    First time PETG, dudes
    3D Printing General Chat
    1.1k
      deckingman @mrehorstdmd
      @mrehorstdmd said in First time PETG, dudes:
      I'm not sure what's boiling off, but I see identical behavior in freshly opened spools and spools that have been sitting around for months, so it doesn't seem to be absorbing water from the air.
      I'm not a betting man, but I'll wager that it's definitely boiling off water. One of the worse reels of filament I ever had was reel of E-Sun PET-G which was fresh out of it's vacuum foil packaging. I event wrote a post about it on my blog. I eventually gave it it to someone else who spent many days drying it and eventually managed to get some sort of print but it was never great. We concluded that the reel must have fallen into a river before it was retrieved and vacuum packed. πŸ™‚
      mrehorstdmdundefined zaptaundefined 2 Replies Last reply Reply Quote 1
      • mrehorstdmdundefined
        mrehorstdmd @deckingman
        @deckingman I get shiny, glass-like, transparent prints out of both fresh and long-ago-opened PETG filament as long as I keep print speed above about 25mm/sec. I live in a humid place (in the summer) and it doesn't seem to affect the prints at all. Maybe the filament is already saturated with water. I buy cheap, no-name stuff via amazon.com, and 5 lb spools from Keene Village Plastics, a quality filament maker. I have noticed no difference in the behavior/performance, but maybe the manufacturing processes are similar enough that the spools all arrive with about the same amount of water absorbed into or adsorbed onto them.
        I don't have a filament dryer but I do generally keep filament in sealed boxes with CaCl desiccant. If I'm in the middle of a design and printing test parts I usually just leave the spool on the printer, exposed to the air in the room, often with the window open, sometimes for days at a time. Again, no apparent difference in performance.
        I am usually running the filament through a volcano heater block with a 1mm nozzle, so maybe that is a contributing factor.
        peirofundefined 1 Reply Last reply Reply Quote 0
        • peirofundefined
          peirof @mrehorstdmd
          Thanks,
          In the area where I live, Valencia (Spain), on the coast, there is a lot of humidity, it is easy for us to be over 70% ...
          It is difficult to keep the filament rolls with low humidity ...
          What effects does this humidity have? (on the impression and on the finished piece).
          • Only aesthetics?
            -Is it more difficult to print?
          • the backfires when printed?
            deckingman @peirof
            @peirof said in First time PETG, dudes:
            Thanks,
            • Only aesthetics?
            I'll post that link one more time. It has all the information you need and will answer all your questions. https://www.matterhackers.com/news/how-to-succeed-when-printing-with-petg-filament
            • peirofundefined
              peirof @deckingman
              @deckingman great article, thx
              • tecnoundefined
                tecno @deckingman
                @deckingman said in First time PETG, dudes:
                @tecno said in First time PETG, dudes:
                @peirof
                Dry your PETG !!! It is hydrophobic
                PETG is afraid of water ??? 😧 I think you mean hygroscopic. πŸ™‚
                Hmmmm marking words you are πŸ˜‰ I'm just a bloody foreigner making some mistakes.!
                • zaptaundefined
                  zapta @deckingman
                  Apparently some filaments go through water during the manufacturing process.
                  https://youtu.be/cI2u-C09JoQ?t=62
                    deckingman @tecno
                    You seem to be upset. In which case I apologise. I've been trying to learn a foreign language myself for many years. Personally I'm quite appreciative when a native of that language points out mistakes that I have made. Especially when it is done in a polite way and with a πŸ™‚ . Fear not, I will not try to help again in the future.
                    tecnoundefined 1 Reply Last reply Reply Quote 0
                    • tecnoundefined
                      tecno @deckingman
                      @deckingman
                      Me upset NO WAY πŸ˜‰
                      I appreciate all help as do all others Ian, so just forget my answer that was written with a glimpse in the eye.
                      Looking forward to be corrected LOL
                        deckingman @tecno
                        @tecno That's OK then. Electronic communications, whether that be forum posts, emails, social media messages, and with or without emojis, can easily be misinterpreted without the subtly nuances of facial expressions.
                        tecnoundefined 1 Reply Last reply Reply Quote 1
                        • tecnoundefined
                          tecno @deckingman
                          @deckingman
                          I agree, this old fart (a Finn in Sweden) I am a bloody foreigner everywhere L O L
                          • peirofundefined
                            peirof @tecno
                            What is the humidity that is recommended for the filament? Right now there is 70%.Β Β And I don't know what value is adapting, or which one I should look for...
                            Anyway it seems to me a lot, although the filament does not have that level of humidity, it will have enough...
                            I would like to know what is the maximum humidity and the recommended for printing. What solutions do you use to control humidity? I've seen several:
                            • bake at low temperature, about 60
                            • airtight plastic containers
                            • I solved prepared for roll (on Amazon there are many) some recommended
                            • others (moving to the Atacama Desert,....)
                              deckingman @peirof
                              @peirof I built an enclosure for my printer which is largely airtight. All my filament is stored in that same booth. I use cheap dehumidifiers of the type which use Calcium Chloride. Looking at the amount of water produced, I'd say they do a reasonably good job. I plan to install circulating fans at some point, which should improve the efficiency. I have an ESP based temperature and humidy sensor in the garage where the printer booth is situated as part of my growing home automation system, and also plan to fit another inside that booth. Then I'll be able to measure the humidity inside the booth and see if an electric dehumidifier would be worth the expense.
