    How do I speed up the bed mesh level
    485
    • rexxundefined
      rexx
      How do I speed up the mesh level
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @rexx
        @rexx One way would be to probe fewer points.
        Another way if to not lift the probe as far off the bed when moving to the next point.
          There are a few things that come into play, most controlled by the parameters in M558.
          The travel speed between probe points can be increased. The probing dive speed can be increased to a point (you don't want to probe too fast which can lead to inconsistency). And the dive height can possibly be reduced to a minimum so you don't have as far to go to touch the bed.
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type
          rexxundefined 3 Replies Last reply Reply Quote 0
          • rexxundefined
            rexx @Phaedrux
            @phaedrux so is this speed change for travel in the config.g or….
            • rexxundefined
              rexx @Phaedrux
              @phaedrux
              M950 S0 C"exp.heater3"
              M558 P9 C"^zprobe.in" H5 F120 T6000
              G31 P500 X-42 Y-1 Z2.90
              M557 X15:315 Y15:315 S75
              so is the speed the f120 in the M558 line?
              is the T6000 the dive height?
              • rexxundefined
                rexx @Phaedrux
                @phaedrux ok so
                H5 is the dive height
                F120 is the travel speed
                T6000?
                  alankilian @rexx
                  @rexx You can look up all the parameters for ALL gcode HERE.
                  • Tnnn Travel speed to and between probe points (mm/min). This is also the Z lift speed after probing. The corresponding axis speed limits set by M203 will be used instead if they are lower.
                  rexxundefined 2 Replies Last reply Reply Quote 0
                  • rexxundefined
                    rexx @alankilian
                    @alankilian thank you
                    • rexxundefined
                      rexx @alankilian
                      @alankilian i have the travel speed increased much better now thank you
                      can i change the probe points or how do i do this
                        Read this
                        https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
                        rexxundefined 1 Reply Last reply Reply Quote 0
                        • rexxundefined
                          rexx @Phaedrux
                          @phaedrux thank you
