Two extruders doesn't heat "together"
@jay_s_uk said in Two extruders doesn't heat "together":
@the_dragonlord might be worth posting the contents of your tool change files as well
here they are:
tfree0.g:
; tfree0.g ; called when tool 0 is freed ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Oct 25 2020 09:41:43 GMT+0100 (Ora standard dell’Europa centrale) if {global.isPrinting==true && global.isTool0Priming==false} M83 ; relative extruder mode M201 E1500.00:1500.00 ; Set extruders acceleration if {move.axes[0].homed && move.axes[1].homed && move.axes[2].homed} G91 G1 Z3 ; raise 3mm G92 G1 E-5 F10000 ; retract 5mm M201 E500.00:500.00 ; Set extruders acceleration
tfree1.g:
; tfree0.g ; called when tool 0 is freed ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Oct 25 2020 09:41:43 GMT+0100 (Ora standard dell’Europa centrale) if {global.isPrinting==true && global.isTool1Priming==false} M83 ; relative extruder mode M201 E1500.00:1500.00 ; Set extruders acceleration if {move.axes[0].homed && move.axes[1].homed && move.axes[2].homed} G91 G1 Z3 ; raise 3mm G92 G1 E-5 F10000 ; retract 5mm M201 E500.00:500.00 ; Set extruders acceleration
tpost0.g:
; tpost0.g ; called after tool 0 has been selected ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Oct 25 2020 09:41:43 GMT+0100 (Ora standard dell’Europa centrale) ; Wait for set temperatures to be reached M116 P0 if global.isPrinting==true if global.isTool0Priming==false M83 ; relative extruder mode if {move.axes[0].homed && move.axes[1].homed && move.axes[2].homed} G1 E6.5 F500 ; undo retract else set global.isTool0Priming=false
tpost1.g:
; tpost0.g ; called after tool 0 has been selected ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Oct 25 2020 09:41:43 GMT+0100 (Ora standard dell’Europa centrale) ; Wait for set temperatures to be reached M116 P1 if global.isPrinting==true if global.isTool1Priming==false M83 ; relative extruder mode if {move.axes[0].homed && move.axes[1].homed && move.axes[2].homed} G1 E6.5 F500 ; undo retract else set global.isTool1Priming=false
in the tpre0.g and tpre1.g I've made no modifications
Before changing the cartridges this configuration of files worked....
p.s. I've copied-pasted the files xxx0.g in xxx1.g but I forgot to adjus the comments
@the_dragonlord yep, nothing obvious in those
have you see my video https://www.youtube.com/watch?v=2CgUXAy0Zoc ? what do you think about the LEDs blinking?
@the_dragonlord said in Two extruders doesn't heat "together":
You have to be a bit careful when looking at the heater LEDs. As a general rule, the bed heater uses a PWM frequency of 10 Hz which is low enough to detect the on/off switching of the Mosfet. But the hot end heaters use a much higher PWM frequency by default, so it's impossible to visually distinguish between say fully on, or switching under PWM control. In RRF 3 you have to set the PWM frequency using the "Q" parameter in M950. If no "Q" value is present, I believe the default is 250 Hz for heaters and fans. If you used the configuration tool, it will likely have set the Q value to 10 Hz for the bed heater and not specified a Q value for the other heaters (so default would be 250 Hz).
@deckingman said in Two extruders doesn't heat "together":
as you can see in my video the frequency is about 2-3Hz so I think that this is abnormal....when the heating works (with just a tool and the bed active) both the LEDs seems always on so the PWM (blinking) frequency is high enough to "cheat" the eyes
Not necessarily. But let's try to do things in a methodical and logical way, rather than speculate as to what might, or might not, be wrong. Run those commands I suggested and let us know what happens.
@jay_s_uk made a valid point about the tool change macros. Whilst there doesn't seem to be anything amiss, I would be inclined to comment out the commands in those macros. Then if we can get things working, you can add them back in.
I will, thanks! I think that later I'll be able to do so when I'll be back home
I've put back the old cartridges and now it seems all solved....i have no words....
i have no words.
How about incredulous?
I'm as confused as you are.
@phaedrux could this be due to a different PID tune at all I wouldn't expect it but who the hell knows
@dougal1957 Might be worth measuring the resistance of the old/new cartridges? Maybe the new ones are drawing more current than they are supposed to?
@gloomyandy said in Two extruders doesn't heat "together":
not me with the issue just throwing ideas into the pot!
