    First time PETG, dudes
    3D Printing General Chat
    1.1k
    • peirofundefined
      peirof @mrehorstdmd
      Thanks,
      In the area where I live, Valencia (Spain), on the coast, there is a lot of humidity, it is easy for us to be over 70% ...
      It is difficult to keep the filament rolls with low humidity ...
      What effects does this humidity have? (on the impression and on the finished piece).
      • Only aesthetics?
        -Is it more difficult to print?
      • the backfires when printed?
      • deckingmanundefined
        deckingman @peirof
        @peirof said in First time PETG, dudes:
        Thanks,
        • Only aesthetics?
        I'll post that link one more time. It has all the information you need and will answer all your questions. https://www.matterhackers.com/news/how-to-succeed-when-printing-with-petg-filament
        peirofundefined 1 Reply Last reply Reply Quote 0
        • peirofundefined
          peirof @deckingman
          @deckingman great article, thx
          • tecnoundefined
            tecno @deckingman
            @deckingman said in First time PETG, dudes:
            @tecno said in First time PETG, dudes:
            @peirof
            Dry your PETG !!! It is hydrophobic
            PETG is afraid of water ??? ๐Ÿ˜ง I think you mean hygroscopic. ๐Ÿ™‚
            Hmmmm marking words you are ๐Ÿ˜‰ I'm just a bloody foreigner making some mistakes.!
            • zaptaundefined
              zapta @deckingman
              We concluded that the reel must have fallen into a river before it was retrieved and vacuum packed
              Apparently some filaments go through water during the manufacturing process.
              https://youtu.be/cI2u-C09JoQ?t=62
                deckingman @tecno
                You seem to be upset. In which case I apologise. I've been trying to learn a foreign language myself for many years. Personally I'm quite appreciative when a native of that language points out mistakes that I have made. Especially when it is done in a polite way and with a ๐Ÿ™‚ . Fear not, I will not try to help again in the future.
                tecnoundefined 1 Reply Last reply Reply Quote 0
                • tecnoundefined
                  tecno @deckingman
                  @deckingman
                  Me upset NO WAY ๐Ÿ˜‰
                  I appreciate all help as do all others Ian, so just forget my answer that was written with a glimpse in the eye.
                  Looking forward to be corrected LOL
                    deckingman @tecno
                    @tecno That's OK then. Electronic communications, whether that be forum posts, emails, social media messages, and with or without emojis, can easily be misinterpreted without the subtly nuances of facial expressions.
                    tecnoundefined 1 Reply Last reply Reply Quote 1
                    • tecnoundefined
                      tecno @deckingman
                      @deckingman
                      I agree, this old fart (a Finn in Sweden) I am a bloody foreigner everywhere L O L
                      • peirofundefined
                        peirof @tecno
                        What is the humidity that is recommended for the filament? Right now there is 70%.ย ย And I don't know what value is adapting, or which one I should look for...
                        Anyway it seems to me a lot, although the filament does not have that level of humidity, it will have enough...
                        I would like to know what is the maximum humidity and the recommended for printing. What solutions do you use to control humidity? I've seen several:
                        • bake at low temperature, about 60
                        • airtight plastic containers
                        • I solved prepared for roll (on Amazon there are many) some recommended
                        • others (moving to the Atacama Desert,....)
                          deckingman @peirof
                          @peirof I built an enclosure for my printer which is largely airtight. All my filament is stored in that same booth. I use cheap dehumidifiers of the type which use Calcium Chloride. Looking at the amount of water produced, I'd say they do a reasonably good job. I plan to install circulating fans at some point, which should improve the efficiency. I have an ESP based temperature and humidy sensor in the garage where the printer booth is situated as part of my growing home automation system, and also plan to fit another inside that booth. Then I'll be able to measure the humidity inside the booth and see if an electric dehumidifier would be worth the expense.
