    Duet3D 1HCL - Closed Loop Controller Beta test
    Hardware dev
    20
    209
    19.6k
    • A Former User?
      A Former User @tristanryerparke
      @tristanryerparke
      Same here! 🐶
      • T3P3Tonyundefined
        T3P3Tony administrators @wayneosdias
        @wayneosdias depending on where you are some resellers will already have them or will get them shortly.
        www.duet3d.com
        • wayneosdiasundefined
          wayneosdias
          @T3P3Tony Im located in Monterey CA USA, Ive been buying Duet stuff from Matterhackers in SoCal and PrintedSolid. Im willing to buy from any auth'd reseller and will by 4 now, preferebly within the USA...
          elmoretundefined 1 Reply Last reply Reply Quote 0
          • elmoretundefined
            elmoret @wayneosdias
            @wayneosdias https://www.filastruder.com/products/duet-3-expansion-1hcl Plenty in stock at Filastruder.
            wayneosdiasundefined 1 Reply Last reply Reply Quote 1
              wayneosdias @elmoret
              @elmoret Awesome, I just ordered 🙂
              • supertb1undefined
                supertb1 @dc42
                @dc42 Hello;
                I just installed the latest firmware RC1. On my machine it disabled the 1HCL boards and then I installed the v0_3(1) driver and it made my X axis drive into the limit switch and then drive to the end of travel where it stopped. I rolled back to 3+1 and it is working fine with the latest MB6 and web control
                  dc42 administrators @supertb1
                  @supertb1 please see my earlier post in this thread and use the updated files at https://www.dropbox.com/sh/2dt7sbqpx6l74np/AADn4-lpcil1iqnWKkiVri3Ia?dl=0.
                  supertb1undefined 1 Reply Last reply Reply Quote 0
                  • supertb1undefined
                    supertb1 @dc42
                    @dc42 What is the difference between the 1HCL.bin/.map and the v0_3.bin/map?
                      @supertb1 the v0_3 version is for version 0.3 EXP1HCL boards (it has to be renamed to remove the V0_3 suffix). The other is for the version 1.0 boards.
                      • supertb1undefined
                        supertb1 @dc42
                        @dc42 OK so the .3 version was for the original beta boards, and the 1.0 is for the production boards that are being sent out now. I will give these a try and get back to you
                        • DHM-onlineundefined
                          DHM-online @T3P3Tony
                          @t3p3tony we confirm the first batch of 1HCL has just arrived here at Compass DHM projects!
                          Shipping all over Europe: https://www.dhm-online.com/schede-di-controllo/7869-duet-3-expansion-1hcl.html
                          The ones already back-ordered will be ship out today.
                          Customer Care
                          Email: info@dhm-online.com | Phone: +39 049 2701149 | Office hours: Mon - Fri 09.00 - 12.00 / 15.00 - 18.00 | Web-links: https://linktr.ee/DHM_online
                          A Former User? 1 Reply Last reply Reply Quote 1
                          • A Former User?
                            A Former User @DHM-online
                            Hey
                            Short question. Layer shifts are coming from bad tuning?
                            I have hysteresis about 0.25 on the x axis and I have layer shifts. Can this be the reason or do I have to show my g.code?
                            Thanks a lot
                            Richard
                            • T3P3Tonyundefined
                              T3P3Tony administrators @A Former User
                              @gruna-studio can you start a new thread about this. It would be helpful to know the configured closed loop parameters and PID settings you are using. There is an updated release of the tuning plugin that should work with 3.4 RC1 (https://github.com/Duet3D/Closed-Loop-Plugin/releases/tag/v3.4-rc1), please post the step tuning move outcome as well.
                              www.duet3d.com
                              A Former User? 3 Replies Last reply Reply Quote 0
                              • A Former User?
                                A Former User @T3P3Tony
                                @t3p3tony
                                Ok. I'll open a new thread
                                Thanks a lot
                                • A Former User?
                                  A Former User @dc42
                                  This post is deleted!
                                  • A Former User?
                                    • A Former User?
                                      @t3p3tony
                                      Hey
                                      I think I'll try it with different timing.
                                      I use the suggested nema 17 from stepperonline. Can you provide me your M569 T ?
                                      I'm a bit frustrated
                                      KR
                                      Richard
                                      • T3P3Tonyundefined
                                        @gruna-studio I am using the default step timing (i.e. no T parameters in M569)
                                        www.duet3d.com
                                        • samlogan87undefined
                                          samlogan87
                                          @dc42 or @T3P3Tony has stall detection been implemented on these boards? Thinking of getting rid of the end stops if possible
                                          Custom Core-XY
                                            dc42 administrators @samlogan87
                                            @samlogan87 stall detection should work in open loop mode, however RRF cannot yet use stall homing for motors connected to expansion boards.
                                            samlogan87undefined 1 Reply Last reply Reply Quote 0
