    Duet 2 Ethernet will not boot -> need WAC
    • L3DS
      L3DS last edited by
      I used a Duet 2 Ethernet in one of my machines but it simply did not boot and I thus got no connection. After changing it by another one everything was fine.
      Please send me a Warranty Authorisation code.
      I built up about 10 similar machines in the last 3 years and I did not have this problem till now.
      Thank you very much in advance!
      • T3P3Tony
        T3P3Tony administrators @L3DS last edited by
        @l3ds we need a bit more information to understand the causes of the failure.
        www.duet3d.com
          @l3ds said in Duet 2 Ethernet will not boot -> need WAC:
          Can you be more specific?
          Do any lights come on?
          Have you connected it to USB?
          When and where did you purchase it?
          Please follow the troubleshooting steps here and let us know how it goes.
          https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
          L3DS 1 Reply Last reply Reply Quote 0
          • L3DS
            L3DS @Phaedrux last edited by
            @phaedrux said in Duet 2 Ethernet will not boot -> need WAC:
            Yes, the LED VIN, +5V and +3.3V were on.
            No, as I never used the USB connection before.
            I bought it at Filafarm on the 26th of August 2021.
            As it is really not my first Duet Ethenet Board I used, and the other one worked without problems, I did not investigate any more. Furthermore the machine is located at my customer's place so I can not go there just for testing..
            • T3P3Tony
              @l3ds I realise this is not the firmst Duet you have used so I agree its unlikely to be a configuration issue however it may be fixable by a firmware reload. This is why we want to see what happens when you connect to it over USB and then attempt to connect using a terminal like YAT.
              www.duet3d.com
