    Question: Best settings for maximum torque of stepper motor
    848
    • wieman01undefined
      wieman01
      I am running a clay printer with a Duet 2 Wifi and occasionally, my extruder motor would miss a few (micro-)steps because the extruder screw has to push high-viscosity material through the nozzle and work under high pressure.
      What are your thoughts on getting the maximum torque out of my extruder motor?
      Of course the torque curve (torque/speed) is what matters most, also the motor current. But are there any other settings I should be aware of?
      I have also experimented with different micro-stepping settings, and it appears E16 would give me the best results so far.
      Any thoughts will be appreciated. Thank you.
      M92 X100.00 Y100.00 Z1600.00 E100:5000.00			; set steps per mm
      M350 X16 Y16 Z16 E16:16 I1			                ; configure microstepping with interpolation
      M566 X500.00 Y500.00 Z20.00 E1000.00:500.00			; set maximum instantaneous speed changes (mm/min)
      M203 X5000.00 Y5000.00 Z1000.00 E6000.00:400.00			; set maximum speeds (mm/min)
      M201 X300.00 Y300.00 Z500.00 E250.00:500.00			; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1000 E2750:2000 I30  	       			; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            		; set idle timeout
      o_lampeundefined zaptaundefined 2 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @wieman01
        @wieman01 Using the highes possible motor voltage helps. I'd also avoid stealthChop, (bad experience with earlier drivers on a different controller)
        High Torque steppers usually have a higher inductance. Picking the right stepper can make a huge difference.
        wieman01undefined 1 Reply Last reply Reply Quote 1
        • wieman01undefined
          wieman01 @o_lampe
          @o_lampe said in Question: Best settings for maximum torque of stepper motor:
          stealthChop
          Thank you.
          I did not mention I am using a Duet 2 with a TMC2660 driver, so Stealthchop is not supported anyway.
          As for the stepper, yes, I will try another geared stepper, but was wondering if anything can be done here with a little tweaking.
            jay_s_uk @wieman01
            @wieman01 have you looked at the EMF calculator? https://www.reprapfirmware.org/emf.html
            • wieman01undefined
              wieman01 @jay_s_uk
              @jay_s_uk said in Question: Best settings for maximum torque of stepper motor:
              Yes, I have seen it, but I think the graph I have attached shows the same thing. The supplier provides it and I have taken the relevant range (up to 200 RPM) into account.
              dc42undefined 1 Reply Last reply Reply Quote 1
                dc42 administrators @wieman01
                @wieman01 the graph you posted should be for a particular driver voltage. What voltage was quoted?
                wieman01undefined 2 Replies Last reply Reply Quote 1
                • wieman01undefined
                  wieman01 @dc42
                  @dc42 said in Question: Best settings for maximum torque of stepper motor:
                  Yes, this is for 24v. I am using a 24v PSU in combination with a Duet 2.
                  • wieman01undefined
                    wieman01 @dc42
                    Oh, I see my error now I think. The Duet pins I am connecting this stepper to only supply 5v. You're right.
                    Would it work if I connected the phase to the 24v VIN instead? Hope this is making sense.
                    The graph is for 24v.
                      @wieman01 said in Question: Best settings for maximum torque of stepper motor:
                      The stepper motor outputs provide up to almost VIN voltage, so 24V if you are providing 24V VIN.
                      • wieman01undefined
                        wieman01 @dc42
                        Thank you, yes, I see that now. Also it would not make much sense if they did not.
                        If nothing else works, I will try another (geared) stepper for that purpose.
                          @wieman01 what's the rated current of the stepper motor, and what motor current have you set?
                          • wieman01undefined
                            wieman01 @dc42
                            I am currently running it at 2.5A. The rated current is 3.0A per phase.
                            • zaptaundefined
                              zapta @wieman01
                              @wieman01, can you improve the properties of the clay? E.g add water?
                              • wieman01undefined
                                wieman01 @zapta
                                @zapta said in Question: Best settings for maximum torque of stepper motor:
                                Yes, you're right, in principle that is an option, however, in our case the viscosity of the material we are using cannot be changed for various reasons I won't bother you with. 🙂
                                I have order a geared stepper, let's see if that works out for us.
