    Homming issues strange Behaviors
    Config Tool
    536
    • bartekpundefined
      bartekp
      My printer, when I start HOME ALL AXIS, move simultaneously Z then Y and X but Y goes in the opposite direction to the Endstop switch and you don't know what I will change, it always goes in the same direction.
      I change the direction in the Marlin Configurator and the commands for endstop do not change.
      In addition, I noticed that when I start HOME Y axis, it starts with the first Z axis. I'm already exhausted with this, I can't set it up. Printer tronxy x5 SA endstpy on each axis normally open Please help
      Bart
      Config g lines
      M208 X500 Y500 Z600 S0 ; set axis maxima
      M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
      M558 P1 C"zprobe.in" H5 F120 T12000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X70:500 Y70:500 S20 ; define mesh grid
      SIamundefined 1 Reply Last reply Reply Quote 0
      • SIamundefined
        SIam @bartekp
        @bartekp please post your complete config.g file also homex.g homey.g homez.g and homeall.g
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        bartekpundefined 1 Reply Last reply Reply Quote 0
        • bartekpundefined
          bartekp @SIam
          @siam
          ; Configuration file for Duet WiFi (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.3 on Fri Oct 01 2021 17:20:53 GMT+0200 (czas środkowoeuropejski letni)
          M550 P"My Printer" ; set printer name
          M669 K1 ; select CoreXY mode
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M350 Z16 E16 I0 ; configure microstepping without interpolation
          M350 X16 Y16 I1 ; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z2756.00 E420.00 ; set steps per mm
          M566 X900.00 Y900.00 Z150.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X30000.00 Y30000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
          M201 X5000.00 Y5000.00 Z50.00 E1000.00 ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp
          M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
          T0 ; select first tool
          ; homex.g
          ; called to home the X axis
          G91 ; relative positioning
          G1 H2 Z5 F12000 ; lift Z relative to current position
          G1 H1 X-505 F1800 ; move quickly to X axis endstop and stop there (first pass)
          G1 X5 F12000 ; go back a few mm
          G1 H1 X-505 F360 ; move slowly to X axis endstop once more (second pass)
          G1 H2 Z-5 F12000 ; lower Z again
          G90 ; absolute positioning
          ; homey.g
          ; called to home the Y axis
          G1 H1 Y-505 F1800 ; move quickly to Y axis endstop and stop there (first pass)
          G1 Y5 F12000 ; go back a few mm
          G1 H1 Y-505 F360 ; move slowly to Y axis endstop once more (second pass)
          ; homez.g
          ; called to home the Z axis
          G1 H1 Z605 F1800 ; move Z up until the endstop is triggered
          G92 Z600 ; set Z position to axis maximum (you may want to adjust this)
          ;G91 ; relative positioning
          ;G1 Z5 F200 ; lift Z relative to current position
          ;G90 ; absolute positioning
          ; homeall.g
          ; called to home all axes
          G1 H1 X-505 Y-505 F1800 ; move quickly to X or Y endstop and stop there (first pass)
          G1 H1 X-505 ; home X axis
          G1 H1 Y-505 ; home Y axis
          G1 X5 Y5 F12000 ; go back a few mm
          G1 H1 Y-505 ; then move slowly to Y axis endstop
          G1 H1 Z605 F360 ; move Z up stopping at the endstop
          • SIamundefined
            SIam @bartekp
            @bartekp said in Homming issues strange Behaviors:
            You have the Y-Axis to drive Backwards, was this a Test? If not then let the Y axis drive forwards and retest
            bartekpundefined 2 Replies Last reply Reply Quote 0
            • bartekpundefined
              bartekp @SIam
              @siam both directionts won't work corectly
              • bartekpundefined
                bartekp @SIam
                @siam yes that was test and this solution dont work
                • T3P3Tonyundefined
                  T3P3Tony administrators @bartekp
                  @bartekp
                  This is to be expected - it is fairly normal to raise Z a bit before homing on this sort of printer so that if the nozzle happens to be on the bed then it wont drag across the bed while homing.
                  ; homey.g
                  Can you do the following test:
                  1. With the printer powered down, SLOWLY move the Y axis so it is in the middle of its range by hand. you need to do this slowly so that the motor does not back power the board.
                  2. Power the printer on and Home Z then Home X. Do not home Y yet.
                  3. Send G92 Y250 that will tell the printer that the Y axis is at 250mm (which is not correct because you moved it by hand, but should be good enough for the short moves we are going to do as a test.
                  4. Using the dashboard in DWC jog Y +10 the Y-10. Does the axis move in the +/- directions as expected? If not send M569 P1 S1 or M569 P1 S0 (the opposite of what it is currently set to and then test again. It should now move in the correct direction.
                  5. Now we need to test if your endstop is working. Send M119 and it should report Y: not stopped. now manually hold down the Y endstop and send M119 again it should report stopped. If that is working then we know the endstop is working correctly.
                  6. With a working endstop and motor going the right direction you can confirm that config.g has the correct M569 setting for Y based on the test in #4.
                  With those steps done try and home Y, have your hand over the power to switch it off if it goes the wrong direction. It should be going to Y minimum as that is where you have set your endstop to be.
                  www.duet3d.com
                  • bartekpundefined
                    bartekp @T3P3Tony
                    @t3p3tony HI thanks for help,
                    I cant home Z because is alert that I did't homed XY
                    how to ?
                    • bartekpundefined
                      bartekp @bartekp
                      @bartekp If I made by hand homing jog +10 is out of endstop and -10 on Y is to endstop direction
                      I put new config g file wich is
                      ; generated by RepRapFirmware Configuration Tool on Wed Oct 24 2018 17:07:50 GMT+0200 (Mitteleuropäische Sommerzeit)
                      M667 S1 ; Select CoreXY mode
                      M550 PTronxy X5S ; Set machine name
                      M552 S1 ; Enable network
                      M587 S"WIFI NAME" P"PASSWORD" I192.168.1.69 J192.168.1.1 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
                      M586 P0 S1 ; Enable HTTP
                      M586 P1 S0 ; Disable FTP
                      M586 P2 S0 ; Disable Telnet
                      M92 X80 Y80 Z800 E830 ; Set steps per mm
                      M566 X600 Y600 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
                      M203 X18000 Y18000 Z180 E1500 ; Set maximum speeds (mm/min)
                      M201 X3000 Y3000 Z100 E10000 ; Set accelerations (mm/s^2)
                      M906 X1000 Y1000 Z1000 E1100 I30 ; Set motor currents (mA) and motor idle factor in per cent
                      M208 X500 Y500 Z600 S0 ; Set axis maxima
                      M574 X1 Y1 S0 ; Set active low endstops
                      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                      M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
                      G31 P25 X-19 Y0 Z2.65 ; Set Z probe trigger value, offset and trigger height
                      M557 X30:315 Y30:305 S59 ; Define mesh grid
                      M305 P0 T100000 B4138 C0 R4700 X2 ; Set thermistor + ADC parameters for heater 0 and remap it to channel 2
                      M143 H0 S80 ; Set temperature limit for heater 0 to 80C
                      M143 H1 S250 ; Set temperature limit for heater 1 to 250C
                      M563 P0 D0 H1 S"Extruder" ; Define tool 0
                      ; Automatic power saving
                      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                      M671 X20:295:20:295:170:170 Y10:305:305:10:10:305 P8 ; adjusting screws at rear left (-15,190), front middle (100,-10) and rear right (215,190), thread pitch 8mm
                      M572 D0 S0.13 ; Set pressure control to 0.13
                      M307 H1 A459.4 C167.2 D4.1 ; PID for Extruder
                      M307 H0 A101.4 C1123.0 D10.0 B0 ; PID for Bed
                      M592 D0 A0.015 B0.0012 L0.2 ; Nonlinear adjustment
                      M591 D1 P1 C4 S1 ; Enable E1 Endstop for filament run out detection
                      M581 E1 S0 T1 ; invoke trigger 1 when a falling edge is detected on the E1 endstop input
                      • bartekpundefined
                        bartekp @T3P3Tony
                        • bartekpundefined
                          bartekp @bartekp
                          @bartekp z probe is not connected
                          BY switching endstops M119 reports that endstops working good
                          • bartekpundefined
                            bartekp @bartekp
                            @bartekp now is that when I use All axis homing X goes home Z move home and Y go out of endstops
                            when I change direction of Y is the same situation but Y motors jumping with X motor but when i use only X homing moving all axis and y goes in the same direction as always .
                            When Use homing Y X goes home and Z and Y goes to endstops but jumping with X and I did this two times ant after this Y comes home but with jumping .
                            • bartekpundefined
                              bartekp @bartekp
                              @bartekp Solved, connection issue by wrong axis , corexy I didnt know exacly wich motor in corexy is X and wich is Y. My mistake .
                              T3P3Tonyundefined 1 Reply Last reply Reply Quote 1
                              • T3P3Tonyundefined
                                @bartekp ahh right ok, thanks for letting us know what the issue was!
                                www.duet3d.com
