906 X1400 Y1400 Z1300 E1400:1400
                                      M84 S0
                                      M143 H0 S110
                                      M143 H1 S335
                                      M143 H2 S265
                                      M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30
                                      M305 P2 T100000 B4138 C0 R4700 X201
                                      M305 P1 T100000 B4138 C0 R4700 X200
                                      M305 P0 T100000 B4725 C7.060000e-8 R3750 X1
                                      M563 P0 D0 H1
                                      G10 P0 X-19.92 Y-0.20 Z0.0
                                      G10 P0 R0 S0
                                      M563 P1 D1 H2
                                      G10 P1 X19.8 Y0 Z-0.09
                                      G10 P1 R0 S0
                                      M550 PMy printer
                                      M552 S1 ;
                                      M587########################
                                      M586 P0 S1
                                      M586 P1 S0
                                      M586 P2 S0
                                      M106 P2 S0.3 I0 F12 H-1
                                      M106 P1 S1 I0 F100 H-1
                                      M106 P0 S1 I0 F10 H-1
                                      tfree0:
                                      G90
                                      M83
                                      G91
                                      G1 Z5 F6000
                                      G90
                                      G1 X-15 F6000
                                      G1 Y180 F6000
                                      G1 X30 F6000
                                      G1 X70 F6000
                                      tfree1
                                      G90
                                      M83
                                      G91
                                      G1 Z5 F6000
                                      G90
                                      G1 X195 Y50 F6000
                                      G1 Y180 F6000
                                      G1 X50 F6000
                                      G1 Y50 F6000
                                      tpre0
                                      G90
                                      M83
                                      G0 X50 F6000
                                      G1 Y180 F6000
                                      G1 X5 F6000
                                      G1 Y50 F6000
                                      tpre1
                                      G90
                                      M83
                                      G0 X50 F6000
                                      G1 Y180 F6000
                                      G1 X175 F6000
                                      G1 Y50 F6000
                                      thanks
                                      Manuel Topiol
                                      • MrTundefined
                                        MrT
                                        Friendly bump
                                        Best regards
                                        Manuel
                                        • MrTundefined
                                          MrT
                                          Dear dc42 & t3p3tony
                                          Did u have any chance to check on my issue , I am still Struggling with it , I can confirme that the issue is not related with the tfree tpre and tpost , if I disabled them and do the tool change movements via the slicer I get the same result the wrong tool is active when I switch to tool1
                                          In the hope of hearing from you
                                          Best regards
                                          Manuel Topiol
                                          • MrTundefined
                                            MrT
                                            Gentle bump bump
                                            Regards
                                            Manuel
