    Duet3D 1HCL - Closed Loop Controller Beta test
    Hardware dev
    20
    209
    20.2k
      T3P3Tony administrators @Alex.cr
      @alex-cr we have orders in from at least Filastruder (need to check with the other ones). I hope we will start shipping reseller orders to them next week.
      Alex.crundefined cloudseedsundefined 2 Replies Last reply Reply Quote 2
      • Alex.crundefined
        Alex.cr @T3P3Tony
        @t3p3tony
        Much appreciated!
        Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
        • cloudseedsundefined
          cloudseeds @T3P3Tony
          @t3p3tony Anything for Germany/Europe? I am currently testing 1XD with SERVO42C but that makes little sense if 1HCL is available soon.
          • madmattcoundefined
            madmattco
            Apologies if this was addressed before but I was wondering why the choice of using the 5160 and it's built-in encoder input was not used?
              T3P3Tony administrators @cloudseeds
              @cloudseeds we have dispatched some to Compass-DHM and Dold Mechatronic , I hope both of them will list them soon.
              DHM-onlineundefined cloudseedsundefined 2 Replies Last reply Reply Quote 0
                dc42 administrators @madmattco
                @madmattco the EXP1HCL uses the TMC2160A because it supports the direct coil current control that we need for closed loop node. The TMC2160A does not support an encoder. In any case, reading the encoder using the built-in encoder support in the MCU is faster than reading from the stepper driver over SPI.
                • martin7404undefined
                  martin7404
                  I have a question can I use mini with 1HCL board ?
                  Muldex IDEX Duet2+Duex5
                  Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                  Sapphire Pro with Duet2, with closed-loop motors
                  custom high temp E3D tool changer with Duet2+Duex
                    T3P3Tony administrators @martin7404
                    @martin7404 yes you can use it with any of the Duet 3 Mainboards (6HC, 6XD and Mini 5+)
                    CNCModellerundefined 1 Reply Last reply Reply Quote 0
                    • CNCModellerundefined
                      CNCModeller @T3P3Tony
                      Hi @t3p3tony,
                      Are there any 1HCL units on the way to UK resellers? I've checked E3D and Oozenest and nothing is showing there at the moment.
                      Many thanks
                      Barry M
                      Polar Duet3 Mini + 1HCL
                      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                      Wanhao D4S: Duet2
                      https://forum.duet3d.com/post/296755
                      K40 Laser, Duet2
                      https://forum.duet3d.com/post/312082
                      Wanhao D5S
                      https://www.youtube.com/CNCModellerUK
                        Any one using EXP1HCL boards with firmware 3.4.0RC1, please upgrade the EXP1HCL firmware to 3.4.0RC1+2 available at https://www.dropbox.com/sh/2dt7sbqpx6l74np/AADn4-lpcil1iqnWKkiVri3Ia?dl=0.
                        supertb1undefined 1 Reply Last reply Reply Quote 0
                        • tristanryerparkeundefined
                          tristanryerparke
                          Has there been any progress on simultaneous tuning of two motors driven by individual 1HCL? I’m looking to control a dual motor Y axis gantry with auto squaring.
                          Thanks
                          MaxGyverundefined A Former User? 2 Replies Last reply Reply Quote 0
                          • MaxGyverundefined
                            MaxGyver @tristanryerparke
                            @tristanryerparke said in Duet3D 1HCL - Closed Loop Controller Beta test:
                            Thanks
                            Same Here 😁
                            • wayneosdiasundefined
                              wayneosdias
                              When is the 1HCL slated for production resale?
                                A Former User @tristanryerparke
                                @tristanryerparke
                                Same here! 🐶
                                  T3P3Tony administrators @wayneosdias
                                  @wayneosdias depending on where you are some resellers will already have them or will get them shortly.
                                    wayneosdias
                                    @T3P3Tony Im located in Monterey CA USA, Ive been buying Duet stuff from Matterhackers in SoCal and PrintedSolid. Im willing to buy from any auth'd reseller and will by 4 now, preferebly within the USA...
                                    elmoretundefined 1 Reply Last reply Reply Quote 0
                                    • elmoretundefined
                                      elmoret @wayneosdias
                                      @wayneosdias https://www.filastruder.com/products/duet-3-expansion-1hcl Plenty in stock at Filastruder.
                                      wayneosdiasundefined 1 Reply Last reply Reply Quote 1
                                        wayneosdias @elmoret
                                        @elmoret Awesome, I just ordered 🙂
                                        • supertb1undefined
                                          supertb1 @dc42
                                          @dc42 Hello;
                                          I just installed the latest firmware RC1. On my machine it disabled the 1HCL boards and then I installed the v0_3(1) driver and it made my X axis drive into the limit switch and then drive to the end of travel where it stopped. I rolled back to 3+1 and it is working fine with the latest MB6 and web control
                                            dc42 administrators @supertb1
                                            @supertb1 please see my earlier post in this thread and use the updated files at https://www.dropbox.com/sh/2dt7sbqpx6l74np/AADn4-lpcil1iqnWKkiVri3Ia?dl=0.
