First print - very slow speed ...
Hi Guys,
First time with duet(duet2 wifi)
Just finish to calibrate all tempture/estep….homing (I hope, have gear motor on my Z)
when homing everything looking OK speed is 30mm/s
When taking benchy from my prusa slicer(speed is around 30-70mm/s)
Its starting to move slowly around 1-8 mm/s ……why?
Missing something?
Thanks
P.S
firmware 3.3
config (3).g; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.2 on Fri Sep 10 2021 08:45:36 GMT+0300 (Israel Daylight Time); General preferences
M550 P"SK-GO2" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet;Ernst Drives
;M569 P0 S1 D2 ; physical drive 0 goes backwards using default driver timings
;M569 P1 S1 D2 ; physical drive 1 goes backwards using default driver timings
;M569 P2 S1 ; physical drive 2 goes forwards using default driver timings
;M569 P3 S0 ; physical drive 3 goes forwards using default driver timings
;M569 P4 S1 ; physical drive 4 goes backwards using default driver timings
;M569 P5 S1 ; physical drive 5 goes forwards using default driver timings
;M584 X0 Y1 Z2:4:5 E3 ; set drive mapping
; ==========Drives
M92 X200.00 Y200.00 Z3200.00 E408 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z450.00 E6000.00 ; set maximum speeds (mm/min)
M201 X2000.00 Y2000.00 Z100.00 E2000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z600 E550 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
;;M671 X-13:-13:323 Y20:250:140 S50 ; set z drive coordinates
;;M350 X16 Y16 Z16:16:16 E16 I1 ; configure microstepping with interpolation
;;M92 X200.00 Y200.00 Z160.00 E420.00 ; set steps per mm
;;M566 X600.00 Y600.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
;;M203 X30000.00 Y30000.00 Z2400.00 E2400.00 ; set maximum speeds (mm/min)
;;M201 X2000.00 Y2000.00 Z200.00 E2000.00 ; set accelerations (mm/s^2)
;;M906 X800 Y800 Z600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
;;M84 S30 ; Set idle timeout; Axis Limits
M208 X305 Y305 Z340 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 B0 R0.413 C530.0 D9.48 S1.00 V24.2M140 H0 ; map heated bed to heater 0
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 B0 R2.328 C205.0 D5.24 S1.00 V24.1
M143 H1 S250 ; set temperature limit for heater 1 to 250C; Fans
M106 P0 C"part_fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
M106 P1 C"ext_fan" S1 H1 T40 ; set fan 1 name and value. Thermostatic control is turned on; Tools
M563 P0 S"main" D0 H1 F0 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
M575 P1 B57600
M501
T0 ; select first tool -
@asafo what's in your start.g and slicer startcode?
@cosmowave
I dont have file called start.g in my system file, but in my prusaSlicer...the pre G code is:
;G28 ; home all axes
;G1 Z5 F5000 ; lift nozzle
M220 S100 ; reset speed factor to 100%
M221 S100 ; reset extrusion rate to 100%
G90 ; use absolute coordinates
M83 ; extruder relative mode
; Set the heating
M104 S160 ; set nozzle print temp to 160 for pre-print leveling to prevent oozing
M140 S[first_layer_bed_temperature] ; set heatbed temperature
; Wait for final bed heating
M190 S[first_layer_bed_temperature] ; wait for the bed to heat up
;; Bed Leveling
;G32 ; True Bed Leveling
;G1 Z5 F5000 ; move z up little to prevent scratching of surface
;G1 X3 Y3 F5000 ; go print area
;;Set Nozzle Temp
M109 S[first_layer_temperature] ; wait for the nozzle to heat up
; Return to prime position, Prime line routine
G28
G1 Z0.2 F3000 ; lower nozzle to printing height
G92 E0.0 ; reset extrusion distance
G1 X150 E15 F1000 ; prime nozzle
G1 X210 F500 ; Slow wipe
G1 E0.2 F1500; de-retract
G92 E0.0 ; reset extrusion distance -
@asafo what firmware flavour have set in PrusaSlicer? Should be RepRap. If you set it to Marlin it will dump a set of speed settings in the file which are in the wrong units for RRF and give a slow print
@engikeneer
WOW..F....K.......I just moved from my skr1.3
I forgot to change this......
Thanks
going to try it
