    Tool Board Heater Tuning Leading To Faults
    101
    5.2k
      Phaedrux Moderator @KevinMar
      @kevinmar said in Tool Board Heater Tuning Leading To Faults:
      M307 H2 R2.063 C316.300:132.500 D6.10 S1.00 V24.3 B0
        M501									; Load config-override.g
      Does that M307 line match what gets loaded by config-override?
      KevinMarundefined 1 Reply Last reply Reply Quote 0
      • KevinMarundefined
        KevinMar @Phaedrux
        @phaedrux always
          And if you execute M98 P"config.g" does it show any errors?
          If you delete config-override.g completely and remove the M307 line entirely from config.g, reboot the board and tune from scratch and save with M500 does it produce the same M307 line?
          • fcwiltundefined
            fcwilt @KevinMar
            boom, fault at 70c
            Drat.
            Does the fault occur when the temp is rising? peaked? dropping?
            Did you leave all the tool boards connected?
            • KevinMarundefined
              KevinMar @fcwilt
              @fcwilt All boards connected, happens ALWAYS when heating up. Never reaches peak or anything
              • fcwiltundefined
                fcwilt @KevinMar
                But it seems to be happening when the cooling fan kicks in?
                Have you changed the temp of the cooling fan to see if the fault tracks that temp?
                How about adding a M570 for that heater and increase the default P parameter value (5) to something like 30.
                • KevinMarundefined
                  KevinMar @fcwilt
                  @fcwilt Yeah, lowered the fan temp to 50, still faulted at about 78C.
                  M750 is at P10, will raise to 30
                  • fcwiltundefined
                    fcwilt @KevinMar
                    I'm interested to see which parameters affect when the fault occurs.
                    It seems we don't know exactly what condition is occurring that is triggering the fault.
                    Does a M122 report anything related to the fault?
                      I'd still like to see a photo of the hotend in case there is something obvious.
                      fcwiltundefined KevinMarundefined 2 Replies Last reply Reply Quote 0
                      • fcwiltundefined
                        fcwilt @Phaedrux
                        @phaedrux said in Tool Board Heater Tuning Leading To Faults:
                        Perhaps you know the answer to this question.
                        He posted a screen shot showing 3 heaters displaying a fault.
                        Does a single heater faulting cause all heaters to display a fault or did all three heaters have to fault at the same time?
                        • KevinMarundefined
                          KevinMar @Phaedrux
                          @phaedrux Ask and you shall receive
                          • KevinMarundefined
                            KevinMar @fcwilt
                            @fcwilt It's a printer with 4 tools, just so happened that the 4th tool continued heating to ~120C before faulting (different M307 parameters). All 4 tools have the issue
                            fcwiltundefined 1 Reply Last reply Reply Quote 1
                              @fcwilt said in Tool Board Heater Tuning Leading To Faults:
                              I can't quite tell from that photo, but is the heater block itself making contact with the body of the extruder, or is there an air gap exposing the heat break?
                              Is there any adjustability on the duct to lower it slightly to direct more air away from the block/nozzle itself?
                              • KevinMarundefined
                                KevinMar @Phaedrux
                                @phaedrux The Hemera tool and V6 hotend are assembled correctly.
                                There is no adjustability to the fan duct, but the ducting is aimed down to the nozzle. It's a fan duct by Rene Jurack, evaluated by an aerodynamicist at BMW 🙂
                                • fcwiltundefined
                                  fcwilt @KevinMar
                                  When the fault occurs have you issued a M122 to see if anything related to the fault is reported?
                                  • KevinMarundefined
                                    KevinMar @fcwilt
                                    @fcwilt
                                    m122
                                    RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                    Board ID: 08DJM-9P63L-DJ3T8-6JKDD-3SD6M-9V4Z9
                                    Used output buffers: 1 of 40 (16 max)
                                    Static ram: 150904
                                    Dynamic ram: 63832 of which 12 recycled
                                    Never used RAM 139444, free system stack 200 words
                                    Tasks: SBC(ready,5.3%,298) HEAT(delaying,0.0%,325) Move(notifyWait,0.0%,302) CanReceiv(notifyWait,0.1%,799) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.4%,93) MAIN(running,87.0%,922) IDLE(ready,0.1%,29), total 100.0%
                                    Owned mutexes: HTTP(MAIN)
                                    Last reset 00:01:48 ago, cause: software
                                    Last software reset at 2021-08-20 13:46, reason: User, none spinning, available RAM 139444, slot 1
                                    Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                                    Error status: 0x00
                                    Step timer max interval 134
                                    MCU temperature: min 38.9, current 39.3, max 39.4
                                    Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                    12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                                    Driver 0: position 0, standstill, reads 14442, writes 16 timeouts 0, SG min/max 0/0
                                    Driver 1: position 0, standstill, reads 14442, writes 16 timeouts 0, SG min/max 0/0
                                    Driver 2: position 0, standstill, reads 14443, writes 15 timeouts 0, SG min/max 0/0
                                    Driver 3: position 0, standstill, reads 14447, writes 11 timeouts 0, SG min/max 0/0
                                    Driver 4: position 0, standstill, reads 14443, writes 15 timeouts 0, SG min/max 0/0
                                    Driver 5: position 0, standstill, reads 14445, writes 14 timeouts 0, SG min/max 0/0
                                    Date/time: 2021-08-20 13:48:32
                                    Slowest loop: 60.53ms; fastest: 0.04ms
                                    === Storage ===
                                    Free file entries: 10
                                    === MainDDARing ===
                                    === AuxDDARing ===
                                    Heater 0 is on, I-accum = 0.2
                                    Segments left: 0
                                    Movement lock held by null
                                    Telnet is idle in state(s) 0
                                    File is idle in state(s) 0
                                    USB is idle in state(s) 0
                                    Aux is idle in state(s) 0
                                    Queue is idle in state(s) 0
                                    LCD is idle in state(s) 0
                                    SBC is idle in state(s) 0
                                    Daemon is idle in state(s) 0
                                    Aux2 is idle in state(s) 0
                                    Code queue is empty.
                                    === CAN ===
                                    Messages queued 1033, received 5285, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 7, free buffers 49 (min 48), ts 545/544/0
                                    Tx timeouts 0,0,0,0,0,0
                                    === SBC interface ===
                                    State: 4, failed transfers: 0, checksum errors: 0
                                    Last transfer: 1ms ago
                                    RX/TX seq numbers: 3860/3860
                                    SPI underruns 0, overruns 0
                                    Disconnects: 0, timeouts: 0, IAP RAM available 0x2c83c
                                    Buffer RX/TX: 0/0-0
                                    === Duet Control Server ===
                                    Duet Control Server v3.3.0
                                    Code buffer space: 4096
                                    Configured SPI speed: 8000000Hz
                                    Full transfers per second: 35.84, max wait times: 5.8ms/0.0ms
                                    Codes per second: 1.10
                                    Maximum length of RX/TX data transfers: 6116/716
                                    • fcwiltundefined
                                      fcwilt @KevinMar
                                      @kevinmar
                                      Thanks for the M122 dump.
                                      Sure would like to know what condition is causing the fault. I'm surprised that information is not being displayed somewhere.
                                      You mentioned that one heater took longer to fault. Were you able to determine what settings were different that might be relevant?
                                      Have you tried disabling the cooling fan to see if it is playing a role in the fault?
                                      • KevinMarundefined
                                        KevinMar @fcwilt
                                        @fcwilt Yes, I've tried disabling the fan.
                                        The heater that took longer to fault had different M307 parameters at that time
                                        • fcwiltundefined
                                          fcwilt @KevinMar
                                          And it still faulted?
                                          Perhaps @dc42 could explain what conditions can lead to a fault.
                                          • bucksurundefined
                                            bucksur
                                            I was trying to point out that R, L and N are the only additional parameters for PT1000 devices.
