Can't rotate screen - not running full desktop - Duet 3 - Rpi 4
I'm losing my mind here. I'm running the RPi4 connected to a Duet 3
I was running a 7" display in landscape mode, but upgraded to a 10" display, which I need to run in portrait mode.
But this version of the OS doesn't have the usual Display options.
There is a little menu, and it only lets me change the screen resolution, and doesn't have any options to rotate the screen.
Is there an easy way to rotate the screen (along with the touch screen). I found the xrandr command, but it's not sticky and doesn't rotate the touchscreen too.
Otherwise, is there a simple way to upgrade my install to the full OS which includes the desktop?
Thanks.
@alankilian I got is all sorted. Thanks.
