    Tevo LM recent conversion and z step issues
    2.0k
    • Dougal1957undefined
      Dougal1957 @the_gibson
      @the_gibson looking better has that solved the problem of the carriage fouling? also try running the G32 a few time see if it all settles in to lower figures (or the after deviation converges down so that each subsequent run doesn't get much different)
      the_gibsonundefined 1 Reply Last reply Reply Quote 0
      • the_gibsonundefined
        the_gibson @Dougal1957
        @dougal1957 Already all over that... and yes, carriage is good now.
        I'll be posting back with results shortly.
        definitely getting better.
        G32
        Calibrated 6 factors using 13 points, deviation before 0.085 after 0.031
          the_gibson @the_gibson
          @the_gibson ok, looking good now.
          G32
          Calibrated 6 factors using 13 points, deviation before 0.036 after 0.035
          Going to try another print.
            @the_gibson It is better, but definitely still dragging the print. first layer goes down great.
            • T3P3Tonyundefined
              T3P3Tony administrators @the_gibson
              @the_gibson ok so delta calibration is looking good now, and you say the first layer is going down well, what do you mean by "but definitely still dragging the print"
              www.duet3d.com
                the_gibson @T3P3Tony
                @t3p3tony like the Z steps aren't moving appropriately. As soon as the second layer starts, you can hear the hotend dragging across the print, eventually either breaking the extruded material free of the bed, or creating a very deformed print. This still feels like either an extrusion issue, or a z steps being off issue.
                but first problem is definitely fixed. 🙂
                Dougal1957undefined 1 Reply Last reply Reply Quote 0
                  @the_gibson said in Tevo LM recent conversion and z step issues:
                  What size pulleys do you have 16 or 20 tooth or some other size?
                    @dougal1957 Stock 20 tooth pulleys.
                      Have you double checked them as your symptoms suggest that yours are slightly different to that.
                        @dougal1957 I have not. Assumed they were what was listed on the printer specs. You think they are 16's?
                        Dougal1957undefined crpalmerundefined 2 Replies Last reply Reply Quote 0
                          that is what I would think maybe what you could do is mark one tooth with a sharp and then count them.
                          • crpalmerundefined
                            crpalmer @the_gibson
                            @the_gibson I think that your steps/mm are right for x/y/z. If they were wrong you'd get a calibrated height that was well off of 530 because the calibration also calibrates how high it can go. Also, mine was running back in its stock days with the same value.
                            Is your first layer actually a little too close? You could print a cube and see if you have "elephant foot" at the bottom indicating it is too close.
                            If not, are you extruder steps/mm correct and have you calibrated the flow rate? Dragging could also be over extrusion.
                            the_gibsonundefined 2 Replies Last reply Reply Quote 0
                              @dougal1957 Definitely 20's.
                                the_gibson @crpalmer
                                @crpalmer I am leaning toward overextrusion now as well.
                                  @crpalmer I have reduce the extruder steps all the way down to 160... still happening...
                                  Starting to rule out overextrusion.
                                  adding current config.g
                                  ; generated by RepRapFirmware Configuration Tool v3.3.4 on Sun Oct 10 2021 10:43:02 GMT-0400 (Eastern Daylight Time)
                                  M550 P"HOWEE"                                      ; set printer name
                                  M555 P2
                                  M665 R157 L397.107 B175 H525                        ; Set delta radius, diagonal rod length, printable radius and homed height
                                  M666 X0.15 Y0.08 Z0.07                                      ; put your endstop adjustments here, or let auto calibration find them
                                  M569 P0 S1                                         ; physical drive 0 goes forwards
                                  M569 P1 S1                                         ; physical drive 1 goes forwards
                                  M569 P2 S1                                         ; physical drive 2 goes forwards
                                  M569 P3 S1                                         ; physical drive 3 goes forwards
                                  M584 X0 Y1 Z2 E3                                   ; set drive mapping
                                  M350 X32 Y32 Z32 E32 I1                            ; configure microstepping with interpolation
                                  M92 X160 Y160 Z160 E810							; set steps per mm
                                  M566 X1500.00 Y1500.00 Z1500.00 E1500.00           ; set maximum instantaneous speed changes (mm/min)
                                  M203 X39960 Y39960 Z39960 E3000.00        ; set maximum speeds (mm/min)
                                  M201 X1000.00 Y1000.00 Z1000.00 E1500.00           ; set accelerations (mm/s^2)
                                  M906 X1100 Y1100 Z1100 E880 I30                   ; set motor currents (mA) and motor idle factor in per cent
                                  M208 Z0 S1                                         ; set minimum Z
                                  M574 X2 Y2 Z2 S1                                   ; set active high endstops
                                  M307 H3 A-1 C-1 D-1                                ; disable heater on PWM channel for BLTouch
                                  M558 P9 H5 F120 T6000                              ; set Z probe type to bltouch and the dive height + speeds
                                  M558 H30                                           ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                                  G31 P500 X0 Y20 Z4.4                                 ; set Z probe trigger value, offset and trigger height
                                  M557 R150 S45                                      ; define mesh grid
                                  M305 P0 T100000 B4138 R4700                        ; set thermistor + ADC parameters for heater 0
                                  M143 H0 S100                                       ; set temperature limit for heater 0 to 100C
                                  M305 P1 T100000 B4138 R4700                        ; set thermistor + ADC parameters for heater 1
                                  M106 P0 S0 I0 F500 H-1                             ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                  M106 P1 S1 I0 F500 H1 T45                          ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                  crpalmerundefined 1 Reply Last reply Reply Quote 0
                                  • crpalmerundefined
                                    @the_gibson Your original config of the steps:
                                    M92 X80.00 Y80.00 Z80.00 E403.00 ; set steps per mm'
                                    is probably better than what you have now. I think interpolation only works at 16 steps/mm which was a mistake in my old config.
                                    Did you ever print a small cube to see what it looked like?
                                      @crpalmer said in Tevo LM recent conversion and z step issues:
                                      Adjusted back to these settings.
                                      printing one now... this is going to be funny.
                                        @the_gibson
                                        ok, I'm dumb... z-offset in the slicer was the culprit.
                                        now mostly printing... have some tuning to do... but working.
                                          the_gibson
                                          @crpalmer @Dougal1957 @T3P3Tony
                                          Turned out to be a Z-offset in my slicer I dismissed because I needed it before.
                                          All is working as it should now.
                                          Thank you for your help, and the debugging assist!
