    Large Format Dowell to Duet conversion
    362
    35.3k
    • Charles Fraserundefined
      Charles Fraser @jay_s_uk
      @jay_s_uk I've tried three cables, none work
        jay_s_uk @Charles Fraser
        @charles-fraser you'd need to make sure your sd card had the correct SD card structure following what's listed here https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
        ultimately you'll need a sys folder containing a populated config.g (which you can get from the config tool) and the www folder which you might as well use the 3.3.0 version of DWC from here
        @charles-fraser said in Large Format Dowell to Duet conversion:
        @jay_s_uk How do I reset this board back to factory settings????
        there is no factory reset as none of your config is stored on the board. its all loaded from the SD card on boot
        Charles Fraserundefined 2 Replies Last reply Reply Quote 0
          @jay_s_uk I have a propper config file from the config tool
          I copied and pasted all the instructions as shown there and added the gcode file and the other one it said. The /www /sys and /firmware folders are copied and pasted onto the SD directly without the parent /config file
            @jay_s_uk
            the SBC can not connect to the duet
            the laptop does not connect to the duet
            do you know how to send it commands over an through the ethernet connected through my modem please?
              @charles-fraser find out the IP address from your router and navigate to that, assuming you have M552 S1 in your config.g
              Charles Fraserundefined 1 Reply Last reply Reply Quote 0
                @jay_s_uk
                my router can not see the Duet
                Neither can the apple
                Neither can the SBC
                I will try to edit the boot file as it says:
                Create a new file named “wpa_supplicant.conf” (exact naming is critical, do not have a ".txt" at the end of the file).
                In a text editor add the following:
                country=GB
                update_config=1
                ctrl_interface=/var/run/wpa_supplicant
                network={
                ssid="SSID_OF_NETWORK"
                psk="PASSWORD_OF_NETWORK"
                  jay_s_uk
                  @charles-fraser I thought you were setting this up standalone? Chucking the SBC into the mix when you can't get it to work standalone won't help.
                  Post a screenshot of the SD card structure.
                  Also post the contents of your config.g
                    @jay_s_uk
                    I'm just making a point by referencing all the devices that can not connect to the Duet
                    Here is a screen shot of my boot drive file config:
                    (NB connecting over wifi doesnt work either)
                    Here is the config folder:
                    config.g
                      @charles-fraser is that boot partition the only partition on the SD card? And is that partition fat32?
                      When the board is powered and the ethernet cable is plugged in, do the lights on the ethernet socket flash?
                        @jay_s_uk yes that is the only partition on the SD. Yes fat32. No lights come on when Ether cable plugged into Duet 3. They do come on when plugged into Pi.
                          @jay_s_uk Is there a table somewhere that explains what a dim orange status light means? This all went wrong when following the instructions for adding the expansion board firmware to the /sys folder.
                            @charles-fraser when powered up from 12/24v only can you take a photo of the lights on the duet 3 please
                            Charles Fraserundefined 3 Replies Last reply Reply Quote 0
                                  @jay_s_uk do you know what these mean? Please could you provide a link to where one can find what they mean. I can find no such information
                                    @charles-fraser they're shown on here. All of those look normal I think
                                    https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram
                                      @jay_s_uk thank you, the diag light is not flashing as it was before which indicates things are working propperly. Now it remains dim orange. This indicates therefore that things are not working propperly. Hopefully someone from Duet @dc42 @Phaedrux @chrishamm can respond in the morning when work starts
                                      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                        @charles-fraser the diag light should flash every second or so.
                                        You could try reinstalling the firmware using bossa https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_All_other_Duet_boards
                                          dc42 administrators @Charles Fraser
                                          That usually means you have erased the firmware on the board. It will need to be reinstallled using USB and Bossa.
                                            Charles Fraser @dc42
                                            This post is deleted!
