Layer times
Duet Web Control
layer time
520
  • undefined
    IMSother
    Im relatively new to the duet firmware, and after a couple of months printing with an Ender 3 with duet wifi motherboard, the layer time is no longer working properly. Although it shows the current layer correctly on the progress bar, the last layer time doesn't update, neither does de layer time graph.screenshot.png
    For clarification, I'm using cura as slicer, with the reprap gcode flavor and one example gcode is attached (not exactly the gcode from the screenshot because its too big to upload here, but I can upload to my drive if that helps). Also, this is my home routine and config.g files, as I think that maybe this has to do with the BLTouch configuration.
    Any help will be apprecieted.
    Thanks
    ; homeall.g
    ; called to home all axes
    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jun 25 2021 17:30:43 GMT-0300 (Horário Padrão de Brasília)
    G91 ; relative positioning
    G1 H1 X-250 Y-245 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 Y5 F6000 ; go back a few mm
    G1 H1 X-250 Y-245 F120 ; move slowly to X and Y axis endstops once more (second pass)
    G90 ; absolute positioning
    G1 X122 Y117 F6000 ; go to first bed probe point and home Z
    ;G91 ; relative positioning
    ;G1 Z1 F100 ;E lift Z relative to current position
    ;G90 ; absolute positioning
    M550 P"Ender 3" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S0 ; physical drive 0 goes backwards
    M569 P3 S0 ; physical drive 3 goes backwards
    M92 X80.00 Y80.00 Z400.00 E97.03 ; set steps per mm
    M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X30000.00 Y30000.00 Z600.00 E6000.00 ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
    M906 X600 Y600 Z600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X0 Y-6 Z0 S1 ; set axis minima
    M208 X245 Y234 Z260 S0 ; set axis maxima
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    G31 P500 X-55 Y-13 Z1.490 ; set Z probe trigger value, offset and trigger height
    M557 X5:203.5 Y30:200 S24.81 ; define mesh grid
    M376 H10 ; set compensation taper to 10mm
    M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp
    M307 H0 R0.258 C465.8 D0.45 S1.00 V23.8 ; set PID values for bed heater
    M143 H0 S130 ; set temperature limit for heater 0 to 130C
    M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
    M307 H1 R2.779 C155.7 D5.90 S1.00 V24.1 ; set PID values for extruder heater
    M308 S2 P"e1temp" Y"thermistor" T98801 B4185 ; configure sensor 2 as thermistor on pin e1temp
    M950 H2 C"e1heat" T2 ; create chamber heater output on e1heat and map it to sensor 2
    M307 H2 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit
    M141 H2 ; map chamber to heater 2
    M143 H2 S100 ; set temperature limit for heater 2 to 100C
    M950 F1 C"fan1" Q500 ; create fan 0 on pin fan0 and set its frequency
    M106 P1 S1 H1 T100 ; set fan 2 value. Thermostatic control is turned on
    M106 P2 S1 H2 T50 ; set fan 2 value. Thermostatic control is turned on
    M206 Y-9 ; Y axis offset
    M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
    T0 ; select first tool
    CE3_Porca_cubo_traseiro.gcode
    • undefined
      What firmware version?
      As of 3.3:
      RepRapFirmware no longer tries to work out what layer number is printing, and no longer provides an estimate of print completion time based on layer progress. The mechanism to work out the layer number failed in many cases, for example when the slicer used variable layer heights or printed multiple objects one at a time. The removal of these 200 lines of hard-to-maintain code has made more space available for other features on the older Duets that are tight on memory space. A consequence of this change is that DWC will no longer produce a layer chart if the GCode file being printed does not include layer number comments. For slicers that do not normally generate these comments (e.g. PrusaSlicer) it is usually possible to add a layer change script to generate them.
      https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#reprapfirmware-33
      undefined undefined 2 Replies Last reply 8 Sept 2021, 07:52 Reply Quote 0
      • undefined
        o_lampe @Phaedrux
        @phaedrux
        [OffTopic]
        In future releases (with multiple gcode streams and simultaneous printing) it will come handy to pre-calculate layer time of each tool and synchronize them by slowing down the tool with the shorter print path / smaller print area.
        But that will probably be done in DWC or SBC.
        The simulator tool of DWC will play a bigger role then. Writing a combined gcode file from two input streams and detect/avoid tool-collisions a.s.o.
        IMHO it's the best way for older controllers like Duet2 to implement these features . Fingers crossed it will come that way...
        • undefined
          CadetC
          @imsother
          @Phaedrux
          I had a similar problem, but I use PrusaSlicer . Everything came back to normal after adding ;LAYER:[layer_num] to the custom gcode tab under the "before layer change g-code" section in printer setting in PrusaSlicer
          undefined 1 Reply Last reply 10 Sept 2021, 19:47 Reply Quote 1
          • undefined
            IMSother @Phaedrux
            @phaedrux I'm using RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11) and Duet Web Control 3.3.0
            undefined 1 Reply Last reply 10 Sept 2021, 22:09 Reply Quote 0
            • undefined
              IMSother @CadetC
              @cadetc My G-Code already has that line, you can see that the board knows which layer it is, just is not counting the layer time.
              undefined 1 Reply Last reply 10 Sept 2021, 20:13 Reply Quote 0
              • undefined
                DIY-O-Sphere @IMSother
                @imsother
                Maybe the problem is that the versions of RRF and DWC are different.
                The calculation of firmware was changed in RRF3.3. Maybe DWC is not backwards compatible in that case.....
                (UTC+1)
                • undefined
                  Phaedrux Moderator @IMSother
                  @imsother said in Layer times:
                  Update your firmware to match the DWC version. They must be in sync for proper function.
                  I suggest you upload this complete zip file package to the system tab in DWC to get everything up to date.
                  undefined 1 Reply Last reply 11 Sept 2021, 03:59 Reply Quote 0
                  • undefined
                    IMSother @Phaedrux
                    @phaedrux said in Layer times:
                    Just did that, and worked perfectly! Thanks for all the help guys!
                    1 out of 9
